Mustang wont start in cold?????? - Forums at Modded Mustangs
post #1 of 7 Old December 14th, 2010, 08:35 PM Thread Starter
5.4mustang gt's Avatar
i got a problem goin on. i parked my car friday n havent tried to start it until this past sunday wen all this bad weather hit. wen i went to start it it turns over for like 2 sec then clicks. i replaced starter n battery n still no solution. is it possible that the oil is too thick cuz of the freezing temps to start????? any suggestions thanks
5.4mustang gt is offline
post #2 of 7 Old December 14th, 2010, 09:20 PM
P1SCstangGT's Avatar
make sure the car has fuel pressure
2002 gt PROCHARGED 9psi
P1SCstangGT is offline
post #3 of 7 Old December 14th, 2010, 09:32 PM
I don't see it being the oil. How does the car run when you do get it started?
Myslowstang is offline
post #4 of 7 Old December 14th, 2010, 09:35 PM
BakerFX4's Avatar
iTrader: 15 reviews
shoulduh ballwt uh chevy.
Im calling BS on replacing the battery with a NEW one. It would turnover consistently if the battery was hot and not do that ruummm rummm click click click.
4.75 MMR 900se
Livernois ported heads
HP 292s blower cams
Procharger D1sc at 20+ psi
IW 15% OD pulley
(and more bolt ons)
E85
Tune/numbers coming shortly!!
BakerFX4 is offline
post #5 of 7 Old December 14th, 2010, 09:39 PM
It's in the details Mod!
M.P. Cobra Fan's Avatar
Your symptoms sound like a battery. Are you sure it is a new one you replaced it with. Oil, especially the viscosity that we use in our motor, has to be VERY cold to get thick enough to cause a sluggish start like that.
Pinup in signature by loish.net
Modded Mustangs Cobra Club#007
Military Crew E6
VOTED MM's BEST SIGNATURE 2010. THANKS STANGGTR07
M.P. Cobra Fan is offline
post #6 of 7 Old December 14th, 2010, 10:49 PM Thread Starter
well ive replaced the batt n yea good point it would have to get really cold for the oil to do that in our cars. i think wat happened was the coolant froze n the water pump fans locked up cuz of the coolant freezing so im currently heatin the motor up n ill check it out in the morning.....
post #7 of 7 Old December 14th, 2010, 11:05 PM
bigjohnstud4200's Avatar
If you have your coolant mixed properly, it would take like -50 to freeze it.. i don't think you're coolant is frozen unless you have zero coolant and all water. I would keep looking at that battery.. how many volts does it read right now? How many cold cranking amps is it rated at?
Tuned by Joe@TrickTuners
CMS Stage 1 Cams, 4.10 Gears, TrickFlow 70mm TB & Plenum, MAC Prochamber with Pypes M80's, MGW Shifter, Custom Paint, Cobra Cloth Top, Staggered Chrome 18" Saleen's and Sequential Tails.
bigjohnstud4200 is offline
Human Verification
LinkBack to this Thread: http://www.moddedmustangs.com/forums/99-04/195944-mustang-wont-start-cold.html
99 4.6 will not start if its <40 degrees outside - Ford Mustang Forums This thread Refback March 3rd, 2013 04:04 AM
