engine builders please ...... .050" off the deck all good or all bad
LinkBack (4) Thread Tools
Old December 20th, 2010, 05:35 AM   4 links from elsewhere to this Post. Click to view. #1
austenpowers is on a distinguished road
ok im at a cross roads ..... could you tell me if it is a good or bad idea to machine .050" off the deck of an engine block ...... namely ford 5.4ltr boss 260
is it done often
im chasing compreshion . and to get it i need .050" off the block
the machine shop seem ok with it . but im positive they have not done many or any blocks of this nature
is there any rules of thumb i need to put in play
Old December 20th, 2010, 09:26 AM   #2
mm's nitrous mod
SWEET2KSTANG's Avatar
2000 mustang gt
11.79@115.83 (old set up)
iTrader: 8 reviews
can you? yes. do i recommend it? not on a street orientated car. imo, the best thing to do is to call in a set of pistons and have it added to the top of the pistons.
Old December 20th, 2010, 09:38 AM   #3
slow02gt's Avatar
2002 mustang gt
11.38@119
slow02gt is a jewel in the roughslow02gt is a jewel in the roughslow02gt is a jewel in the roughslow02gt is a jewel in the rough
Send a message via AIM to slow02gt
built motor,trickflow heads,logan intake,80mm comp turbo on the way..
Old December 20th, 2010, 09:41 AM   #4
1998 Mustang GT
13.046@107.49
cruizer will become famous soon enough
Could you get heads with a smaller combustion chamber or shave the heads instead?
98 Mustang GT 13.795 @ 98.87 N/A
Main mods: PI Swap, 3.73 gears, E85
My Mark VIII and T56 swap
Old December 20th, 2010, 09:56 AM   #5
mm's nitrous mod
2000 mustang gt
iTrader: 8 reviews
you can shave the heads, but it takes quiet a bit to get make a difference in the compression ratio.
Old December 20th, 2010, 10:03 AM   #6
CobraStang161's Avatar
4V twin turbo 2000 GT
I live my life a quarter mile at a time xD
CobraStang161 will become famous soon enoughCobraStang161 will become famous soon enough
why dont you just get a different dish piston?
Built 4V Motor with Sullivan Single Plane Intake
Custom 66MM BB TT kit
Borla XR-1 Dumped before rear
Moser built 9" Rear
35 spline WaveTrac Diff with 3.75s
35 spline Moser axles
14PT roll cage and minitubbed
Old December 20th, 2010, 10:07 AM   #7
mm's nitrous mod
2000 mustang gt
iTrader: 8 reviews
flat top's still dont yeild squat for compression in the 5.4's.
Old December 20th, 2010, 11:58 AM   #8
perhaps i should of elaborated, i mean call up CP and get a custom piston that will yield desired CR
Moser built 9" Rear
Old December 20th, 2010, 12:25 PM   #9
limited's Avatar
99 limited edition vert
limited is a glorious beacon of lightlimited is a glorious beacon of lightlimited is a glorious beacon of lightlimited is a glorious beacon of lightlimited is a glorious beacon of light
I would not shave the block or heads unless it is to square up the deck or if there is warpage. It really effects a lot as in chains, intake manifold fit etc. Do as mentioned and get the piston/rod combo that does what you want
KB'd 446rwhp/451rwtq, Mustang Dyno http://www.youtube.com/watch?v=3ZDpQ0EEm1M
Tuned by Joe at http://www.tricktuners.com
Old December 20th, 2010, 03:51 PM   #10
tbirdscwd's Avatar
12.88 @ 109.45 N/A
tbirdscwd is a name known to alltbirdscwd is a name known to alltbirdscwd is a name known to alltbirdscwd is a name known to alltbirdscwd is a name known to alltbirdscwd is a name known to all
iTrader: -1 reviews
I agree with all these posts so far pretty much. It is a lot better of an idea to get the right CR by choosing the right rods/pistons for your combo. I don't know about the 5.4, but shaving the heads or deck makes our already PTVC prone engines to have an even smaller amount of clearance which would require you to nothc the pistons to run any sort of decent cam
Fun: 2004 Mustang GT
DD: 1994 Ram 2500 Cummins 4x4
Borla "Stinger" Exhaust Vids
Old December 20th, 2010, 05:04 PM   #11
mm's nitrous mod
2000 mustang gt
iTrader: 8 reviews
the 5.4 sits in the deck, and is why he is hunting down a set up to bring up the compression. its not that big of a deal to dial the timing chains and intake manifold when you shave them down.
