MM's Taint Shaver!
2003 Mustang GT
Need help figuring out where this noise is coming from.
My car has been making this annoying buzzing sound for the past couple weeks and I can't figure out whats causing the sound. I usually only hear the noise when the motor is at normal operating temperature and when backing off the throttle too slow for a stop. It doesn't increase with the RPM's and seems too be coming from the top of the motor. The car still runs fine and hasn't been problematic starting or running poorly. Can someone help me out? I attached a video of the car making the noise. Thanks!
![]() Dale :: MOV00373.mp4 video by Dale06_photo - Photobucket
MM's Taint Shaver!
2003 Mustang GT
Bumpity bump bump. Anyone? Or am I the lone ranger here too have ever had this noise?
00 mustang gt
make sure ur cup holder dont have any loose change in it...happens to me all the time...
![]() Cms stage 2 cams 04 explorer aluminum engine spec 3 clutch sct x3 k and n cai 410 gears underdrive pulleys roush short throw |
MM's Taint Shaver!
2003 Mustang GT
Click the linky in the thread. The noise is coming from under the hood.
Supersized Salami Swallower
00 GT
14.043@99.03
![]() ![]() ![]() ![]() ![]() ![]() ![]() iTrader: 2 reviews
Really hard to hear the noise man :/ can you try to describe it better? Maybe where its coming from? up/down with rpms? etc
MM's Taint Shaver!
2003 Mustang GT
I have this stated in the OP. You can hear the buzzing noise when I rev thd motor a little and the rpms begin too drop back to idle.
'99 Mustang GT
The kinda high pitch buzzing sound, or the grinding/scraping sound it makes a few times while revving? I'd like to know too, cause I think my car has done it quite a few times. None recently though.
MM's Taint Shaver!
2003 Mustang GT
Yea thats the noise. It doesn't seem too be abnything major but its definately annoying. I just can't track it down. Its not coming from the motor, the sound is coming from around the intake manifold and plenum. Ill let you know when I get it figured out.
04 mustang gt
7.21 @ 98
i think mine doing it too but only since its been cold and been using heat
![]() cams + 150 shot |
MM's Taint Shaver!
2003 Mustang GT
Im not sure if its cold weather related but I do know it does this regardless of whether or not the heat and a/c are on.
'99 Mustang GT
Yup, I noticed mine with all heat/ac etc off before it snowed. Please do let me know when you figure it out, I'll ask around to see if anyone knows too.
04 mustang gt
7.21 @ 98
may not have anything to do with it. just know that it hasn't been like that for long
MM's Taint Shaver!
2003 Mustang GT
boobs.
you talkin at the :36 and :40ish mark's? Ive heard a few cars make that noise and they never had a problem, always figured it was a harmonics transfer through something, that one weird/odd moment and it made something around it vibrate
2003 ford mustang gt
13.9 stock
u can hear it clearly at :21-:22 seconds, does it idle ok?
k&n cai, mangaflows exhaust, summit udp's, 24lb injectors, 78mm bbk plenun, tri-ax s/s, a/c delete,3.73's, aluminum drive shaft, upr upper/lower control arms, solid motor mounts, bbk heades, upr xpipe,bbk cc plates, camber bolts.bama tune
MM's Taint Shaver!
2003 Mustang GT
The car idles fine. I haven't noticed any problems other than that noise.
99 Cobra, 03 Mach1, 07 CS
It's hard to say for sure, but if it's the sound I think I'm hearing, I had something similar once that turned out to be the waterpump. Maybe take your belt off and try spinning that and all the other pullies by hand and see if any of them have play or feel rough.
![]() 2007 Redfire California Special http://i183.photobucket.com/albums/x...n/2007GTCS.jpg 2003 Dark Shadow Grey Mach 1 http://i183.photobucket.com/albums/x...born/Mach1.jpg 1999 Black Cobra Vert |
MM's Taint Shaver!
2003 Mustang GT
I'll check that out also. Thanks! The noise seems too be coming from around the IAC and TPS though. I cleaned the IAC valve although it wasn't very dirty.
MM's Taint Shaver!
2003 Mustang GT
Just wanted too update this to let everyone know I found the problem. It ended up being my IAC valve. The problem finally started showing symptoms of a hanging idle. My car got to where it didn't wanna idle lower than 1,500rpms. Replaced the IAC and everythings great now.
Threads Similar to: Need help figuring out where this noise is coming from.
| noise coming from HIDs | WhtStang00 | Audio/Video | 7 | September 11th, 2009 01:22 AM |
| noise coming from alternator... | wushux2003 | V6 Mustangs | 7 | July 9th, 2009 09:22 PM |
| Where is that damn noise coming from??? | Dr BlackStang | 2005 - 2010 | 15 | January 11th, 2009 12:39 AM |
| Where is this noise coming from!? | 1997Stang | 96-98 | 8 | February 16th, 2008 02:11 AM |
| noise coming from intake | brian p. | 99-04 | 3 | January 16th, 2008 06:32 PM |
