Heads vs Cams on PD blower
Old November 20th, 2010, 09:22 PM   #1
bobz18711's Avatar
2001 Mustang GT
TBD
bobz18711 is on a distinguished road
Ok, so I will be coming home fron the Desert with a little spending money. I'm trying to finish up my performance mods, so my question is, I want to make the most out of my MMR 600 with the 2.1 KB SC. I would like to save as much money as possible, are Heads really worth the price tag or should I just go for cams, and what kind?? I plan on just going up to 10-11psi, KB said if I go higer than 11, I will need to run some type of Octane booster, I don't want that. Also if I choose to go with say 10 psi would I need to up the Octane when adding the cams or heads or both??
01 GT with 2.1 Kenne Bell, MMR 600 Aluminum Block,
4:10's, Dyno done 2/27/2012: 404RWHP
Old November 20th, 2010, 09:26 PM   #2
BakerFX4's Avatar
BakerFX4 has much to be proud ofBakerFX4 has much to be proud ofBakerFX4 has much to be proud ofBakerFX4 has much to be proud ofBakerFX4 has much to be proud ofBakerFX4 has much to be proud ofBakerFX4 has much to be proud ofBakerFX4 has much to be proud ofBakerFX4 has much to be proud ofBakerFX4 has much to be proud of
iTrader: 14 reviews
cams without a doubt!
"Heads dont do you any good for the fact that you are forcing air throught them anyway" says Tbird!
MUCH LOVE TBIRD!
Really man, if i were you, id do some research on the MPH KB cams. Those would be one of my first choice of cams.
4.75 MMR 900se
Livernois ported heads
HP 292s blower cams
Procharger D1sc at 20+ psi
IW 15% OD pulley
(and more bolt ons)
E85
Tune/numbers coming shortly!!
Old November 20th, 2010, 09:28 PM   #3
BYAHHHH!
Scott2001GT's Avatar
2001 Mustang GT
13.874
just do cams IMO.We will make plenty of power like that. But the rest of your money into your suspension.
Old November 20th, 2010, 09:29 PM   #4
stal94gt's Avatar
2003 mustang v6 ;)
slow
stal94gt has much to be proud ofstal94gt has much to be proud ofstal94gt has much to be proud ofstal94gt has much to be proud ofstal94gt has much to be proud ofstal94gt has much to be proud ofstal94gt has much to be proud ofstal94gt has much to be proud ofstal94gt has much to be proud of
i have ported heads and stock cams. i suck
Old November 20th, 2010, 09:30 PM   #5
bobz18711's Avatar
2001 Mustang GT
TBD
MUCH LOVE TBIRD!
Yes, those were the Cams I was eyeing for a long time, but they don't have a web site anymore, And I know they moved up to the Chicgo area, anyone know if they are still doing those cams, and how to get in contact with them??
Old November 20th, 2010, 09:33 PM   #6
BakerFX4's Avatar
iTrader: 14 reviews
yeah they are still making them and you can still get them... cant think of the shop he is at now though. Itll be just a sec and somebody will post it.
4.75 MMR 900se
HP 292s blower cams
IW 15% OD pulley
(and more bolt ons)
E85
Old November 20th, 2010, 09:39 PM   #7
bobz18711's Avatar
2001 Mustang GT
TBD
Thanks for the help, also about the octane issue, with 10psi and a set of cams, would I need to run higher than 93??
Old November 20th, 2010, 09:40 PM   #8
BYAHHHH!
2001 Mustang GT
13.874
you dont have to...ever thought about e85?
Old November 20th, 2010, 09:40 PM   #9
BakerFX4's Avatar
iTrader: 14 reviews
nah
4.75 MMR 900se
HP 292s blower cams
IW 15% OD pulley
(and more bolt ons)
E85
Old November 20th, 2010, 09:42 PM   #10
tbirdscwd's Avatar
12.88 @ 109.45 N/A
tbirdscwd is a name known to alltbirdscwd is a name known to alltbirdscwd is a name known to alltbirdscwd is a name known to alltbirdscwd is a name known to alltbirdscwd is a name known to all
iTrader: -1 reviews
I agree with baker that cams would be more of an improvement on your setup than adding a set of heads.
