reverse glow guage install
Old December 18th, 2010, 04:37 PM   #1
cedsks's Avatar
cedsks will become famous soon enoughcedsks will become famous soon enough
Question
Hey you all,
I got a set of reverse white face guages that go green at night, anyway. it says that you dont need to remove the needles, my question is do the little caps come off and not take the needles off? like a decrative cover that snaps over the needle holder? I hope that make sense...
2004 2v GT--3.90's, t3650, H&R SS, 78mm TB, K&N CAI, steeda bump stop kit, HP Blues shocks and struts, soon to have a rear seat delete, light weight driveshaft.
Old December 18th, 2010, 05:51 PM   #2
00redgt's Avatar
2000 mustang gt
00redgt is a jewel in the rough00redgt is a jewel in the rough00redgt is a jewel in the rough
iTrader: 5 reviews
Send a message via Yahoo to 00redgt
ur gauge just slided over the top of the needles and the base of the needles...once you take the cluster out and remove the cover u just slide ur gauges over the needles
Old December 18th, 2010, 06:43 PM   #3
Novanutcase's Avatar
2003 GT
Novanutcase has a spectacular aura aboutNovanutcase has a spectacular aura aboutNovanutcase has a spectacular aura about
You probably have the one that is in three pieces right? If so as 00redgt said, you just slip them over the needles. No need to take anything off other than the cluster from the car. There should be some holes to help line it up and keep it in place.
John
SOLD - '03 GT, Max Moto Max Grip Box, Wilwood SL 6 front/DL4 rear Big Brake Kit, Corbeau Seats, MGW Short Shifter, MAC Long Tube Headers/Prochamber mid/ Flowmaster 40, FRPP 4.10, TrickFlow Diff Cover/75mm TB/Plenum, Eaton Posi, Moser 31 spl Axles
Old December 19th, 2010, 01:35 AM   #4
cedsks's Avatar
yea its tha three piece, I got it off ebay, it looks decient, but they didnt give any instructions with it, all they did was send a link to an install on a exploder/ranger. and it seemed like there was a black cap ontop of the actual needle and holder... just wondering if it was the same, well, if they slide right over, does it look stupid installed? ie. can u see the small gap around the needles?
Old December 19th, 2010, 09:40 AM   #5
00redgt's Avatar
2000 mustang gt
iTrader: 5 reviews
this is a cheap 3 piece slip on set on ebay
Old December 19th, 2010, 10:23 AM   #6
Mustang46's Avatar
11.85 @ 125
Mustang46 has a spectacular aura aboutMustang46 has a spectacular aura about
I got mine a long time ago for my 96 gt and it installed just like everyone elses has listed. The only thing that I had to do is take the little black pins out that the needles rest on when the power is off. They just pull strait out and you just put them back after its all installed. I don't know if they are like that now or not. I havn't installed any in a long while. The overlays that don't require the removal of the needles are nice. It's just alot more convenient and you don't have to worry about resetting the needles in the right spot.
I did find out in my case that it was more convenient for me to hook the power wire up to the hedlight switch. If I remember right the kit I bought (remember it was a long time ago) They just wanted you to hood up to a power source and use the dial knob to turn it on/off. Hopefully they are different now. Good Luck man and enjoy your new gauges.
Old December 19th, 2010, 12:15 PM   #7
2003 GT
Yup! Just hook the power to the power lead on the headlight switch and ground it to the metal bar that is behind the cluster.
