Intake manifold...I need a new one
Old December 15th, 2010, 10:42 AM   #1
slo3gt is infamous around these partsslo3gt is infamous around these partsslo3gt is infamous around these partsslo3gt is infamous around these partsslo3gt is infamous around these partsslo3gt is infamous around these partsslo3gt is infamous around these partsslo3gt is infamous around these partsslo3gt is infamous around these partsslo3gt is infamous around these partsslo3gt is infamous around these parts
Short run down. 03 2v, PP heads,cams,injectors,bolt ons,etc. NA the car ran a best of 12.2.
I need a new intake. Mine keeps leaking coolant. Here are my options.
1.stock PI
2. Aluminum Typhoon 3 piece from PP with current tb.
3. Edelbrock Victor Jr with adapter to use current accufab plenum and tb.
4. Edelbrock Victor Jr with aluminum elbow from MMR and current TB.
On the dyno,car makes good power up to around 6600. Tuner said the intake was the bottleneck. So if you have any experience,good or bad,with these setups,please share.
Old December 15th, 2010, 10:43 AM   #2
Forgot,no boost in my future. But when I replace the intake,on goes the nitrous and a new tune.
Old December 15th, 2010, 10:44 AM   #3
stal94gt's Avatar
2003 mustang v6 ;)
slow
stal94gt has much to be proud ofstal94gt has much to be proud ofstal94gt has much to be proud ofstal94gt has much to be proud ofstal94gt has much to be proud ofstal94gt has much to be proud ofstal94gt has much to be proud ofstal94gt has much to be proud ofstal94gt has much to be proud of
i have the tfs intake mani, has a little low end loss but brings it back in the big end. works even better now with fi
Old December 15th, 2010, 10:46 AM   #4
bigjohnstud4200's Avatar
2000 GT 'vert
bigjohnstud4200 has a spectacular aura aboutbigjohnstud4200 has a spectacular aura aboutbigjohnstud4200 has a spectacular aura about
From what I understand, the stock intake is plenty for NA cars.
"...but don't say my car's topless, say the titties is out"
Nas
Originally Posted by thrashersonmomma09 View Post
( member as in person not as in cock although i do love cock)
Old December 15th, 2010, 10:46 AM   #5
stal94gt's Avatar
2003 mustang v6 ;)
slow
btw the typhoon is junk, dont run it, there is a couple of people who have it that swear its the best but do your self the favor and stay away from it. also for less money and be able to use your stock plenum is the hps hard baller intake which looks stock but flows nice and also brings it at the big end
Old December 15th, 2010, 10:48 AM   #6
stal94gt's Avatar
2003 mustang v6 ;)
slow
its plenty for a stock sb motor but it sounds to me this guy is trying to push 7k, which i agree its then a problem. not a big one and you may not see a hole lot of gain na from it, but a little juice will fix it. btw the eddie is a nice manifold as well, never ran it and i dont know to many na guys using it so i cant chime in on it.
Old December 15th, 2010, 10:50 AM   #7
stal94gt's Avatar
2003 mustang v6 ;)
slow
the mmr elbow for the eddie intake is expensive, go with the 6061 intake for it.
Old December 15th, 2010, 10:55 AM   #8
Do you have a link for this elbow? I've looked and can't seem to find it.
And to the above post,I'm planning on pushing it past 7k. Probably 7200.
Old December 15th, 2010, 10:59 AM   #9
stal94gt's Avatar
2003 mustang v6 ;)
slow
i want to say they are 250 dollars or so
http://www.6061.com/elbows.htm
Old December 15th, 2010, 11:00 AM   #10
fmxona500's Avatar
1996 Mustang
I take myself way too seriously.
fmxona500 will become famous soon enough
6061.com 6061 IntakeElbows.com intake elbow elbows valve covers ls1 lsx mustang camaro fuel rials injector bungs efi conversion aluminum fabrication 6061 6061.com edelbrock fuel rails 4150 dominator lsx injector bungs 90mm 105mm throttle body Aaron L
Old December 15th, 2010, 11:13 AM   #11
stal94gt's Avatar
2003 mustang v6 ;)
slow
honesly for a na car i would shoot for a manifold that is more setup for na app. the hps and tfs manifolds both have tapered runners which help with velocity and you wont loose so much bottom end. they both are shorter runners which helps with top end. flow wise they both put out what you need for your motor and i think you would net better results with them. but it sounds like you have your heart set on the eddie and it is a good manifold as well.
