1996 GT
how to get my car to drop rpm faster?
how do i get my car to drop rpm faster?
MM's Taint Shaver!
2003 Mustang GT
Get a heavier flywheel. May I ask why you wanna do this?
![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() iTrader: 14 reviews
IAC mod. And they will drop as fast as you want according to how big you make the hole in the gasket. Do a google search or MM search on "iac mod mustang"
rep for baker!
![]() 4.75 MMR 900se Livernois ported heads HP 292s blower cams Procharger D1sc at 20+ psi IW 15% OD pulley (and more bolt ons) E85 ![]() Tune/numbers coming shortly!! |
Between shifts? In the morning when it's cold?
2003 mustang v6 ;)
slow
![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() iTrader: 2 reviews
lighter flywheel will make the rpm's move up and down faster. heavier flywheels carry momentum
1996 GT
have a ford racing aluminum flywheel. i have cams and at like stop lights it takes to long for idle to drop when running temp
1996 GT
takes to long to drop
1996 GT
i want it so when u push clutch in it drops to where u can here cams instead of high rpm bul shit
It's explained as for a Mach1s but it'll also work on GTs and Bullitts.
Difficulty (1-10): 3 Time Required: 1 hour Equipment: Socket set, .5square feet of 1/32" aluminum sheetmetal, tin snips This is for anyone that doesn't like when the RPM's that are slow to drop or even rise slightly when you push the clutch in to shift. Another symptom, is that when cruising in a higher gear and you let your foot off the gas, the car almost cruises on its own for a bit. First, understand the problem. The engine is recieving too much air through the IAC valve. From my knowledge Ford did this for emissions reasons. As a side effect of this fix, when you downshift, the car burbles a lot more, sounds like a carburated engine. You get a little more engine braking effect. The FIX: Most older mustangs have an external IAC valve. Meaning that it is easy to find, follow a small air hose (1/2" ID) to a silver cylinder thing on your intake (the IAC solenoid). Once you found it, the older fix was to buy a 1/2" copper pipe cap, drill out a small hole, insert this into the line the restrict air flow through the IAC, and your done. The Mach has a slightly different setup. We have an INTERNAL IAC air supply. Meaning that there is no hose leading to it. To find your IAC valve, first remove your entire shaker assembly from your car. Next, look between your intake and the firewall, there should be a silver cylinder shaped object with 2 bolts leading to your intake. Remove the two bolts and move this assembly. You should see the following, the IAC assembly has two "ports" with the solenoid controlling the air flow between these two ports, what we want to accomplish is to restrict the airflow leading through this. To do this, there should be a small gasket on your intake, or it could be stuck to the IAC valve. Remove this (carefully) Trace out the shape of this gasket as well as the holes for mounting bolts, and the two airholes, onto a piece of 1/32" aluminum or something similar. Cut out the outline of this "restrictor plate" from the aluminum. Cut out the holes for your bolts to go through. Cut out a single one of the Air holes. Now the tricky part. You have to decide how big to make the other hole because this determines the amount of air you are restricting. The smallest you should go would be around 5/32", the worst case if you go to small is your car will stall when fix is complete, if this happens just take the plate out, make the hole bigger, and check that. The hole I used is around 9/32" which is about the medium you would want to go. After your "restricter plate" is cut out, mount it with the small hole on the passenger side of the IAC, and make sure to replace the gasket against the intake. Start your car, you should notice the RPMs drop when you start back to normal very quickly. If it idles smoothly, try putting turning on the AC, this will load the engine down. If your car stalls out, remove the plate, make the hole bigger, try again. If still idling smoothly, bolt your shaker back on, take it for a spin. You might need to adjust your driving/clutching style after being used to the crappy RPM hang, so don't be discouraged. Also, you might want to disconnect your battery during the procedure to make your computer relearn it tweaks after you finish. If, after you start the car you notice a "whistling" sound, then take a look at your plate, make sure the BIG hole is at least as big as the hole on the IAC valve. ALso make sure edges of holes are rounded (sharp edges are bad), and the holes are round. This happened on mine, and I fixed it.
1996 GT
baker ur my hero did u go hunting at all and any luck
nah, havent been lately.
Just take that gasket out behind the IAC and trace it out with some gasket material from autozone or similar. Then just make that breather hole smaller. You have to buy a big ass sheet of gasket material so play with the size till you get the drop speed that you want. Real easy man.
1996 GT
is it worth it? u say urs hangs high too?
naw, it used to with an old shitty tune i use to have. Im not running the mod anymore because i have a larger build. I could run it but mine is fine after many dyno tunes. lol. Just dont go really small cause it gets aggravating between shifts unless you shift super fast while the rpms are still up. Just play with it till you get it where you want.
Its a cheap thing to try man, just give it a shot. It will indeed drop faster. I promise!
1996 GT
so the bigger whole the better
the smaller the hole, the quicker they drop. I would try going just slightly smaller than the stock size and i bet you will be happy. Im not a fan of them dropping super fast. Gets aggravating. Just make one slightly smaller.
1996 GT
so drill the plenum and get gasket i dont want it stalling out tho
1996 GT
how would u make the hole smaller? cant drill smaller hole?
1996 GT
or r u saying drill for the other hole on the iac so ur making a brand new hole
1996 GT
yeah i dont want them dropping super fast just faster
Threads Similar to: how to get my car to drop rpm faster?
| Please God... Drop it hard, drop it fast | dr.gonzo! | The Clubhouse | 37 | December 9th, 2010 12:27 PM |
| What's faster | 86gt t-top | The Clubhouse | 66 | January 14th, 2009 03:57 PM |
| i need something faster! | mustang kid 1989 | The Clubhouse | 29 | July 10th, 2007 08:02 AM |
| how much faster........ | spero | 99-04 | 20 | April 6th, 2007 03:52 AM |
| I want my 6er to be faster..... | trueballerisme | V6 Mustangs | 61 | January 9th, 2007 11:10 PM |