John
Old December 19th, 2010, 12:23 PM   #8
WonfastGT's Avatar
2000 GT
WonfastGT is on a distinguished road
Send a message via AIM to WonfastGT
dude those so tacky to me you should have went to the latemodel resto page and got some of those white face gauges they look way more oem than those things my op
Old December 22nd, 2010, 12:34 AM   #9
1_nice_03_gt's Avatar
2003 ford mustang gt
13.9 stock
1_nice_03_gt has a spectacular aura about1_nice_03_gt has a spectacular aura about
ok i having a problem with my install first off sorry for bring an semi old tread back, but i cant get the damn wire to connect to the (grey) positive wire what did you guys use? i saw am install but they said to use wat is most convenient umm ok im lost lol i hate electical
k&n cai, mangaflows exhaust, summit udp's, 24lb injectors, 78mm bbk plenun, tri-ax s/s, a/c delete,3.73's, aluminum drive shaft, upr upper/lower control arms, solid motor mounts, bbk heades, upr xpipe,bbk cc plates, camber bolts.bama tune
Old December 22nd, 2010, 12:56 AM   #10
00redgt's Avatar
2000 mustang gt
iTrader: 5 reviews
i just skinned back the grey wire just a bit and connected mine there
Old December 22nd, 2010, 12:57 AM   #11
00redgt's Avatar
2000 mustang gt
iTrader: 5 reviews
it all in what you like man.me im changing mine out in jan for some guages that are like the 03-04 cobra ones
Old December 22nd, 2010, 01:02 AM   #12
Supersized Salami Swallower
Kohrs93's Avatar
00 GT
14.043@99.03
Kohrs93 is a splendid one to beholdKohrs93 is a splendid one to beholdKohrs93 is a splendid one to beholdKohrs93 is a splendid one to beholdKohrs93 is a splendid one to beholdKohrs93 is a splendid one to beholdKohrs93 is a splendid one to behold
SERIOUS lack of grammar skills on this thread...
All in all... I like the look of it.
Black Stang Crew #Coorslight
Originally Posted by Nameless View Post
It is big...but not as big as this pic makes it appear.
Originally Posted by Dennis View Post
yea now all i need is the time to clean it and lube it and fire it.
BONER CREW EMPLOYEE #3 - RECEIVING DEPARTMENT
Old December 22nd, 2010, 01:02 AM   #13
13.9 stock
i was doing that, but were did u grounded at?
Old December 22nd, 2010, 01:05 AM   #14
cedsks's Avatar
Mine are cheap and off ebay, but they arnt the sameones u have, they are 3 piece, but they look exactly like the 03-04 cobras minus the svt logo and it has the redline at 6.5k. I like em after they were installed, I can run them either as blue or green, I am currently running them green.
It matches perfect with my phanthom autometer guages with the leds installed, I was happy. I would post a pic but for some reason me posting pics on this site dosnt work well for me...
Old December 22nd, 2010, 02:08 AM   #15
00redgt's Avatar
2000 mustang gt
iTrader: 5 reviews
after 19 hrs of work,i can use crappy grammar lol
behind the cluster,there is a metal brace.drill you a hole and mount it there ir ground it there somehow
that is the same gauge im getting to match my cobra hvac layover
Old December 22nd, 2010, 02:26 AM   #16
cedsks's Avatar
Just from personal experience if u have the silver colored radio surround piece and shifter surround, it kinda looks out of place with the white face over the HVAC. Thats just IMO, I dont know if I even like the white face ac with the black but to each his own... BTW it can get funky to get the glow intensity to mach if u start mixing brands of parts, I ended up having to get the autometer led light adjuster to make it all look right and not be blinding...
If u can post the link to the one u are looking at on ebay.... BTW do u have a pic to post of your ebay glow guage at night?
Old December 22nd, 2010, 11:27 AM   #17
00redgt's Avatar
2000 mustang gt
iTrader: 5 reviews
this is what im going to buy,just not the same seller
1999-2004 FORD MUSTANG GT 150MPH GLOW GAUGES 2000 2001 - eBay (item 250742156224 end time Jan-11-11 19:47:58 PST)
and all the pics i got at night time are to blurry to see anything
Old December 22nd, 2010, 12:08 PM   #18
akvanden's Avatar
akvanden is on a distinguished road
Send a message via Skype™ to akvanden
Need to figure out the pictures... I'd like to see what these cheap gauge covers look like.....
link to where you found them?
K&N CAI
DiabloSport Predator tune
Bassani o/r x pipe
Borla cat back
Eibach Pro kit
Nitto 555r on Cobras
Old December 22nd, 2010, 12:56 PM   #19
cedsks's Avatar
Threads Similar to: reverse glow guage install
Reverse white face glow gauges install help will2045 96-98 8 March 14th, 2010 02:36 PM
Reverse glow gauges. bb0029 V6 Mustangs 51 March 9th, 2010 07:11 PM
a/c reverse glow???? Daniel Visual 10 October 19th, 2008 10:09 AM
guage switch? need help with reverse glow gauges!!!!!!!!!! 94pacecarSVT 99-04 11 May 29th, 2008 12:43 PM
help with a/c reverse glow WeCircleTheProblem Visual 4 September 8th, 2007 10:35 AM
