Need some help with my car.
Old December 19th, 2010, 04:21 PM   #1
I don't drag, I drift.
danielholmesGT is on a distinguished road
Okay so yesterday I was on my way up to Kent and when I hopped on the freeway my car started misfiring and bucking, then the check engine light started blinking. So I pulled over and drove it home until I could get to O'Reilly's today to run a diagnostic. The diagnostic said Misfire On Cylinder 6 with a code of P0174 Too Lean Bank 2...
OBD-II Trouble Code: P0174 System Too Lean (Bank 2)
PaladinMicro
I am going to try cleaning the MAF and cleaning my K&N and see if it does the trick...
Old December 21st, 2010, 04:29 PM   #2
Okay I'm going to bump this with an update and see if I get a response.
Update- Went around unplugging spark plugs and injector's, the only one that didn't change how it ran when it was unplugged was the #6 injector and spark plug (Of course) So I popped the spark plug out, tested the spark plug and coil and they both worked great, fired it up and it had great compression. Soooo next thing I did was put the spark plug back in and got a new injector figuring that I knew that was the problem. Installed the injector today and fired it up, it's still missing on number 6! So I took the injector out and tested it (Works great and I know the plug is working too)
So I'm kinda back to square one afte the spark plug, injector, cleaning the MAF, cleaning the TB, and testing all the connections with a test light.
Any Ideas?
Old December 21st, 2010, 11:09 PM   #3
AngryPumpkin is on a distinguished road
I had this problem with my 2001 Lightning. Ended up taking it to HP Ranch in Marysville. All the truck needed was a tune.
I think I met you this summer in Centrallia, Your Cat-less and running E-85 right.
All I know is with my L running E-85 I had to take it back to my tuner for a new tune.
If you dont have a hand held, I can always meet you somewhere and you can load a tune off mine to see if it helps.
Old December 22nd, 2010, 01:37 AM   #4
Yep. Catless, off road pipe, e85, and a few new things since then. You had the orange and black GT (Or was it a Mach?) I've seen it around a couple of times since then, but haven't seen you around since that one night when you bailed in Toledo lol. A tune would be awesome if you could get one and load it on my car. I am trying to get the car running good before I put it in storage while I go to Basic.
Old December 22nd, 2010, 01:42 AM   #5
stal94gt's Avatar
2003 mustang v6 ;)
slow
stal94gt has much to be proud ofstal94gt has much to be proud ofstal94gt has much to be proud ofstal94gt has much to be proud ofstal94gt has much to be proud ofstal94gt has much to be proud ofstal94gt has much to be proud ofstal94gt has much to be proud ofstal94gt has much to be proud of
does e85 do alot of good for na cars? just wondering
Old December 22nd, 2010, 01:51 AM   #6
K_Boss01GT's Avatar
2012 5.0
N/A
K_Boss01GT is on a distinguished road
Replace ur coil pack for the cylinder or even swap it with another to see if i moves.. If not change that spark plug... Had to do it to 4 of mine.. And wat branch r u joining??? Im in the AF myself
2012 Black GT, 3.73, bassani axel backs, MGW shifter ordered!!!
MFE - If Engines can't fix it, your're f#@ked
http://www.wpclipart.com/armed_services/airplanes/airplanes_2/EC-130H_Compass_Call.jpg
Old December 22nd, 2010, 01:54 AM   #7
Very much so for me when I was tuned for it.
Old December 22nd, 2010, 02:00 AM   #8
Army, all of my line scores were over 110 so every job the Army had to offer was open to me and I chose 21D which is Army Diver (You go through the Navy school for diving as does the Coast Guard, Navy, and Marines)
Old December 22nd, 2010, 03:42 PM   #9
Its just a GT not a Mach. I'll see what I can do about a tune for ya.
Good luck in Diver school. I heard its pretty hard to pass. I'm currently active duty army stationed at Lewis. You should of went 11B. Its a hard job to beat. Who else will pay you to drive around and shoot at people.
Old December 22nd, 2010, 09:44 PM   #10
Okay, shoot me a PM when you know. I had kinda thought about Airborne Infantry but there are not many jobs for driving around shooting people when you get out of the military lol...
Old December 22nd, 2010, 10:07 PM   #11
21D- Who else will pay you to dive around and blow up bridges? I will see if I can get the tune I had before from Dan Schoneck...if not let me know what you find.
