Borla Exhaust Install. Left (done). Right(need help)
Old December 15th, 2010, 04:43 AM   #1
bebo109 is on a distinguished road
So check this out... I started to install my Borla Exhaust system today. I was able to install the left one in about 3 hours (its hard doing this without being able to lift your car that high; cutting with a small jacksaw and trrying to get the right angles). Greate so left one is done.
I was able to cut off the right side much easier this time (it was a breeze after figuring out where the right spot to cut was lol). Heres the hard part. I cant get the new exhaust over the right axle. There is a little "nipple?" on the top of it which is making it impossible for me to do. I included pics(from google) to show what i mean. (A) is left, (B) is right...
Any pionters on how to get this done would be greatly appreciated. I'm skipping work tomorrow since i cant get there with my car like this.
Maybe any pointers on how to lift my car higher safely? I started with 2 jacks in the back, but my car swayed and i almost pinned myself between my car, and another (Good lesson to learn). So i was only lifting one side at a time. Maybe i just dont have the right equipment huh?
Anyway, any help would be GREATLY APPRECIATED.
Old December 15th, 2010, 05:59 AM   #2
R3dFyre02's Avatar
R3dFyre02 has a spectacular aura aboutR3dFyre02 has a spectacular aura aboutR3dFyre02 has a spectacular aura about
JACKSTANDS!!! Dont EVER go under your car with it only on jacks!!!! yea, it might be just for a second, bt its not worth the risk. I have seen jacks fail and missed getting killed myself once when my car fell just as I got out from under it. jackstands arent that expensive, and are a MUST when working under the car.
as to your nipple issue... have you tried rubbing it to make it stand up? oh wait, wrong conversation...
seriously, if it is just the nipple holding up your install, have you looked into just taking it off temporarily? should just spin off with a smallish wrench. then put it back on once you get the exhaust on.
02GT - Blown motor
86LX 3.8TBI auto replacement daily driver
How to retrofit HID's
Old December 16th, 2010, 12:18 AM   #3
gdl
99 Cobra, 03 Mach1, 07 CS
gdl has a spectacular aura aboutgdl has a spectacular aura about
Seconding, get yourself some jackstands! Do NOT go under there with just a jack holding it up.
Question for you, where were you putting the jacks? Hopefully not under the axle itself. Once you have the jackstands, jack the car way up and then put the stands under the subframe near where the control arms attach to the body of the car. That way when you let the jacks back down the axle will droop and will give you more clearance.
2007 Redfire California Special
http://i183.photobucket.com/albums/x...n/2007GTCS.jpg
2003 Dark Shadow Grey Mach 1
http://i183.photobucket.com/albums/x...born/Mach1.jpg
1999 Black Cobra Vert
Old December 16th, 2010, 12:24 AM   #4
Blk01ponyGT's Avatar
2004 SVT Cobra
Blk01ponyGT is on a distinguished road
+1. if you drop the axle you should be able to get it over no problem. ive always done my exhaust installs this way. and yes you MUST get jack stands dude. so dangerous to not have them. im always skeptical to work under my car even with jack stands lol
Garage: http://www.moddedmustangs.com/forums...e-member-9480/
04 Cobra - STOCK for now
Old December 16th, 2010, 12:25 AM   #5
MikeJones's Avatar
13.7@103
MikeJones is just really niceMikeJones is just really niceMikeJones is just really niceMikeJones is just really niceMikeJones is just really nice
Jack it up from the rear subframe or something metal. Let your axle drop down. Much easier.
Mod6
Bigbore
Kooks
(parting out 2v motor)
Old December 16th, 2010, 12:25 AM   #6
Shaun03GT's Avatar
2003 Mustang GT
Shaun03GT has a brilliant futureShaun03GT has a brilliant futureShaun03GT has a brilliant futureShaun03GT has a brilliant futureShaun03GT has a brilliant futureShaun03GT has a brilliant futureShaun03GT has a brilliant futureShaun03GT has a brilliant futureShaun03GT has a brilliant futureShaun03GT has a brilliant futureShaun03GT has a brilliant future
iTrader: 12 reviews
I had that problem with my Magnaflows, while the car is on jackstands/ramps, I jacked up right behind the gastank and rear bumper. Took a piece of wood, jacked it up there to lift the car alittle and I got that piece over the axle. Hope that helps man
Vortech V1 Intercooled @ 11psi
394rwhp/392rwtq @ 9.5psi
415rwhp/400rwtq @ 11psi on Methanol
Tuned By: Pete @ Performance Dyno
Affordable Supercharger Build Guide
Supercharger Info for Noobs
Old December 16th, 2010, 12:34 AM   #7
2001 Bullitt
12.25@110.4
Bullitt5339 is a glorious beacon of lightBullitt5339 is a glorious beacon of lightBullitt5339 is a glorious beacon of lightBullitt5339 is a glorious beacon of lightBullitt5339 is a glorious beacon of lightBullitt5339 is a glorious beacon of light
I did my Borla exhaust on a drive-on lift, with weight on the suspension, started from the back forward, and it slid right in, no problems.
Old December 16th, 2010, 03:47 AM   #8
12.84@108
04N20GT will become famous soon enough
Just did my Borla exhaust. Need a set of jack stands for sure. Lift the car by the axel, set the jack stands under the subframe, then let the jack back down, thus letting the axel down, then slide the axle part in from an angle and massage it into place. Trust me, it will go. then just connect all the band clamps and you are done.
Enjoy the best EXHAUST for these cars.... IMHO
MMR 950 Stroker
TFS 38cc Heads
MHS TFS N/A stage 3.5 cams
11.5:1 compression
Nitrous Express wet kit
12.84@108 2.0 60' on motor. race weight was 3750lb
354whp 330wtq motor, 480whp 500wtq 150shot.
Proud Iraq and Afghanistan Vet
Threads Similar to: Borla Exhaust Install. Left (done). Right(need help)
Finished the Borla install 04N20GT 99-04 4 November 25th, 2010 07:53 PM
Front pads install : the 'spring' left the pad :( registo 2005 - 2010 2 June 30th, 2009 06:19 PM
Borla Ford Mustang Exhaust System, Borla 11752 $558 Shipped candycane184 V6 Mustangs 16 December 12th, 2007 12:27 PM
Stock exhaust, borla stingers, borla w/ O/R h pipe 06GTMustang89 Videos 1 October 10th, 2007 05:58 PM
