Front Squeak please HELP!
There is a horrible squeak coming from what seems to be my front suspension on both sides. It looks to me like the guy before me put a set of lowering springs on it and now some of the upper coils are touching which makes a metal on metal squeak. Does this make sense?
2001 Mustang GT
![]() ![]() ![]() iTrader: 3 reviews
Sort of not really, the springs shouldn't be rotating so it shouldn't be rubbing on itself. The coils may contact but I don't think that would squeak? Could be wrong but I dunno. Check if he kept the isolaters in (rubber pads on top and bottom of the springs) if there are no iso's you could be getting some squeaking from the spring hitting the perches.
![]() True Blue Crew Member #2 315's Crew Member (Dat azz) 255/298 Founder of the please leave my signature alone, I want it to say what I put there and don't appreciate you deleting it club |
01 GT
I currently have the same problem buddy. Its my ball joints. And at times it can also be the ISOLATORS. I just ordered both parts. Once they arrive ima get on that ASAP cuz that HELL NOISE is horrible
Well please let me know what it ends up being because the noise is driving me insane and its really embarrasing. true blue, my car looks identical to yours.
03 True Blue GT
check to see if the boots on your ball joints are cracked/ripped, if they are they should be replaced asap. I have seen what happens when a ball joint goes out at low speed in 99-04 stangs (tire smacks the fender leaving some nasty dents). At high speeds it can cause a major accident.
If you have checked the joints and there is no play try squirting a little WD-40 in there to see if the squeak goes away. If it does replace the ball joint asap because it is a time bomb once all the grease dries up. I believe stock ball joints last about 90,000 give or take (less if you lowered and kept the stock A arms). |
99 GT Vert 35th Limited
All Blake everything is right. Just replace those parts and you should be good to go.
Threads Similar to: Front Squeak please HELP!
| Squeak sound in front (brakes) | 97PonyGT | 96-98 | 38 | June 17th, 2011 10:34 AM |
| Front End Squeak | MineralGT | 99-04 | 15 | September 20th, 2010 10:51 AM |
| Front Right Suspension Squeak | jonwrong | 99-04 | 2 | March 1st, 2010 01:40 PM |
| Front End squeak? | stang_soldier | 99-04 | 4 | November 25th, 2009 07:17 PM |
| front end squeak | Fish | 2005 - 2010 | 1 | August 5th, 2008 08:44 PM |
