LinkBack (2) | Thread Tools |
#1
2003 mustang gt
slow
upr caster camber plates
94-04 Mustang Billet Shark Caster Camber Plates...looking for opinions..i know they are not the best out there but are they worth 45 bucks?
04 mustang gt
7.21 @ 98
uh 45 bucks? yeah!
they have lifetime warranty as well.
![]() cams + 150 shot |
I assume they are used or unwanted?
My brother has them on his '99, they are OK--not great but OK. I have the Steeda 4-bolt plates and FWIW they are far superior...
-cliff knight- My Mustang 2003 GT, UPR X, 24lb/h injectors, Magnaflow, 180° stat, PP 70mm TB & plenum, DF Commando, Steeda UDPs, Ralco RZ_flywheel, RAM HDX clutch, WX EFX COPs 3.73s, 262 rwHP/305 lb-ft. Flex-fuel: burns gas and rubber...
04 mustang gt
7.21 @ 98
what do they do differently??
2001 Bullitt
12.25@110.4
The UPR sharks don't let you slide the plates up and down for camber like others. You're stuck with the factory range of motion, but with 2 different settings to use, which actually works OK, but isn't the greatest setup, and makes it a lot harder to adjust when you run out of range of motion on the holes you're setup with. You have to take them off, and then reinstall them in the other holes.
2001 Bullitt
12.25@110.4
In this picture of my car, you can kind of see what I'm talking about. You can slide them front/back for caster, but you have to choose a hole for camber, instead of just sliding them up and down.
Also, they are much less robust than any of the 4-bolt plates, here's a shot of the Steeda's on my car...
13.4@101 wheel spin
I have the steel version of the upr sharks and altough they do the job my driver side clanks
02 GT K&N CAI no cats FRPP drop diablo programmer cherry bomb mufflers MGW short throw shifter TFS UDP's 3.73's... Looking into some shorty headers upper intake got a 75mm tb waiting ... Ironhorsemotorsports.com for all your ford needs! |
2003 mustang gt
slow
thanks for the replies, sorry its been a day or two. they are new and unused only no instructions. i have some negative camber issues bc its lowered .. i hope they will straighten it out ..
2001 Mustang GT Vert.
I'd go with a set of 4 bolts...much easier to adjust
Mods in garage |
2003 mustang gt
slow
i would like to but funds wont allow me to at the time.. but for 45 bucks i figured it would be cheaper than new tires..
LinkBack to this Thread: http://www.moddedmustangs.com/forums/99-04/196395-upr-caster-camber-plates.html
| Thread upr caster camber plates | Forums at Modded Mustangs | BoardReader | This thread | Refback | June 4th, 2011 10:12 AM | |
| upr warranty | BoardReader | This thread | Refback | January 13th, 2011 03:22 PM | |
Threads Similar to: upr caster camber plates
| are caster camber plates really necessary? | wtwillie1 | 2005 - 2010 V6 | 13 | May 3rd, 2010 08:28 PM |
| Caster and camber plates | flattusmaximus78 | 5.0 Mustangs | 8 | August 13th, 2009 11:17 AM |
| Caster camber plates | UnthoniJones | 99-04 | 8 | March 22nd, 2008 12:06 AM |
| caster/camber plates | ricks01 | General Tech | 12 | July 18th, 2007 04:26 PM |
| caster camber plates | Blk01ponyGT | 99-04 | 16 | July 14th, 2007 08:34 AM |
