CC pistons
Old April 11th, 2007, 07:41 PM   #1
barksdaleammo is on a distinguished road
CC pistons
ok, What pistons should i get if i want to run about 15 psi from a blower. im looking at the 17cc forged kit on VT. Im building another motor for my mustang on paper to see how much i need to save. still trying to go to korea and save some money. ive given up on the nitrous set up and decided to go blown procharger the dcs-1 and roush stage 3 clone. so which pistons do i need to get.
Old April 11th, 2007, 07:42 PM   #2
also if i get the aluminum 4.6 from brothers can i build it like a 4v or do i need to get the iron blocks from them.
Old April 11th, 2007, 07:48 PM   #3
last question...how much of a difference between the patriot stage 2 heads and the patriot Stage 3 heads same thing with cams.
Old April 11th, 2007, 07:49 PM   #4
03 Mustang GT Twin Turbo
10.43 @ 139mph
WAVEBYE is on a distinguished road
Send a message via AIM to WAVEBYE
what kinda power are you looking to make? i would stay away from patriot heads btw.
Nobody gonna take my car
Im gonna race it to the ground
Nobody gonna beat my car
Its gonna break the speed of sound
Oooh its a killing machine
Its got everything
Like a driving power big fat tires
And everything - Deep Purple
Old April 11th, 2007, 07:52 PM   #5
id like to have the most power i can and still be a daily driver. probably around 500-600. yes im serious. is this possible.
Old April 11th, 2007, 08:01 PM   #6
10.43 @ 139mph
then i would get a alum. block. preferably one out of a '01 cobra and a tubular K-member. that should free up about a 100lbs or more off the car.
You can put any 4.6L heads you want on there 4v or 2v depending on your preference. FoxLake makes really good heads but their turnover is really slow,but they do make some badass heads.
what kind of money are you wanting to spend?
Its got everything
Old April 11th, 2007, 08:13 PM   #7
right not if i save right while im over there i can get around 12,000 saved up. i know thats not enough but it should be a good start. my plan is the get the bolt ons and such and then start building a motor in my garage. ill do most of the maintence myself. ive been building old chevy motors since before i can remember this is the first time ive ever messed with a ford let alone a Fuel Injected motor. but i can put 4v heads on a motor and that will make a 4v right. ive read on here that the bolt pattern on the heads is different so i need to get a 4v block? right?
Old April 11th, 2007, 11:26 PM   #8
Im planning on useing the fox lake stage 2 and VT stage 3 blower cams. thanks for those sites now if i could just figure out about the rotating assembly.
Old April 11th, 2007, 11:31 PM   #9
Proud American
MustangMatt96GT's Avatar
You will need to drill some different holes on the aluminum block that is a 2V to make it a 4V and I think it would be much easier and cheaper to get an aluminum block that is 4V! VT makes a nice stroker kit as does livernois!
RIP Travis Billings
Special Thanks to:
Andrews Racing Transmissions
Baseline Suspensions
25.3 SFI Chassis Build
Never Lift Racecars
Old April 12th, 2007, 12:14 AM   #10
10.43 @ 139mph
LOL!! no you won't dude. hahah
i've got a 01 cobra aluminum block and a cobra crank with 2v FoxLake Stage 2 heads on it. that's what modular means,it means they're interchangeable.
i think a built 2v 4.6 would probably run you about $6000 if you do the work yourself. that leaves another 6 grand for a poweradder. if you have 12k to spend you could probably wind up with a TT on a built motor puttin down around 625rwhp for maybe little more than $13,000 and probably in the mid to high 10's
but you also gotta factor in cost of upgrading the driveline and brake system. and possibly a cage.
what state do you live in?
Its got everything
Old April 12th, 2007, 12:23 AM   #11
Proud American
Waveby! arent there certain holes different on a 2V block than a 4V block because of the different timing chain covers and set ups like that! I could be wrong and if I am please explain as I would like to learn!
