#21 |
2003 Terminator Cobra
11.58@118
no i have never degreed the cams. i honestly do not know if the machine shop degreed them or not.
![]() Previous Ride: Fully built 03 mustang: gone but not forgotten. New ride: 2003 Black Terminator Cobra. 501/505 on 17psi |
#22 |
2004 Mustang
![]() ![]() ![]() ![]() ![]() ![]() iTrader: 4 reviews
I dont think your stock 19LB injectors will hold for a powerful tune with what you have done to the motor (heads AND cams)
![]() 305/333 WHP/WTQ with CMS Stage II cams 440/552 WHP/WTQ on Spray 7.86 @ 89.1mph, 1.61 60 foot N/A 7.20 @ 98.8MPH 1.55 60 foot on spray Stock Longblock with Cams |
#23 | |
agreed
#24 |
11.58@118
i thought the 19lbs were suppose to be good to almost 350-360rwhp??
#25 |
2003 mustang v6 ;)
slow
![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() iTrader: 2 reviews
you should let your motor sit at before you drive it for 20 min and dump the oil out, and change the filter when you breake in new motors. you never know how clean preped your motor was when it was put together plus your motor is going to shed for a little bit and it does not take a whole lot of crap in the oil pump to damage it. i let my car run for 20 min first start, then swap oil/filter, after that i drive it easy 3000 and under for 50 miles and dump the oil/filter again, then again 500 miles later.
#26 | |
11.58@118
#27 |
11.58@118
i will see what i can find out. what does degreeing the cams consist of and if there is no clearance issues why degree them? just curious. never done it or researched that part of it because i was told i didnt have to degree them when i bought them.
#28 |
2004 Mustang
I think MAX "safe" Duty cycle on them is about 85-90%. At that % they can hold about 290-300 WHP
#29 |
1996 Mustang
I take myself way too seriously.
Always wanted to say this....
#30 |
11.58@118
i have a set of 42lb injectors in the storage building. would those be to much?
#31 |
11.58@118
i can't upload them. i could take a few on my phone and email them along with a short idle clip to someone if you wanted to put them up for me.
#32 |
1996 Mustang
#33 |
11.58@118
dont have internet at the house and that site is blocked at work. that is why i can not upload anything.
#34 |
11.58@118
i wasnt expecting to get numbers much higher than 300rw out of this setup n/a. figured at the max i would probably be sitting around 315rw considering it is a blower setup.
#35 |
2003 mustang v6 ;)
slow
it is expensive but it cost more if you dont go threw the proper steps and ruin the motor if something gets in the oil pump and damages it and then breaks your motor. about the whole cam degree part, its important to degree cams in since the oem cam sprockets fall in a tolerance of 4 degrees +- which total can be up to 8 degrees off from bank to bank. if you have your pistons notched you may not have issues with ptv but its just good practice to have them degreed in. if you payed some one to do the balance and timing of the motor i would expect it to be done.
#36 |
11.58@118
oh ok well that makes since. yeah i have been going by how the builder told me to break it in on changing the oil after the first thousand miles but from what you said that is the extreme to what he told me lol.
#37 |
2003 mustang v6 ;)
slow
like i said oil changes are cheap compaired to a broken motor. you can break it in how you feel but if you have ever seen the oil pump in our car you will see how tight the gears fit in the housing so that means any bit of crap in it will mark it up and could damage it.
#38 |
11.58@118
Yes oil changes are cheaper than a new motor lol. Can't argue that one. I believe I will change the oil at 500 instead of 1000 and change it again at a 1000 to be more on the safer side
Threads Similar to: It's Alive!!
| It's Alive!!! | One Bad Sixxx | V6 Mustangs | 16 | December 4th, 2010 07:03 AM |
| ALIVE She's ALIVE! | ModMustang97GT | 96-98 | 8 | April 8th, 2010 06:36 PM |
| It's ALIVE! | Dr BlackStang | 2005 - 2010 | 15 | November 28th, 2008 12:06 PM |
| it's alive! | fairlane_68 | Videos | 0 | October 13th, 2008 04:22 PM |
| Its Alive ! | e3sean | 5.0 Mustangs | 13 | March 7th, 2008 10:23 PM |
