Difference between stock Mustang GT and Cobra blocks? - Forums at Modded Mustangs
post #1 of 14 Old December 19th, 2010, 07:30 PM Thread Starter
What are the differences between the stock Mustang GT block and the iron Cobra block???
If I switch to a Cobra block, will I need to make any other changes, or do they swap without any changes?
MM Bracket Racing Crew Member #5
saxmanJJ is offline
post #2 of 14 Old December 19th, 2010, 07:33 PM
stal94gt's Avatar
cobra blocks are romeo blocks. if you have a 99-mid 01 its a windsor block and heads. every thing can be transfered over. the timing cover bolts are the only thing that is diff when it comes to the swap from windsor to romeo. romeo blocks are romeo blocks cobra or gt.
stal94gt is offline
post #3 of 14 Old December 19th, 2010, 07:50 PM Thread Starter
I have a 2004 Mustang Gt, so I guess you're saying it's a direct swap. What is the advantage of having a Cobra block vs. the 2004 Mustang GT block?
The reason I ask is because I am either going to replace my rotating assembly with all forged parts (keep my block), or just by a complete short block with a Cobra block and the same forged parts.
saxmanJJ is offline
post #4 of 14 Old December 19th, 2010, 08:44 PM
86er's Avatar
if its 96-98 great block some 99/01's had the same teksid block out of the 96-98 cobras, and other 99/01's have the wap block which isnt as strong b/c of the windowed mains in the block. 2v heads on cobra short blocks make some good compression almost 11.1 and yeild some nice gains
Just a truck
86er is offline
post #5 of 14 Old December 19th, 2010, 09:15 PM
tbirdscwd's Avatar
iTrader: -1 reviews
Everything will bolt right up. The main difference between them is that the cobra blocks have knock sensor bosses in the intake valley which need to be ground off to fit blowers such as the Kenne Bells. Other than that, there is no machine work necessary to allow all your 2v stuff to fit or anything. I think that is what you are looking for saxmann.
Being romeo blocks, I believe they also use a different main bearing design.....but I'm sure you won't be using your old shit anyways.
Fun: 2004 Mustang GT
DD: 1994 Ram 2500 Cummins 4x4
Borla "Stinger" Exhaust Vids
tbirdscwd is offline
post #6 of 14 Old December 20th, 2010, 01:56 PM Thread Starter
Thank you for the info about compatibility of the parts.
I would like to know if there is any advantage whatsoever to using a "Cobra" block vs our "stock" Mustang GT blocks (2004). I.e. are they stronger in any way???
saxmanJJ is offline
post #7 of 14 Old December 20th, 2010, 04:45 PM
tbirdscwd's Avatar
iTrader: -1 reviews
If they are somehow stronger, it doesn't really matter. Our stock GT blockss can take about anything you can throw at them
post #8 of 14 Old December 20th, 2010, 10:24 PM
Procrastinator
gt blocks and termie blocks are the same
DickH is offline
post #9 of 14 Old December 21st, 2010, 03:24 AM
tbirdscwd's Avatar
iTrader: -1 reviews
They are actually different castings, but all of the 2v stuff will fit on it so it really doesn't make a difference.
post #10 of 14 Old January 2nd, 2011, 10:09 PM
will the c head fit on a gt block? do they use different timing covers or can i use mine?
20GTstang02 is offline
post #11 of 14 Old January 2nd, 2011, 10:12 PM
There was one bolthole that had to be filled on mine putting the GT timing cover on the WAP block, so they're not "exactly" the same. No big deal though.
Bolt-On Bullitt... Unmodified longblock, stock intake and throttle body.
266rwhp/306rwtq
12.25@110.4 1.64 60ft
Currently Under Reconstruction
Bullitt5339 is offline
post #12 of 14 Old January 2nd, 2011, 10:13 PM
BYAHHHH!
Scott2001GT's Avatar
iTrader: 5 reviews
Teksid's are 6 bolt mains, no?
Powered by Ford
Boosted by Precision Turbo and Engine
Thanks to: Wagon Wheel Performance & STL Mustangs
Scott2001GT is offline
post #13 of 14 Old January 2nd, 2011, 10:19 PM
stal94gt's Avatar
are you talking about a wap aluminum block? cause i switched over from a windsor block to a romeo block and i used all the timing cover bolts.
stal94gt is offline
post #14 of 14 Old January 2nd, 2011, 10:26 PM
Yeah, all WAP blocks are aluminum. Wap stands for Windsor Aluminum Plant........
266rwhp/306rwtq
Human Verification