RIP Travis Billings
Special Thanks to:
Never Lift Racecars
Old April 12th, 2007, 07:24 AM   #12
mm's nitrous mod
SWEET2KSTANG's Avatar
2000 mustang gt
11.79@115.83 (old set up)
iTrader: 8 reviews
my advise, a good forged kit from a reputable company, vt stg. 2 heads, custom grind cams, aftermarket intake manifold of your choice, procharger (personal opinion), upgraded fuel rails, and a return style fuel system. maybe an intercooler spray set up, or a 50 shot for a little more umph. clutch and trans upgrade a must, i posted pics of my trans on here showing what happened on my car with what i have. a 31 spline rear end set up will be needed as well. if you plan on going to the track, you will have to get neseccary safety equipment to run. once you start getting all that power, you will still have a lot left to do.
Old April 12th, 2007, 08:21 AM   #13
Ill build the rear-end first with 31-spline t-loc and 3.73 gears since itll be SC. Im going to build off of a procharger D-1 with fox lake stage 2 heads and vt stage 3 blower cams. P-51 intake and BBK Long Tubes and Mid Pipe and bassani cat-back. Thats basically what i got but now im stuck on what rotating assembly to use. i looked on VT but all them have different cc pistons. now when i used to build chevy motors they tell you the compression ratio for the pisons. im wanting about 9:1 compression. ill be running around 16 psi. also im looking at the k member from AJE. but i cant find which one to get and other than the k member what do i need to get for the front end like a arms and such.
Old April 12th, 2007, 08:41 AM   #14
bransdaman78 is on a distinguished road
you can build your 2v for around 3k-4k, 6k with new heads.... get a stroker kit with 18cc dished pistons, bored .020 over.... that will make for a torquey motor that can take what ever power adder and pump gas you can throw at it.
03 GT leather seats for sale or trade for racing seats,
Looking to buy: subframes, tower braces, control arms, bypass/BOV, 42# injectors & MAF
Trade/ Sell Predator 4 SCT (wrong part of the country)
Old April 12th, 2007, 08:46 AM   #15
i figured up about 8000 for all that i want. motor wise. altogether the cost is going to be about 15000 for all that i want including suspension and rear-end. i can do everything but the rear-end and the tuning.
Old April 12th, 2007, 10:32 AM   #16
MM's Mad Scientist
acmillr's Avatar
Slow Fella
acmillr is a splendid one to beholdacmillr is a splendid one to beholdacmillr is a splendid one to beholdacmillr is a splendid one to beholdacmillr is a splendid one to beholdacmillr is a splendid one to behold
Correct, but they are talking about an aluminum 4V block that already has everything that is needed. If you bolt on 2V heads, you just want use a couple of the threaded holes.
Old April 12th, 2007, 11:09 AM   #17
where can i get a aluminum 4v block. what year cobra am i looking for. BTW
I GOT ORDERS TO KOREA!!!!!!!!!!!!!!!!!!!!!!!!!!!!!
Ill report there in november of this year and be there for a year. ill be able to set aside a lil over 1000 a month for the mustang. Im getting D-1SC procharger and 3.73 gears and 75 mm throttle body and plenum and OMG This is going to be awesome. Look for me to have a BADASS mustang around jan of 09. plus ill get my tax return around that time which will help out some more too. Damn i cant wait.
Old April 14th, 2007, 06:12 PM   #18
does anyone know where i can get the aluminum 4v block.
Threads Similar to: CC pistons
Pistons Micro Ford 2005 - 2010 2 October 11th, 2007 10:08 PM
pistons mmvi V6 Mustangs 32 September 2nd, 2007 09:18 PM
pistons notsoslow50 5.0 Mustangs 2 August 22nd, 2007 11:30 AM
Pistons kmjsmith 2005 - 2010 0 May 29th, 2007 01:38 PM
pistons on an 88 5.0 ddashtrois 5.0 Mustangs 3 April 23rd, 2007 09:26 AM
