Flywheel
Old November 18th, 2010, 05:40 PM   #1
1999 Mustang GT
Fuma23 is on a distinguished road
Send a message via AIM to Fuma23
Flywheel
Hi I have a question for a flywheel. I have a 99 GT and replaced the engine with a 04 GT. But once I accelerate the car starts to shake. The mechanic told me it was the flywheel that was not the right size. I got the flywheel from a junk yard. I dont know what car it came from but the mechanic told me it will fit the car. And it did fit but now the car shakes. If i dont accelerate the engine is so smooth it feels like its off. What size of flywheel do I need for my car. If its a 99 with an 04 engine. The car is manual. Any help would be greatly appreciated. No one can give me a good answer to my question. Thank you for your time.
Edit Report
Old November 18th, 2010, 10:31 PM   #2
stal94gt's Avatar
2003 mustang v6 ;)
slow
stal94gt has much to be proud ofstal94gt has much to be proud ofstal94gt has much to be proud ofstal94gt has much to be proud ofstal94gt has much to be proud ofstal94gt has much to be proud ofstal94gt has much to be proud ofstal94gt has much to be proud ofstal94gt has much to be proud of
there is no such thing as wrong size fly wheel, if it fits it fits. yes it may have to be balanced depending on what year car it came out of, some people get vibrations with their drive shaft being spun 180 out.
Old November 18th, 2010, 10:48 PM   #3
pumm3l's Avatar
1999 Mustang GT
12.09@117.87
pumm3l is on a distinguished road
I had some annoying vibrations with a piece of junk ebay flywheel because the alignment dowel holes didn't line up with the pressure plate so I didn't use them.
Lesson learned, don't cheap on out parts that are a bitch to replace if they cause problems. I replaced mine with a billet frpp flywheel and made sure to use the alignment dowels, no vibration.
99 GT - 462 rwhp / 405 rwtq
L&M Engines tuned - SStang.com
Old November 18th, 2010, 11:06 PM   #4
stal94gt's Avatar
2003 mustang v6 ;)
slow
i dont have the alignment dowels in mine and it has run fine for years. no vibrations, the one you had probably was not the correct balance for the motor. im still using the oem one
Old November 18th, 2010, 11:25 PM   #5
almighty396's Avatar
2003 mustang gt
almighty396 is on a distinguished road
well from what i know 99-01 use an 8 bolt flywheel while mid 01-04 use a 6 bolt flywheel that maybe the problem. are you sure you have an 04 engine?
Old November 19th, 2010, 03:23 AM   #6
ndfrspd's Avatar
1998 Mustang GT
1:34.43@13.86
ndfrspd is infamous around these parts
well theres your problem. "i bought a flywheel from a junkyard." come on bro, you can't honestly expect to put a junkyard part on the end of your crankshaft, that spins at all kinds of low and high rpms and not know where the part has been, what the condition is, so on and so on. like my mans said above me, dont cheap out on mechanical shit that will be a bitch to replace if it doesnt work out.
save some cash, buy yourself a beautiful billet flywheel from americanmuscle and i guarantee you will love it.
"The only way to learn about a car truly is to break something and fix it yourself..."
Old November 19th, 2010, 04:04 AM   #7
mm's nitrous mod
SWEET2KSTANG's Avatar
2000 mustang gt
11.79@115.83 (old set up)
iTrader: 8 reviews
^why not? a flywheel is a flywheel, and wont matter if its from ford or salvage yard. if its in spec and no physical damage, then its fine to use.
Old November 19th, 2010, 04:06 AM   #8
mm's nitrous mod
2000 mustang gt
iTrader: 8 reviews
ALL 4.6 are neutral balanced. i have heard horror stories about ebay flywheels with a different balance, but i yet to see any type of proof. as for the vibration, it sounds like a balance or loose part issue.
Old November 19th, 2010, 09:54 AM   #9
rotten's Avatar
SA XD40
rotten is on a distinguished road
I think you should change mechanics .
09 crf450x super motard.
06 f250 powerstroke
04 cbr1000rr
03 rsx-s
Old November 19th, 2010, 10:02 AM   #10
Geno's Avatar
01 Mustang GT
12.7126@109.65
Geno is on a distinguished road
I agree. Not much can go wrong with a flywheel. I personally would run a flywheel from a salvage yard before using a cheap ebay piece of crap.
MM SUPERSHIFTER
Old November 19th, 2010, 10:07 AM   #11
1999 Mustang GT
I think its the balance. Thank you for your help.
Old November 19th, 2010, 10:07 AM   #12
Geno's Avatar
01 Mustang GT
12.7126@109.65
Originally Posted by Geno View Post
I agree. Not much can go wrong with a flywheel.Have it resurfaced and your good to go. I personally would run a flywheel from a salvage yard before using a cheap ebay piece of crap.
Wait ,I did use one from a salvage yard on my swap. Bought one from Oreillys first and it had "made in China" stamped on it so I took it back.
MM SUPERSHIFTER
Old November 19th, 2010, 10:18 AM   #13
1999 Mustang GT
The flywheel from the salvage was in great conditions. With the Ford stamp But the flywheel he removed from my old engine was smaller then the one from the salavge. There was a big change in size. At the yard they told me it was from an 04 mustang. It was next to an 04 engine but not on it. But this is what i get for taking shortcuts. Thank everyone i will replace the flywheel for a new one.
Old November 19th, 2010, 10:23 AM   #14
rotten's Avatar
SA XD40
size it either 10.5 or 11" and there all zero balanced , i would seroiusly goto a diffrent mechanic .
You need to describe the issue more , is the lurking shaking when engaging the clucth ? or is it vibrating when in gear and accelerating ?
06 f250 powerstroke
04 cbr1000rr
03 rsx-s
Old November 19th, 2010, 10:26 AM   #15
1999 Mustang GT
Only accelerating and the RPM's go down. Do you think its the flywheel or something els?
Old November 19th, 2010, 10:30 AM   #16
rotten's Avatar
SA XD40
that's something else, I'd look at the driveshaft .
06 f250 powerstroke
04 cbr1000rr
03 rsx-s
Old November 19th, 2010, 10:34 AM   #17
1999 Mustang GT
Yes also in neutral if i press the gas it shakes and wont stop till the RPM's are down. But after that the engine is smooth.
Old November 19th, 2010, 10:38 AM   #18
rotten's Avatar
SA XD40
he said it does , DId you replace the pilot bearing ?
06 f250 powerstroke
04 cbr1000rr
03 rsx-s
Old November 19th, 2010, 10:40 AM   #19
rotten's Avatar
SA XD40
wTF delelted posts ?
06 f250 powerstroke
04 cbr1000rr
03 rsx-s
Old November 19th, 2010, 10:43 AM   #20
Geno's Avatar
01 Mustang GT
12.7126@109.65
The pilot bearing would have no effect on it in neutral would it?
MM SUPERSHIFTER
Threads Similar to: Flywheel
flywheel bigtom Modular Mustangs 0 April 27th, 2010 11:30 PM
New Flywheel UnixHH 99-04 26 April 26th, 2010 08:45 AM
flywheel ModularSteed 96-98 1 September 13th, 2009 09:29 PM
Flywheel bbrewer03 96-98 6 August 18th, 2007 09:47 PM
