choosing between 1st and reverse - Page 2
LinkBack (1) Thread Tools
Old December 20th, 2010, 04:45 PM   #21
Tang Stang's Avatar
Tang Stang is just really niceTang Stang is just really niceTang Stang is just really niceTang Stang is just really nice
Originally Posted by cedsks View Post
just get a line lock dude and leave it in reverse
Most line lock solenoids are only intended for momentary use.
Originally Posted by 03_StangGuy View Post
I always thought higher gears worked better? Higher gear means the engine has to turn more for the tires to move further. Reason behind a transmission, the lower gears are easy to turn than a direct 1:1 ratio.
That applies to the cases when we're trying to turn the tires via the engine. In this case, we're trying to turn the engine via the tires. You want the gear that would require the highest number of engine revolutions per tire revolution, which would be a low (numerically high) gear.
Rod @ AzzKicker Cars
2004 Ford Mustang GT-The Driver-BBK CAI, PP TB & Inlet, Steeda UD's, SLP LM1, & 3.73's.
1990 Mercury Cougar XR7-The Meth Addict-5.0L DOHC Stroker w/2.1L KB SC.
1995 Ford F150-Mud Toy-5.0L, 4x4, 33's, & Warn 8274 Winch
Old December 20th, 2010, 04:55 PM   #22
I Poop Entirely Way Too Much
Blown 03 GT
03_StangGuy is just really nice03_StangGuy is just really nice03_StangGuy is just really nice03_StangGuy is just really nice
Makes sense!
Old December 20th, 2010, 07:34 PM   #23
bigjohnstud4200's Avatar
2000 GT 'vert
bigjohnstud4200 has a spectacular aura aboutbigjohnstud4200 has a spectacular aura aboutbigjohnstud4200 has a spectacular aura about
But the higher the gear, the less resistance on the engine. Test it... put your car on a hill in 5th and let go of the brakes then try the same thing in reverse. Another reason behind my madness, have you ever push started a car in 1st vs 2nd or 3rd? I don't know for sure, but it seems like reverse has the most resistance.
"...but don't say my car's topless, say the titties is out"
Nas
Originally Posted by thrashersonmomma09 View Post
( member as in person not as in cock although i do love cock)
Old December 20th, 2010, 07:39 PM   #24
quadracer786's Avatar
2006 Mustang GT
quadracer786 will become famous soon enough
put it in neutral and keep going till you find a brake shop lol but seriously man ebrakes are usually a cheap fix
Old December 20th, 2010, 07:46 PM   #25
jonnyspeed is on a distinguished road
What do all seven switches do?
Old December 21st, 2010, 12:43 AM   #26
Eagle2000GT's Avatar
12.73@111.36
Eagle2000GT is a splendid one to beholdEagle2000GT is a splendid one to beholdEagle2000GT is a splendid one to beholdEagle2000GT is a splendid one to beholdEagle2000GT is a splendid one to beholdEagle2000GT is a splendid one to beholdEagle2000GT is a splendid one to behold
Holy cow. Haven't any of you driven without an e-brake? I've driven a lot of years without the "hand brake" that we have in our Mustangs. Those mechanical lines that go to the back brakes used to be called "Parking Brakes."
If you intend to go foward. Put the damn thing in first gear and use the clutch to hold you. Sometimes this requires a little rocking motion as you let the clutch in and out out a little and let it out to hold you. This is a damn sight better then rolling into the car that pulled up on your bumper.
Edit: This is the first technique I taught my kids. I intentionally put them on hills so that they could kill the motor a few time before they learned to hold the car. I also taught them to back a horse trailer with a manual transmission. Sorry. I digressed.
ProCharger P-1SC, 9 psi, STD 396/383; Uncorrected 388/375; SAE 383/370
Mods list in Garage.
Old December 21st, 2010, 12:55 AM   #27
12.73@111.36
I went back and looked at the original post. Perhaps I misunderstood the question. Perhaps you were asking about a parked car.
If you are on a hill turn your tires so that if the brakes fail the tires turn into the curb. That means if you are pointed up hill, turn your steering wheel left. If you are pointed down hill completely to the right. If the car rolls, the curb stops it.
Old December 21st, 2010, 11:04 AM   #28
Blown 03 GT
Thats a good idea, just make sure theres actually a curb there!
Old December 21st, 2010, 11:11 AM   #29
fmxona500's Avatar
1996 Mustang
I take myself way too seriously.
fmxona500 will become famous soon enough
He lives in L.A. so they're is curbs everywhere.
Old December 21st, 2010, 09:41 PM   #30
Moderator
03SonicBoom's Avatar
2003 Grand Cherokee
03SonicBoom has much to be proud of03SonicBoom has much to be proud of03SonicBoom has much to be proud of03SonicBoom has much to be proud of03SonicBoom has much to be proud of03SonicBoom has much to be proud of03SonicBoom has much to be proud of03SonicBoom has much to be proud of03SonicBoom has much to be proud of03SonicBoom has much to be proud of
It comes down to simply understanding how gears work. Imagine first gear is a small diameter gear on the engine side and a big gear on the output shaft. It is VERY easy for a small gear to drive a large gear. But it takes MUCH more force for a large gear to drive a small gear (it comes down to translating torque through the gears). This is why it's easy to take off in 1st gear than 5th gear.
The difference in the question is that we do not want the car to move and the tranny output is the driving side. So to prevent it from rolling, you want the largest gear on the tranny output mated to the smallest gear on the tranny input. On the TR-3650, first gear and reverse are the same ration, 3.38:1. This means 1st gear and reverse are just the same for preventing the car from moving.
LinkBack to this Thread: http://www.moddedmustangs.com/forums/99-04/196596-choosing-between-1st-reverse.html
Cat E Plenum This thread Refback December 21st, 2010 04:50 AM
Threads Similar to: choosing between 1st and reverse
choosing a cam... help please. burnout5.0 94-95 17 March 9th, 2009 11:33 AM
Choosing a cam orcusomega 5.0 Mustangs 5 September 21st, 2008 08:42 AM
choosing a cam efulton95 94-95 7 October 22nd, 2007 12:31 PM
help choosing cam 97TunedMustang V6 Mustangs 5 February 12th, 2007 11:48 PM
Help Choosing Oil AM1AW 2005 - 2010 9 November 7th, 2006 08:09 PM