Call Tim at Mr. Norm's Garage for a set of his custom KB cams
Fun: 2004 Mustang GT
DD: 1994 Ram 2500 Cummins 4x4
Borla "Stinger" Exhaust Vids
Old November 20th, 2010, 09:42 PM   #11
bobz18711's Avatar
2001 Mustang GT
TBD
I live in Kentucky, and have not seen any E85 pumps around, so I don't know about that whole situation??
Old November 20th, 2010, 09:43 PM   #12
BakerFX4's Avatar
iTrader: 14 reviews
do a search on e85 and your city and you might have it. I didnt know it but my city does after i did a search.
4.75 MMR 900se
HP 292s blower cams
IW 15% OD pulley
(and more bolt ons)
E85
Old November 20th, 2010, 09:44 PM   #13
stal94gt's Avatar
2003 mustang v6 ;)
slow
if your tuner is any good you can run more boost with out an issue, he has to be sure to check the plugs after each pull to make sure the timing mark does not pass the 90 degree on the strap. i dont know where he gets off saying 10# is the limit, he can always back off the timing a hair to keep it safe. im not sure what cr you plan on running but im running 18# pump gas+meth on 9.5 cr just fine. off the meth the timing holds fine at 15 degrees
Old November 20th, 2010, 09:47 PM   #14
BakerFX4's Avatar
iTrader: 14 reviews
bet this is 93 octane....
4.75 MMR 900se
HP 292s blower cams
IW 15% OD pulley
(and more bolt ons)
E85
Old November 20th, 2010, 10:01 PM   #15
bobz18711's Avatar
2001 Mustang GT
TBD
Well I guess I will finish my performance with a good set of Cams, going to 10 psi, adding my 90mm MAF, 75 mm TB, JLT intake, Stainless steel springs. Anything else I might need as far as the cams go??
Old November 20th, 2010, 10:03 PM   #16
BakerFX4's Avatar
iTrader: 14 reviews
springs....
EDIT... you might can get away with them. You will have to talk to Tim on that. Reason i say might not have to is because the KB isnt a "higher rpm blower" like a centri so you shouldnt have to rev it out as much. Hell i dunno/
4.75 MMR 900se
HP 292s blower cams
IW 15% OD pulley
(and more bolt ons)
E85
Old November 20th, 2010, 10:07 PM   #17
bobz18711's Avatar
2001 Mustang GT
TBD
springs....
Thanks, I will find out from him on that one, just need to find out how to get ahold of them...
Old November 20th, 2010, 10:07 PM   #18
stal94gt's Avatar
2003 mustang v6 ;)
slow
as far as building a good set of heads rated to hold down boost i would go with a good set of high load springs just in case you plan on turning up the boost. also replace the valve seals, BRONZE GUIDES! timeserts, titanium locks and retainers.
Old November 20th, 2010, 10:08 PM   #19
BakerFX4's Avatar
iTrader: 14 reviews
he is now at MR. NORMS GARAGE
4.75 MMR 900se
HP 292s blower cams
IW 15% OD pulley
(and more bolt ons)
E85
Old November 20th, 2010, 10:08 PM   #20
tbirdscwd's Avatar
12.88 @ 109.45 N/A
iTrader: -1 reviews
springs....
I agree that Tim would be the guy to talk to about whether or not his KB grind requires aftermarket springs.
Threads Similar to: Heads vs Cams on PD blower
2v blower cams mustanginky 99-04 8 June 9th, 2010 11:00 PM
Edelbrock Blower on a Stock Block: heads/cams OK? Feshdogg 2005 - 2010 12 May 30th, 2010 10:09 PM
Stage 3 heads/blower cams? jivepepper 99-04 4 April 29th, 2008 02:25 PM
vt heads and blower cams sonicblue 99-04 6 December 12th, 2006 03:14 PM
