Will a aluminum drive shaft of a 03 cobra fit my 01 GT?
Old December 18th, 2010, 01:48 PM   #1
01KnightRiderGT's Avatar
2001 Mustang GT
01KnightRiderGT has a spectacular aura about01KnightRiderGT has a spectacular aura about01KnightRiderGT has a spectacular aura about
Send a message via MSN to 01KnightRiderGT
Like the title says, found a good one for $80. will it fit, if so is it worth $80?
Thanks
Black Stang Member #13
315's Crew Founder
My Track Videos
Old December 18th, 2010, 02:01 PM   #2
12.84@108
04N20GT will become famous soon enough
It is worth 80$, but it will not fit your GT unless you have a T-56 in it. It is too short.
MMR 950 Stroker
TFS 38cc Heads
MHS TFS N/A stage 3.5 cams
11.5:1 compression
Nitrous Express wet kit
12.84@108 2.0 60' on motor. race weight was 3750lb
354whp 330wtq motor, 480whp 500wtq 150shot.
Proud Iraq and Afghanistan Vet
Old December 18th, 2010, 02:29 PM   #3
'00 gt, '95 gt, '83 lx
11.85@116
bottled2v is a jewel in the roughbottled2v is a jewel in the roughbottled2v is a jewel in the rough
Send a message via AIM to bottled2v
how much shorter? might be worth it if it's only like half an inch too short, since steeda sells a spacer for the d/s.
'00 GT, hp 292's, full bolt ons, built/stalled auto, 4.10's, 150 shot-new times to come.
'95 GT, 347, tko, etc-11.8@116-sold.
WTT-my mildly built 4r70 for t56/tko.
Old December 18th, 2010, 02:30 PM   #4
ran260gt's Avatar
2004 4R75W Mustang GT
13.179 @ 104.30
ran260gt is on a distinguished road
Steeda makes a spacer but I'm not sure if its for making a Cobra shaft work in a GT !
...Mods in garage
Old December 18th, 2010, 02:32 PM   #5
11.85@116
it's not it's for putting a tko3550 in place of a t5 but i was just curious if it would work for the t56 as well.
Old January 28th, 2011, 07:41 PM   #6
Look Ma! My First Post!
lx388 is on a distinguished road
The 03 cobra driveshaft is 1.5" shorter than the GT plus the companion yoke (rear end) is bigger (4.25" bolt circle). If you decide to not use it, I need a shaft for a 03 cobra and would appreciate it if you would give me a call.
C. Newton 904-704-9043
Old January 28th, 2011, 08:02 PM   #7
0949er's Avatar
12.85 @ 114
0949er is a jewel in the rough0949er is a jewel in the rough0949er is a jewel in the rough0949er is a jewel in the rough
dude thats a perfect deal for somebody trying to put a t-56 into a GT....
MODS:
Vortech V1 T-Trim @ 7.5 PSI (tuned down)
Comp Cam Stage 2's
+ more
432 rwhp / 396 rwtq 02/27/2011
NEW VIDEOS!
**It takes ~$60 a rwhp (over stock) for a 99-04 Mustang GT.** Do the Math
C2H5OH on the horizon
Old January 28th, 2011, 11:22 PM   #8
stal94gt's Avatar
2003 mustang v6 ;)
slow
stal94gt has much to be proud ofstal94gt has much to be proud ofstal94gt has much to be proud ofstal94gt has much to be proud ofstal94gt has much to be proud ofstal94gt has much to be proud ofstal94gt has much to be proud ofstal94gt has much to be proud ofstal94gt has much to be proud of
you can swap yokes out to fit the sra. i just did this swap on my cobra. unfortunatly it is still to short and running the spacer wont eat up enough gap.
Old January 28th, 2011, 11:53 PM   #9
WhiteVenom's Avatar
99 Cobra :p
12.36@119.35
WhiteVenom is just really niceWhiteVenom is just really niceWhiteVenom is just really niceWhiteVenom is just really niceWhiteVenom is just really nice
Send a message via AIM to WhiteVenom
^ took long enough. I was just going to post that. The u-joint part # is precision 448 at Oreilly Auto Parts. Double check that because its off the top of my head.
MM COBRA CLUB #80
SRA SWAP WRITE UP!
Old January 28th, 2011, 11:53 PM   #10
WhiteVenom's Avatar
99 Cobra :p
12.36@119.35
Heres a pic of the two for anyone who cares
MM COBRA CLUB #80
SRA SWAP WRITE UP!
Old January 28th, 2011, 11:56 PM   #11
stal94gt's Avatar
2003 mustang v6 ;)
slow
448 is the right one, or you can swap the pinon flanges but that is harder
Threads Similar to: Will a aluminum drive shaft of a 03 cobra fit my 01 GT?
Aluminum Drive shaft Blower Head 96-98 0 December 21st, 2009 09:17 AM
Aluminum Drive shaft scubasteve041186 V6 Mustangs 0 July 14th, 2008 03:53 PM
Aluminum drive shaft ZsMach1 4V / SVT 16 March 14th, 2008 02:51 PM
aluminum drive shaft obdnanr V6 Mustangs 15 March 1st, 2008 12:01 AM
Aluminum Drive Shaft MikeyS281 5.0 Mustangs 11 November 15th, 2007 06:13 PM