Old December 15th, 2010, 11:18 AM   #12
I8ACMRO's Avatar
2003 Mustang GT
14.03@100
I8ACMRO has a spectacular aura aboutI8ACMRO has a spectacular aura aboutI8ACMRO has a spectacular aura about
^I was thinking the HPS one as well, especially once he said nitrous.
OP, the HPS Hardball'r Intake can supposedly withstand nitrous backfires, which we all know is a VERY bad thing. I would look into that intake as well. But like stal said, you seem to have your heart set on an Eddy, so I would get that 6061 elbow with it IMO.
http://www.moddedmustangs.com/forums...-member-30498/
Originally Posted by RZNCAIN View Post
Drive the shit out of it and replace shit when it breaks. No point in having these things if we are going to drive them like a bunch of pussies!
Old December 15th, 2010, 12:01 PM   #13
Hooo Ha Ha
sharkbait's Avatar
1997 Mustang GT
11.65 @ 115
sharkbait has much to be proud ofsharkbait has much to be proud ofsharkbait has much to be proud ofsharkbait has much to be proud ofsharkbait has much to be proud ofsharkbait has much to be proud ofsharkbait has much to be proud ofsharkbait has much to be proud of
iTrader: 10 reviews
i owned one of the HPS intakes and i am very fond of them.
I would highly recommend it
410rwhp 520rwtq @ 12.9 psi
Old December 15th, 2010, 12:06 PM   #14
Willy Mo's Avatar
Willy Mo is just really niceWilly Mo is just really niceWilly Mo is just really niceWilly Mo is just really niceWilly Mo is just really nice
HPS, or option 4.
If you plan on goin FI I would do option 4. That is if you are going to use a turbo or centri.
Old December 15th, 2010, 12:07 PM   #15
I'm not set on the edelbrock. I listed it 2x because of the different ways to mount the TB,the elbow and the plenum adapter. I'm gonna look into this HPS intake. Anyone know if it will accept stock fuel rails?
Old December 15th, 2010, 12:11 PM   #16
Willy Mo's Avatar
I would def get the elbow, and not the adapter to use a traditional plenum. You will see greater gains witht the edlebrock when you boost.
Old December 15th, 2010, 12:12 PM   #17
I8ACMRO's Avatar
2003 Mustang GT
14.03@100
Yes it will. It looks similar to the Typhoon, but it's a MUCH better intake.
Old December 15th, 2010, 12:19 PM   #18
That hardballer looks like it will work better than any I listed. Plus,they're made here in TEXAS,which is cool. Gotta suppor local businesses.
Old December 15th, 2010, 12:21 PM   #19
BakerFX4's Avatar
BakerFX4 has much to be proud ofBakerFX4 has much to be proud ofBakerFX4 has much to be proud ofBakerFX4 has much to be proud ofBakerFX4 has much to be proud ofBakerFX4 has much to be proud ofBakerFX4 has much to be proud ofBakerFX4 has much to be proud ofBakerFX4 has much to be proud ofBakerFX4 has much to be proud of
iTrader: 14 reviews
eddie w/ 6061 elbow gets my vote!
4.75 MMR 900se
Livernois ported heads
HP 292s blower cams
Procharger D1sc at 20+ psi
IW 15% OD pulley
(and more bolt ons)
E85
Tune/numbers coming shortly!!
Old December 15th, 2010, 12:21 PM   #20
Willy Mo's Avatar
Isnt the hardballer made by Texas Hot Rods?
Threads Similar to: Intake manifold...I need a new one
Swapping a 98 V6 intake manifold with for a 99 V6 manifold 98mustang V6 Mustangs 6 November 20th, 2010 11:20 PM
best intake manifold? 5.0Madness 5.0 Mustangs 81 October 14th, 2010 11:52 AM
Non PI intake manifold vs Aluminium crossover Intake manifold cedp83 96-98 6 September 10th, 2010 03:45 PM
Non PI intake manifold vs Aluminium crossover Intake manifold cedp83 99-04 1 September 9th, 2010 02:04 AM
intake manifold chickenbot 5.0 Mustangs 5 September 15th, 2008 05:48 PM
