some ?s on reat diff install
Old December 20th, 2010, 07:32 PM   #1
JD mustang's Avatar
2004 saleen (clone)
8.46
JD mustang is on a distinguished road
Parts are in for my rear end. 31 spline mosers, new diff. my question is since my pinion gear is ok do I have to pull out the pinion gear and shim it also since i am replacing the diff or can i get by with just new shims for my new diff??? What happened was when my axle broke it wallered out the spool housing of my diff.
Old December 20th, 2010, 07:59 PM   #2
andrewskaggs's Avatar
2003 Mustang GT
8.26@83.06 (1/8)
andrewskaggs has a spectacular aura aboutandrewskaggs has a spectacular aura aboutandrewskaggs has a spectacular aura about
If you can reuse the shims that held your stock diff in that should get you very close and you might not have to pull the pinion out.
Do you already have gears? If not, you might as well install some while you're in there.
Edit: In either case, you'll have to get the diff in there before you can tell what (if anything) you need to do to your pinion gear.
SLP :: SCT :: Eaton :: Maximum Motorsports :: Baseline Suspensions :: Strange Engineering
MM Bracket Racing Crew
BAMA Performance Drag Team #1
Project Thread :: YouTube Channel
Old December 21st, 2010, 04:39 AM   #3
JD mustang's Avatar
2004 saleen (clone)
8.46
yah already have 4.10s in there. This is my first diff install on my own just did not know what to do in this situation. thanks for the info
Threads Similar to: some ?s on reat diff install
Need help with gear and diff install DsmDave Northeast 4 December 21st, 2010 12:20 PM
Gear and Diff Install Monday... Last Chance to Influence Me jonwrong 99-04 32 July 1st, 2010 05:34 PM
FML. I need a new diff. BlackedOut04GT 99-04 4 August 30th, 2009 09:07 PM
2 diff dynos 2 totally diff readings 03snakeminated 4V / SVT 45 December 4th, 2008 03:52 PM
getting eaton diff, 4.10's and frpp girdle. What install kit do i need? navyman8903 2005 - 2010 7 October 10th, 2008 06:14 PM
