MM's Taint Shaver!
2003 Mustang GT
Hood Pins
Just wondering if anyone can give me any feedback on these hoodpins. I want a set of the regular hood pins with the clips but I already know someone would keep pulling them out and piss me off so i'm just gonna eliminate that problem by getting locking ones. Do these look like a decent set? Thanks!
2004 mustang GT
the problems i see with these are with the locks facing up like that, they will not only collect dirt and function poorly, but will collect water and will eventually rust and "freeze" up. another thing is that installation will be more tedious, your pin height will have to be dead on. unless you know for certain someone will mess with them, i don't think they will get jacked with, mine never do. put some lanyards on the pins and just deal with the very rare putting the pin back in. it's just jealous LS guys
#3 | |
MM's Taint Shaver!
2003 Mustang GT
Abyssinian of AX
'02 Saleen
19.34@42.259
Justa is straight up correct on this one
![]() Years and YEARS ago, I had made my own alarm system on my Vega and had MAJOR issues with water in the lock (mounted on the fender) I had to put WD-40 in there constantly to get rid of the rust and for it to function. As for which hood pins to buy... ? I would NOT go anything but FRPP They are all SS and wont rust. I have had them on my ride for several years now and holding up great:![]() ![]() I decided to install some nylon washers between the pins and hood plate to avoid scratches and works wonderfully ![]() Jazzer ![]() PS. Have more pics for installation location, so PM if needed
jazzer, i have the same style of pins as you do, but I didnt get the FRPP ones. do your pins slide to one side of the pin? in the pic you posted the pin is centered... is that the scuff plate holding it? or do you just center it by hand all the freaking time...
![]() 02GT - Blown motor 86LX 3.8TBI auto replacement daily driver How to retrofit HID's |
Abyssinian of AX
'02 Saleen
19.34@42.259
I have the pins low enough that the upward pressure from the hood holds them tight. It helps that I have a cheap hood that is bent up on the sides and the pins hold it down
This is actually the reason I ended up getting pins in the FIRST place ![]() The nylon washers add a bit of friction and keep them from scratching, so all is good. Jazzer
#7 | |
MM's Taint Shaver!
2003 Mustang GT
Abyssinian of AX
'02 Saleen
19.34@42.259
Excellent
![]() Please "save-as" these images if you think you may want them, as I need to remove them from my Photobucket account to thin it out a bit. I will delete them by tomorrow morning ![]() Jazzer ![]() PS. YW
2003 Mustang GT
and it looks sweet
2004 4R75W Mustang GT
13.179 @ 104.30
I have the hood locks and just be warned they are a motherF'r to install and to get lined up, other then that they look good with dirt and rust not being an issue as my car get parked in the garage, I dont know how they would far being out doors all the time but my guess is they would not last, if I had to do it again I'd get the pins !
...Mods in garage
on our racecar we use these. they dont rust but its not normally left in the rain either tho. and ours are chrome
![]() Check out our race team! http://www.facebook.com/media/set/?s...3927011?v=wall American Iron Mustang- ^1.6 lateral gs 03 Steeda 1.2 lateral Gs-ra1 08 Gt |
I think you will be much happier with a traditional set of hood pins. The locking ones tend to be a but pain sometimes.
Threads Similar to: Hood Pins
| Aftermarket fiberglass hood. Hood pins or factory hood latch??? | Saleen0101 | Modular Mustangs | 11 | November 9th, 2011 04:09 PM |
| hood latch keeps failing... other alternative than hood pins? | R3dFyre02 | 99-04 | 2 | June 12th, 2010 04:41 PM |
| Drake Hood Pins/Trufiber GTS Hood | Monochrome '05 | 2005 - 2010 | 39 | December 3rd, 2009 11:20 PM |
| Hood Pins install in outer hood stops? | krispyrob | 2005 - 2010 | 61 | September 27th, 2009 11:13 PM |
