Why does my car take so dam long to warm up???? - Forums at Modded Mustangs
post #1 of 19 Old December 5th, 2010, 04:07 AM Thread Starter
I Have A FLATULENT Butthole.
(Kohrs93)'s Avatar
I've noticed since it started getting cold that my car takes FOREVER to warm up (the engine not the heat). I drove about 20 miles today (let the car idle for about 5 mins before i started dirivng) and when i go home it was only about 1/8 of the way up on the temp guage. Why would it be taking so long to warm up??? I have a feeling its the reason i'm getting such crap gas mileage...
Black Stang Crew #Coorslight
BONER CREW EMPLOYEE #3 - RECEIVING DEPARTMENT
[CUMYUM!]
i like pee pees i guess too
(Kohrs93) is offline
post #2 of 19 Old December 5th, 2010, 04:15 AM
moneygreenstang's Avatar
thermostat
01 GT Vert - Triple Black - 2v 5.4 270/340
00 Lightning - Triple Black - 2v SC 5.4 400/500
Brand New Tubular UCA and LCA set for sale PM me
Slightly Used 05-09 Halo Headlights for sale PM me
moneygreenstang is offline
post #3 of 19 Old December 5th, 2010, 04:18 AM
stal94gt's Avatar
the prior owner probably put in a 160 degree thurmostat thinking it would net him some hp. or the one that is in there is bad and it does not close (fail safe brand does this)
stal94gt is offline
post #4 of 19 Old December 5th, 2010, 04:29 AM
bigjohnstud4200's Avatar
+1
Tuned by Joe@TrickTuners
CMS Stage 1 Cams, 4.10 Gears, TrickFlow 70mm TB & Plenum, MAC Prochamber with Pypes M80's, MGW Shifter, Custom Paint, Cobra Cloth Top, Staggered Chrome 18" Saleen's and Sequential Tails.
bigjohnstud4200 is offline
post #5 of 19 Old December 5th, 2010, 03:10 PM Thread Starter
(Kohrs93)'s Avatar
How much does it cost for a new one? And how easy is the install?
[CUMYUM!]
post #6 of 19 Old December 5th, 2010, 03:13 PM
0949er's Avatar
^^ not sure on price, install is easy, as long as you got a non-plastic crossover. If you got a plastic one, make sure not to crack it :-p
MODS:
Vortech V1 T-Trim @ 7.5 PSI (tuned down)
Comp Cams XE270-AH
+ See Garage
432 rwhp / 396 rwtq 02/27/2011
NEW VIDEOS!
**It takes ~$60 a rwhp (over stock) for a 99-04 Mustang GT.** Do the Math
PLANS ON HOLD
0949er is offline
post #7 of 19 Old December 5th, 2010, 05:15 PM Thread Starter
(Kohrs93)'s Avatar
I replaced it and it seems to have helped Thanks guys, hopefully this at least helps my bad mpg problem
[CUMYUM!]
post #8 of 19 Old December 5th, 2010, 05:18 PM
T-Lee. 30's Avatar
Send a message via Yahoo to T-Lee. 30
have the same problem it takes like +15min for the car to get up to temp and not just on cold days.
T-Lee. 30 is offline
post #9 of 19 Old December 5th, 2010, 05:21 PM Thread Starter
(Kohrs93)'s Avatar
Try replacing your thermostat like i just did. Took me literally 15 mins if that, and I got the medium grade 195* replacement. With the gasket and the thermostat it was like 19 bucks
[CUMYUM!]
post #10 of 19 Old December 5th, 2010, 05:23 PM
T-Lee. 30's Avatar
gotcha! will have to do that. Is that any parts store or a particular one?
post #11 of 19 Old December 5th, 2010, 06:43 PM
Willy Mo's Avatar
the new thermostat will definately help your fuel mileage.
Willy Mo is offline
post #12 of 19 Old December 5th, 2010, 06:49 PM
any part store I got a 180* for 12.99 from summit racing.. re used the old O-Ring it was in good shape took 15 minutes like the OP said
post #13 of 19 Old December 5th, 2010, 06:55 PM
try a coolant flush too when you do it
DsmDave is offline
post #14 of 19 Old December 5th, 2010, 08:26 PM
T-Lee. 30's Avatar
how will the new thermostat help the fuel mileage? not being a smart ass im seriously asking.
post #15 of 19 Old December 5th, 2010, 08:27 PM
engine temp affects the way a car runs, being at optimal tempeture will help the motor be at a optimal power zone. temp=timing
DsmDave is offline
post #16 of 19 Old December 5th, 2010, 08:37 PM
T-Lee. 30's Avatar
oh ok I gotcha I may def want to get that fixed then. That want grenade my engine with the blower will it
post #17 of 19 Old December 5th, 2010, 08:40 PM
in the beginning the timing cause cause your tune to be off, a car is tuned to a certain temperature, if your not a that temp then it could hurt the performance.
DsmDave is offline
post #18 of 19 Old December 5th, 2010, 09:22 PM
T-Lee. 30's Avatar
oh damn. gotcha I need to get on that then. thanks for that
post #19 of 19 Old December 5th, 2010, 09:25 PM
not a problem
DsmDave is offline
Human Verification
