well my ceramic flowtechs showed up....and - Page 3
Old December 13th, 2010, 02:05 PM   #41
2004 mustang gt
40thgtvert is on a distinguished road
Originally Posted by wrecked2001 View Post
I had to clean mines up, but the flange was straight. You get what you pay for, so I was prepared for some prep work. You definitely need a good gasket to make up for it. With all that said the Ceramic coating was great. Also only leaks I have had were at the slip joint. I reinstalled them on my new motor, with stage 8 bolts, Percy's Gaskets and bronze RTV at the slip joint with a band clamp. No problems at 3000 miles!
well i got the stage 8 locking bolts, the better gaskets from summit and some copper rtv..but what is the deal with the band clamp, and you only used 1..? there are two slip fits on the headers..also what other type of cleaning up on them did you have to do
Old December 13th, 2010, 06:40 PM   #42
PowerShiftz02GT is just really nicePowerShiftz02GT is just really nicePowerShiftz02GT is just really nicePowerShiftz02GT is just really nicePowerShiftz02GT is just really nice
iTrader: 13 reviews
where did you get a band clamp that fits the Slipfit?
Old December 13th, 2010, 11:38 PM   #43
2004 mustang gt
yea im wondering the same thing..also im assuming you would need two band clamops instead of one
Old December 14th, 2010, 04:31 AM   #44
wrecked2001 is on a distinguished road
I just used one around the two. With the RTV the clamp just compresses the two. Because the gap is so tight on my set the clamp compresses the outsides, while the two inside areas of the slip fit compress against each other. I think the reason it works is that the clamp keeps the slipfit from vibrating, keeping it tight so the RTV can stay sealed. I can't remeber what part number I used, but there was a write up on one of the forums sometime ago. I ordered mine about 5 yrs ago and summit dosen't track that far back. The best way would be to slot the female end of the slip fit with a dremmel, and then use two band clamps, one for each. Currently though mines are not leaking!
Old December 14th, 2010, 08:56 AM   #45
iTrader: 13 reviews
interesting. do you think you could get a quick picture? doesn't have to be detailed just a general picture of the slip fit with the clamps around it.
Old December 14th, 2010, 06:50 PM   #46
2004 mustang gt
yea i woul lik to see a picture as well please...not sure what type of band clamp you used or where you even found one big enough to go around both pipes?
Old December 16th, 2010, 10:10 AM   #47
I will get a Pic up today
Old December 16th, 2010, 10:23 AM   #48
Bringing Yellow Back
zinc-vert02's Avatar
2002 mustang gt
12.2 at 117
zinc-vert02 is a splendid one to beholdzinc-vert02 is a splendid one to beholdzinc-vert02 is a splendid one to beholdzinc-vert02 is a splendid one to beholdzinc-vert02 is a splendid one to beholdzinc-vert02 is a splendid one to beholdzinc-vert02 is a splendid one to behold
Send a message via MSN to zinc-vert02
im going with flow techs
SOON TO BE 5.4 3V POWERD WITH A ROUSH CHARGER HELPING IT
BAMA Performance Drag Team Member #4
Old December 16th, 2010, 11:10 AM   #49
Blk01ponyGT's Avatar
2004 SVT Cobra
Blk01ponyGT is on a distinguished road
you get what you pay for i guess, flowtechs are cheap for a reason. this is why eventho im broke im still saving up to get the best headers for my car.
Garage: http://www.moddedmustangs.com/forums...e-member-9480/
04 Cobra - STOCK for now
Old December 16th, 2010, 11:14 AM   #50
2002 mustang gt
12.2 at 117
fl8 HAS ran them for years with zero problems
Old December 16th, 2010, 11:30 AM   #51
slo3gt is infamous around these partsslo3gt is infamous around these partsslo3gt is infamous around these partsslo3gt is infamous around these partsslo3gt is infamous around these partsslo3gt is infamous around these partsslo3gt is infamous around these partsslo3gt is infamous around these partsslo3gt is infamous around these partsslo3gt is infamous around these partsslo3gt is infamous around these parts
Perfect example of why mine has BBK ceramic Lts
Old December 16th, 2010, 11:54 AM   #52
86er's Avatar
lol, those are right there with the cheap headers, if the trans ever has to come out, the passenger side header HAS to be all but removed.
Just a truck
Old December 16th, 2010, 01:41 PM   #53
iTrader: 13 reviews
+1
BBk headers are like 50.00 more...
Threads Similar to: well my ceramic flowtechs showed up....and
Well, one DR showed up today 07 Boss 2005 - 2010 30 December 10th, 2010 01:24 AM
Rest of the parts showed up F8L GT 99-04 14 February 23rd, 2010 01:33 AM
new suspension showed up today xtremes10 2005 - 2010 14 January 30th, 2010 08:15 AM
Which one showed up today?? homebrewed The Clubhouse 0 October 14th, 2007 02:29 PM