Old December 20th, 2010, 05:42 PM   #12
tbirdscwd's Avatar
12.88 @ 109.45 N/A
iTrader: -1 reviews
If that is the case, I wouldn't think twice about shaving the deck surface down a bit down a bit
Old December 20th, 2010, 05:57 PM   #13
mm's nitrous mod
2000 mustang gt
iTrader: 8 reviews
you have to get good tensioners, and a way to dial in the cams. the crank gears are prefered method, but the cam gears can be used as well. this also depends on how much is shaved off as well. the deck on the 5.4's are able to take quiet a bit, but not enough to make that primary way of getting the compression.
Old December 20th, 2010, 06:39 PM   #14
Thanks guys for all your answers ,comments and questions . im in aus and dont know alot about this engine as do my machine shop .... it started back at a combo from modxxx. i wanted a cr of 9 to 9.5:1 because im boosting this engine and they set me up hbeam 4340 rods and 11cc dish manley pistons wich put me in the 8.7:1 cr area and was really conserned about it being a street car a driving like a dog off boost (and the turbos arnt going strait on eighter).
they told me there was a problem as the deck was way down (i now know this is normal for 5.4) and i want 9.5:1 cr that told them that .050" had to come off the deck wich started the this thread,,,,,
so if i take .008 off the heads and .010" off the block this bumps the cr to 9.125:1 wich im happy with and its not the .050" as first thort .......
so its been a learning curve for both me and my machine shop (im just about to leave and educate them now)
thanks once againe this is a verry valuable forum keep up the good work
pleas comment
Old December 20th, 2010, 07:31 PM   #15
slow02gt's Avatar
2002 mustang gt
11.38@119
if thats all you want... then just go with flat tops and it will put you where you want to be...thought you wanted a all motor car...nex ttime be more specific..
also sounds like you probably would have been better off getting a shortblock already built since the machine shop you are useing dont know anything about mod motors...
Old December 20th, 2010, 08:30 PM   #16
mm's nitrous mod
2000 mustang gt
iTrader: 8 reviews
+1 on the flat tops. if you would just get flats, then you wouldnt have to worry about shaving anything.
Old December 20th, 2010, 09:35 PM   #17
yip you guys are right flattops would put me where i want it.... but money spent funds running out for the build so im working with what i have....
its a bit of a regretfull purchase, well,,, im shure i will be happy with the final outcome..... i did spesify what cr i wanted but i also specified what hp i wanted too so maby the pistons rods and cr was based on all those things i specified. it will work ok and now i have room for more boost i guess.
im gunnah be strapping on 2 wizzers but dont make me tell you what they are as im a bit ashamed of them however there a start
thanks
Old December 20th, 2010, 10:13 PM   #18
mm's nitrous mod
2000 mustang gt
iTrader: 8 reviews
if your boosting, then dont worry bout the little bit of compression difference. you can make that up with a little more boost.
Old December 20th, 2010, 11:23 PM   #19
well im more worried about the off boost performance and down low torque
this is where a cr would help off boost....... its been 16years since my last turbo car and it was a to you guys "pinto 2ltr" to us and the pom's a rs 2ltr escort ...... (loved that car) was crap off boost though.....
im shure i will have great resaults but have a long way to go
Old December 21st, 2010, 12:21 AM   #20
mm's nitrous mod
2000 mustang gt
iTrader: 8 reviews
you arent looking at much difference in off boost tq with minor compression difference depending on heads,cams, and turbos size set up.
LinkBack to this Thread: http://www.moddedmustangs.com/forums/99-04/196576-engine-builders-please-050-off-deck-all-good-all-bad.html
engine builders please ...... .050 This thread Refback December 27th, 2010 08:15 AM
engine builders please ...... .050 This thread Refback December 22nd, 2010 05:09 AM
engine builders please ...... .050 This thread Refback December 20th, 2010 09:07 PM
engine builders please ...... .050 This thread Refback December 20th, 2010 08:27 PM
Threads Similar to: engine builders please ...... .050" off the deck all good or all bad
Any good websites of engine builders out there? pavementpownder 99-04 10 August 4th, 2010 03:52 PM
question for engine builders mxnate116 The Clubhouse 0 May 22nd, 2010 06:17 PM
a ? for engine builders mpboy 99-04 3 February 3rd, 2008 04:47 PM
Engine Builders motorhead6776 99-04 6 October 14th, 2006 01:28 PM
Q for Engine Builders: Flex Honing Zak 5.0 Mustangs 8 September 12th, 2006 08:47 PM
