Nano Nitrous
Old December 20th, 2010, 08:00 PM   #1
WHOOP!
AggieStang's Avatar
7.44@95 (1/8)
AggieStang is just really niceAggieStang is just really niceAggieStang is just really niceAggieStang is just really niceAggieStang is just really nice
Question
Nano Nitrous
I have been experiencing consistently slower times after every run using a 150 shot and a bottle heater. I lose between 1.-.2 each run even after the pressure is brought up to 900 and after a few runs it won't even reach a good pressure. I have been reluctant to buy a nano nitrous kit in the past, but I am thinking about getting one now. What have yall heard about the kits? I've read magazine articles, but have heard nothing first hand.
Buy my:
Nitrous Accessories
Diablosport Programmer
In The Classifieds
Old December 20th, 2010, 08:37 PM   #2
mm's nitrous mod
SWEET2KSTANG's Avatar
2000 mustang gt
11.79@115.83 (old set up)
iTrader: 8 reviews
what heater and size bottle you running? i never had any issue with a single 15lb bottle, and i also running a pressure control heater.
Old December 20th, 2010, 08:37 PM   #3
mm's nitrous mod
2000 mustang gt
iTrader: 8 reviews
as for the nano system, i'm not fond of them personally. if you do get one, get a wideband to keep track of afr's. there have been a lot of people running leaner with the nano system.
Old December 20th, 2010, 09:17 PM   #4
Nicos2001GT's Avatar
2001 MustangGT
14.039@100(60ft 2.2)
Nicos2001GT will become famous soon enough
buy my zex kit
Old December 20th, 2010, 09:19 PM   #5
WHOOP!
AggieStang's Avatar
7.44@95 (1/8)
NX 10lb bottle and heater.
Buy my:
Nitrous Accessories
In The Classifieds
Old December 20th, 2010, 09:59 PM   #6
BaznastyDave's Avatar
2004 Mustang
BaznastyDave is a name known to allBaznastyDave is a name known to allBaznastyDave is a name known to allBaznastyDave is a name known to allBaznastyDave is a name known to allBaznastyDave is a name known to all
Have you been letting it cool down in between runs and ran it at the same pressure each time?
305/333 WHP/WTQ with CMS Stage II cams
440/552 WHP/WTQ on Spray
7.86 @ 89.1mph, 1.61 60 foot N/A
7.20 @ 98.8MPH 1.55 60 foot on spray
Stock Longblock with Cams
Old December 20th, 2010, 10:15 PM   #7
WHOOP!
AggieStang's Avatar
7.44@95 (1/8)
I have the heater on between runs. Most of the time it gets up to optimal pressure, but after 3 or 4 1/8th mile passes it doesn't make it all the way. The only good pass I get is off of a full bottle.
Buy my:
Nitrous Accessories
In The Classifieds
Old December 20th, 2010, 10:25 PM   #8
mm's nitrous mod
2000 mustang gt
iTrader: 8 reviews
i would doubl check the heater is heating up to optimum and pressure switch is connected good. i was making aout 3 runs before i had any type of issue a all with a 10lb bottle in my car.
Old December 20th, 2010, 10:28 PM   #9
WHOOP!
AggieStang's Avatar
7.44@95 (1/8)
Well, have you heard anything about the kit? It will be around the same price as a bottle heater if the heater is broken.
Buy my:
Nitrous Accessories
In The Classifieds
Old December 20th, 2010, 10:32 PM   #10
2004 Mustang
You might have a small leak in your connections. Open your bottle to fill the lines, then close the bottle. Now your lines will have pressure but will not be connected to the bottle. If you have a gauge after the bottle record your pressure, if not it will be less accurate to tell if you have a leak. Come back out at least an hour later and check the pressure in the lines with the bottle still off. It might drop a MAX of 50 PSI in the lines, any more than that suggests a leak.
If you do not have a gauge after the bottle just do a quick purge with the bottle open, remember about how loud/violent it is then turn off the bottle. Come back at least an hour later and purge it again. It will get less loud quick but your just listing to that 1st half of a second you purge it to see if the pressure sounded like it dropped a lot or not. Do this test with the bottle at outside temp.
Old December 20th, 2010, 10:38 PM   #11
MikeJones's Avatar
13.7@103
MikeJones is just really niceMikeJones is just really niceMikeJones is just really niceMikeJones is just really niceMikeJones is just really nice
You can usually tell when there is frost forming around the leak.
Mod6
Bigbore
Kooks
(parting out 2v motor)
Old December 20th, 2010, 10:41 PM   #12
2004 Mustang
On larger leaks yes
Old December 20th, 2010, 11:52 PM   #13
WHOOP!
AggieStang's Avatar
7.44@95 (1/8)
Out of nitrous right now. Will have to check it after a refill.
Buy my:
Nitrous Accessories
In The Classifieds
Threads Similar to: Nano Nitrous
NANO-Nitrogen Assisted Nitrous Oxide AnimalCrackers 2005 - 2010 21 December 20th, 2010 11:15 PM
Any nano heads in here? dr.gonzo! The Clubhouse 3 April 17th, 2009 06:36 AM
NANO anyone? Stangzilla 5.0 Mustangs 9 October 16th, 2007 06:21 PM
