suspension advice
so i just got my torque arm installed and it is amazing, i have so much rear end grip its retarted. But my front end has a little bit of understeer now. How do i fix this. I have the Tokico D-spec shocks, should i losen them up in the front or tighten? Do i have to much weight in the front? Stickyer tires?
![]() Mods = stuff to make me take corner faster
Abyssinian of AX
'02 Saleen
19.34@42.259
So compounding the rear grip has given you understeer, huh? he he
*I keed, I keed* ![]() A heavier rear sway bar is one of the easiest ways to address this issue, but would NOT recommend one unless ALL of your other suspension mods are done. A better way, would be to install heavier rear springs, so should consider this. Did you get new springs rated for use with this TA and what are your mods again, as I forget? For this issue on my own car, I installed an MMRSB #4 and was a nice upgrade. The softest setting is just stiffer than the OEM GT New Edge bar, but has 3 additional adjustment settings. I eventually went to the last one and was still not enough for AX. I now run the #5 bar (purchased all by itself for this upgrade) and run at the lowest setting, but will likely move it up one setting for next season and see how she does. Jazzer
what do you have for your front suspension? could it be that the rear is stiffer than the front suspension?
SA XD40
retarded rear grip! ,Man I miss summer and riding my bikes .
09 crf450x super motard. 06 f250 powerstroke 04 cbr1000rr 03 rsx-s |
#5 | |
tokico d-specs bbk springs (650F and 250R) spring rate eibach sway bars CC plates x2 ball joints struttower brace bump steer subframes panhard bar ta lcas's what rating should i be using with the ta? i want to do coilover but i cant find a kit for the tokico d-specs. . look above
#6 | |
2001 Mustang GT Vert.
The bbk spring rates were designed to be used on the mustang with the standard 4 link. By decreasing binding in the rear with the TA, and thus improving traction the rear springs need to be changed Increasing the rear spring rate will help compensate for the understeer. MM can help you choose a rear spring rate that works best for your car. They have springs specifically designed to be used with a TA.
Mods in garage |
#7 | |
and awsome thanks for the help man ill call maximum right away.
Threads Similar to: suspension advice
| suspension advice | 25mike87 | 99-04 | 11 | December 8th, 2010 02:37 AM |
| Suspension Advice. | Ijuswan2gofast | 5.0 Mustangs | 11 | October 20th, 2010 03:03 PM |
| suspension advice | joymij | 94-95 | 21 | December 28th, 2009 03:32 PM |
| Suspension Advice | mousaleeni | 99-04 | 43 | November 24th, 2009 01:28 PM |
| Suspension Advice | weems | 99-04 | 14 | August 1st, 2009 08:39 PM |
