bad wrist pin - Page 2
Old December 21st, 2010, 11:04 PM   #21
SadleUp's Avatar
2011 Mustang 5.0
SadleUp is on a distinguished road
I thought it might have been some timing chain slap, so i took the cover off and found my timing chains wore through the tensioner arms by a significant amount and had alot of slack. I fixed those and thought my problem was solved, but everything was still there.
Old December 21st, 2010, 11:05 PM   #22
stal94gt's Avatar
2003 mustang v6 ;)
slow
stal94gt has much to be proud ofstal94gt has much to be proud ofstal94gt has much to be proud ofstal94gt has much to be proud ofstal94gt has much to be proud ofstal94gt has much to be proud ofstal94gt has much to be proud ofstal94gt has much to be proud ofstal94gt has much to be proud of
sounds like a bad lifter. repeat
Old December 21st, 2010, 11:07 PM   #23
SadleUp's Avatar
2011 Mustang 5.0
Originally Posted by stal94gt View Post
man it sounds more like a lifter. all your symptoms leads me to think they are bad
I've had the valve cover off while listening with a scope...you can still hear it more internally than anything.
Old December 21st, 2010, 11:09 PM   #24
stal94gt's Avatar
2003 mustang v6 ;)
slow
does it sound like an exhaust leak? or a knock sound. its real hard to determin a sound
Old December 21st, 2010, 11:12 PM   #25
SadleUp's Avatar
2011 Mustang 5.0
I wish i made a video before i tore it apart. I did check for exhaust, but found nothing. Towards the end it got very loud and started sounding more like a knock. Loud enough to where I was scared to turn it on because it sounded like something was about to go seriously wrong.
Old December 21st, 2010, 11:13 PM   #26
SadleUp's Avatar
2011 Mustang 5.0
Since the mechanic swore that it was upper valvetrain, I bought a set of heads from someone just to do a quick swap...they'll be here on friday.
Old December 21st, 2010, 11:17 PM   #27
stal94gt's Avatar
2003 mustang v6 ;)
slow
sure its not a spun bearing? has the car ever seen spray?
Old December 21st, 2010, 11:22 PM   #28
SadleUp's Avatar
2011 Mustang 5.0
i figured i would have seen some metal if it were...and to the best of my knowledge, no
Old December 21st, 2010, 11:24 PM   #29
stal94gt's Avatar
2003 mustang v6 ;)
slow
you could have had detonation and eyed out your connecting rod. that wont leave metal just make a knock noise.
Old December 21st, 2010, 11:27 PM   #30
SadleUp's Avatar
2011 Mustang 5.0
what exactly is eyed out?
Old December 22nd, 2010, 05:26 AM   #31
2003 gt
5.4 32v on the way
DickH is just really niceDickH is just really niceDickH is just really niceDickH is just really niceDickH is just really nice
I believe he is saying you could have elongated/warped the hole the pin sits in. And to go back to my other post, what I was told is you can pull the piston down far enough to get to the pin while keeping the piston rings in the cylinder. I have read/heard that from a couple places but im not sure if its true.
If you have your heads off and have the timing cover off, you might as well just pull your rotating assembly and see what happened. No need to guess and waste money after you take a good look at the actual parts.
2003 Mustang gt - usual mods - slowly working on 5.4 swap
2004 srt4 - Stock DD/winter beater
Click here for your tuning needs
Before asking a gearing related question click THIS link and enjoy all your saved time.
Old December 22nd, 2010, 10:01 AM   #32
stal94gt's Avatar
2003 mustang v6 ;)
slow
he is selling the car.
Old December 22nd, 2010, 01:39 PM   #33
SadleUp's Avatar
2011 Mustang 5.0
worst case scenario I'll just put it back together and sell it as is to someone who wants to rebuild it
Old December 22nd, 2010, 03:23 PM   #34
superbeef1000's Avatar
sounds to me like a rod bearing,,, you can pull the oil filter off cut it open pull out the filter ant look at it while it is spread out to see if there are any gold metal flakes in it,,,,,i could see how changing the rod from under the engine would work that could be a big time time saver
Threads Similar to: bad wrist pin
It's all in the wrist 06RedfireGT The Clubhouse 59 December 10th, 2009 11:19 PM
Fractured my wrist Arsenal The Clubhouse 20 January 20th, 2009 11:14 PM
wrist pins cali 5.0 5.0 Mustangs 9 October 21st, 2007 10:44 PM
