It's Alive!!
Old December 15th, 2010, 02:46 PM   #1
2003 Terminator Cobra
11.58@118
napwrd2vgt03 is on a distinguished road
It's Alive!!
Hopefully a few of you guys remember my last thread of my new motor being finished. Well last Wednesday night at 10:00 pm she finally came to life. I spent 3 days trying to find the right starter for my car and after going through 4 brand new starters I bought a remanned starter that worked. Been driving the car for the last week and boy does it feel strong. I was told to put 1,000 miles on the new motor to break it in properly and I only need 750 more miles to finally be able to put the pedal to the metal. Hopefully I have been going about it the right way. I have been switching back and forth from shifting at 3,000rpms and 4,000rpms at 3/4 throttle. Around the first couple of weeks in January I will be taking the car to Dallas to get my new n/a tune put on as well as my tune for the 150 shot of nitrous. Just wanted to share my story.
Previous Ride:
Fully built 03 mustang: gone but not forgotten.
New ride: 2003 Black Terminator Cobra.
501/505 on 17psi
Old December 15th, 2010, 03:05 PM   #2
04 Ford Mustang Mach 1
WildHorse28 is on a distinguished road
sounds SWEET!
Old December 15th, 2010, 03:07 PM   #3
Willy Mo's Avatar
Willy Mo is just really niceWilly Mo is just really niceWilly Mo is just really niceWilly Mo is just really niceWilly Mo is just really nice
Did you install new cams? mayeb recap what was done?
Old December 15th, 2010, 03:15 PM   #4
11.58@118
Ok well here is the break down of the motor. Patriot stage 2 ported heads, crower stage 2 blower cams. 2005 mountaineer aluminum block bored .020 over with manley 18cc dished pistons, manley ibeam rods, eagle cast steel 8 bolt crank, cobra high volume oil pump w/ pickup, moroso oilpan, steeda underdrive pulleys, 75mm throttle body, ported plenum w/ plenum spacer, stock injectors, rails, and intake, and a cai. pype long tube headers w/ prochamber into a magnapack catback. tko 500 trans w/ pro 5.0 shifter, aluminum driveshaft, 4.10 gears, full length subframe connectors. and i can not remember what suspension is in the back. it was put on before i bought the car. first part of the year i will be installing tubular suspension upfront and adding a 150 shot of nitrous.
Previous Ride:
501/505 on 17psi
Old December 15th, 2010, 03:31 PM   #5
Willy Mo's Avatar
Blower cams? But no blower? and did you run the motor at 2000rpm for 20 min before driving?
Old December 15th, 2010, 03:36 PM   #6
11.58@118
plans for blower in future. ummm no i did not. i let it run for 20 minutes though. No one said anything about running it at 2,000rpms for 20 minutes.
Previous Ride:
501/505 on 17psi
Old December 15th, 2010, 04:15 PM   #7
2k rpms? as long as you break it in by giving it an overall mix of driving through the rpm range (not readline lol) and all gears then it should be okay. at least thats what i thought.
Old December 15th, 2010, 04:16 PM   #8
11.58@118
that is what i thought as well. atleast that is the way i was told to break it in by the builder.
Previous Ride:
501/505 on 17psi
Old December 15th, 2010, 04:21 PM   #9
regardless good luck with the new motor, im jealous haha but christmas bonus and tax return might bring some parts to the door step
Old December 15th, 2010, 04:26 PM   #10
11.58@118
Thanks man. I am definately enjoying having the car back. I spent 6 months without it waiting to get the money put together.
Previous Ride:
501/505 on 17psi
Old December 15th, 2010, 04:39 PM   #11
Willy Mo's Avatar
Well i honestly dont know the exact procedure to break in cams on a mod motor. but on almost every pushrod motor build i have been apart of, was required to run the engine at 2000 rpm for 20 min. But sounds like a nice build. Hope all goes well.
Old December 15th, 2010, 04:44 PM   #12
11.58@118
correct me if i am wrong willy mo but doesn't the cam on the old 5.0 motors go inside of the block instead of sitting on top of the heads? with our cams they do not have to break in and have never heard of having to break them in. i could be wrong but do not think i am. i have done a lot of research on different setups and from what i have found out the timing on the 2v sohc motors is one if the easiest types and quickest to time. i have not once ran the cams at a certain rpm to break them in and this is the third motor that they have been on in my car.
Previous Ride:
501/505 on 17psi
Old December 15th, 2010, 04:52 PM   #13
Willy Mo's Avatar
Originally Posted by napwrd2vgt03 View Post
correct me if i am wrong willy mo but doesn't the cam on the old 5.0 motors go inside of the block instead of sitting on top of the heads? with our cams they do not have to break in do to being powered by the timing chains. i have done a lot of research on different setups and from what i have found out the timing on the 2v sohc motors is one if the easiest types and quickest to time. i have not once ran the cams at a certain rpm to break them in and this is the third motor that they have been on in my car.
push rod motors use timing chains as well. and you are mistaken about a SOHC motor being easy to time. They are very easy to screw up. I dont know where you found this info. Your break in a cam/s to seat the cam/s to the bearings.
Old December 15th, 2010, 05:00 PM   #14
11.58@118
dangit you quoted me before i edited my post. and yes i know the old 5.0s used timing chains as well. im not a complete moron. im mistaken on them being easy to time??? done it three times already and to me not being a mechanic and only been doing motor work on my own car for two years it seems to be pretty straight forward and simple to time them especially if you have marked chains.
Previous Ride:
501/505 on 17psi
Old December 15th, 2010, 05:03 PM   #15
Willy Mo's Avatar
I am going to assume you have not degreed the cams in a SOHC motor. The timing of the cams are very important, as if the cam timing is off you will hear teh drummer boy in your cylinder. (valve hitting piston)
Old December 15th, 2010, 05:07 PM   #16
11.58@118
yeah they are very important to time. which is why i turn my motor over by hand a few times just to double check the timing of the cams and make sure there is no clearance issues. i would never just install the cams slap on the chains and fire the car up and take that chance. that is extremely stupid and i am sure there have been a ton of people who have made that mistake before but i dont like taking chances with expensive crap.
Previous Ride:
501/505 on 17psi
Old December 15th, 2010, 05:09 PM   #17
Willy Mo's Avatar
did you degree the cams? it is not needed but with a build like yours I would hope you did.
Old December 15th, 2010, 05:09 PM   #18
11.58@118
do i know every single thing about motors? HELL no i dont. like i said i have only been doing the work on my own car for two years and i know i have a lot to learn which is why i am glad i have friends who do this crap for a living.
Previous Ride:
501/505 on 17psi
Old December 15th, 2010, 05:10 PM   #19
11.58@118
this go around i did not install the heads and cams. i took the easy way out to save myself some time. i had the machine shop build the entire longblock.
Previous Ride:
501/505 on 17psi
Old December 15th, 2010, 05:14 PM   #20
11.58@118
man i aint trying to argue with you. i know you probably know exactly what you are talking about and know your stuff. all i have been trying to say is no one has ever told me to break in cams before.
Previous Ride:
501/505 on 17psi
Threads Similar to: It's Alive!!
It's Alive!!! One Bad Sixxx V6 Mustangs 16 December 4th, 2010 07:03 AM
ALIVE She's ALIVE! ModMustang97GT 96-98 8 April 8th, 2010 06:36 PM
It's ALIVE! Dr BlackStang 2005 - 2010 15 November 28th, 2008 12:06 PM
it's alive! fairlane_68 Videos 0 October 13th, 2008 04:22 PM
Its Alive ! e3sean 5.0 Mustangs 13 March 7th, 2008 10:23 PM
