1993 lx 351 coupe
![]() iTrader: 1 reviews
Alternator Problems?
What is the easiest way to see if my alternator is gone bad? My car has a new red top battery, so i know that isn't the problem so it has to be the alternator right? I went to crank it up last week and nothing just clicked so I jumped it off with my truck, I drove the car for about thirty mins came and came home. The next day I try to crank and it turned over slowly then cranked up, i let it run for about ten mins and cut it off. The next day the battery was dead the starter wouldn't even turn over. Would buying a new alternator be better than getting this one rebuilt? I just want to spend $215 Bucks just for a alternator!!
![]() Killer Performance |
Resident Bubblehead
remove the alternator and take it to advance auto and have them test it. or you can find out the hard way like i did last year with my truck...
#3 | |
2000 GT 'vert
Also, you can put a voltmeter to it while running, you should be reading 13.2+ |
when all three of mine went out they would test it and it would work most of the time... had one guy run it through the whole test three times in a row and passed failed passed... i finally just ran fused wire straight from the battery into my cabin where I put it on my DMM. while driving around i saw my volts go from a nice healthy 14.3 to below 12.... replaced my alt and everything cleared up.
now i am searching on Ebay and what not for a blown stocker and i am going to have it rebuilt but wound to put out 200 amps and that way i can run it and have my current working one as a spare, plus i will have the benifit of more amperage so my stereo will be even happier...
![]() 02GT - Blown motor 86LX 3.8TBI auto replacement daily driver How to retrofit HID's |
1993 lx 351 coupe
I've noticed over the past couple of weeks that when I'm driving to work in the mornings with the lights on they will dim when ever I come to a stop. So I figured the alternator was going bad.
1993 lx 351 coupe
Alright guys so I removed the alternator and took it to star electric a local auto electric repair shop, and they tested the alternator and it was working fine. So I told them to take it apart a double check everything, and still everything was working fine. They told me something must be drawing power so I removed my aftermarket radio to see if that is the problem, because it is the only electric thing I've changed in the last few months. Maybe this will fix my problem if anyone has any more ideas let me know.
All Homo All The Time
2003 Mustang GT
Whatever you run plus 5 seconds
Are you a LEO?
BLACK STANG CREW MEMBER #30
2001 Mustang GT Vert.
is your voltage light ever coming on?
Mods in garage |
1993 lx 351 coupe
No my voltage light never comes on.
1993 lx 351 coupe
sounds like something is drawing power from your battery. If the car continues to run and no voltage light comes on while driving...doesn't sound like alternator
Mods in garage |
#12 | |
2000 GT 'vert
1993 lx 351 coupe
nope no subs or aftermarket alarm, only an aftermarket radio which I have removed to see if the battery goes dead.
2000 GT 'vert
Did you buy the battery b/c your other one was dead or was it an upgrade?
1993 lx 351 coupe
it was an upgrade, to the dry cell red top optima
2000 GT 'vert
If it still dies, try taking putting the other battery back in and see what happens.. maybe you got a bad battery?
1993 lx 351 coupe
alright so after taking out the radio, i let the car set for a day and went to crank it up an hour ago and it fired right up!!! I think I've found the problem the aftermarket radio was drawing fire while the key was off.
2000 GT 'vert
who wired it up? does it have a wiring harness or did they cut the factory and manually wire it up?
1993 lx 351 coupe
A car audio shop wired it up and used a wiring harness, I think is a short in the power wire coming out of the radio because i pulled the radio out with the key on and it kept cutting on and off when i moved the radio so I'm pretty sure I got me a bad connection or something in the harness.
#20 | |
2000 GT 'vert
Threads Similar to: Alternator Problems?
| Alternator Problems ( I Think) | rdspins89 | 2005 - 2010 | 8 | August 10th, 2010 08:17 AM |
| PA Performance 3G Alternator Problems | dennislv | 5.0 Mustangs | 2 | March 26th, 2010 02:08 PM |
| Alternator problems/wiring | Ford5.0 | 5.0 Mustangs | 3 | November 18th, 2009 02:09 PM |
| alternator problems | PolishSasquatch | 5.0 Mustangs | 0 | October 20th, 2009 10:42 PM |
| Alternator the root of my problems? | RyanGT | 99-04 | 14 | November 21st, 2008 12:14 PM |
