Choosing a lower control arm
Old December 21st, 2010, 02:53 PM   #1
Too Soon, Junior!
asiansensation78's Avatar
03 GT Vert
15:43.28@25.21 Too many naked bitches in the back
asiansensation78 is a splendid one to beholdasiansensation78 is a splendid one to beholdasiansensation78 is a splendid one to beholdasiansensation78 is a splendid one to beholdasiansensation78 is a splendid one to beholdasiansensation78 is a splendid one to beholdasiansensation78 is a splendid one to beholdasiansensation78 is a splendid one to behold
Here is a compiled list of lowest prices (including tax and shipping) of lower control arms I'm looking at, just need a few recommendations
My car is mostly a street car, I take it to the drag strip once in a while and am starting to get into cornering. I'd like to be able to launch decently on drag radials, but more importantly, I'd like to stiffen up the rear end a little to help cornering. I'm wondering if some of the lower priced LCA options would hold up as well as the MM product for what my goals are. Thanks!
$192 PA Racing (generally favorable reviews), do these have sway bar mounts?
PA Racing
$203 Team Z
Team Z Double Adjutable Lower Control Arms (use w/ sway bar)
$240 Maximum Motorsports
GT MAXM LOWER CONTROL ARMS INCLUDES SPRING PERCH AND SWAY BAR MOUNT 1999-2004 | CJ Pony Parts
$160 UPR (ehh)
99-04 Mustang Chrome Moly Adjustable Urethane Lower Control Arms
$203 CHE (not good for cornering?)
View the 99-04 Mustang Rear Lower Control Arm Set at http://www.cheperformance.com
ADJUSTABLE HEIGHT, probably not in my budget right now
$310 J&M
1979-1998 & 1999-2004 Mustang Street/Race Rear Lower Control Arms W/ Weight Jack Spring Perch
$350 Maximum Motorsports
MAXIMUM MOTORSPORTS HEIGHT ADJUSTABLE REAR LOWER CONTROL ARMS 1999-2004 | CJ Pony Parts
03 GT - Scrapes on lane markers - Modded
02 Cougar - Able to clear most speed bumps - Some mods
01 Explorer - Parking blocks NOM NOM NOM - Stock
Nitrous Switch Panel for sale!
Old December 21st, 2010, 03:41 PM   #2
2001 Bullitt
12.25@110.4
Bullitt5339 is a glorious beacon of lightBullitt5339 is a glorious beacon of lightBullitt5339 is a glorious beacon of lightBullitt5339 is a glorious beacon of lightBullitt5339 is a glorious beacon of lightBullitt5339 is a glorious beacon of light
You don't need adjustable length lowers. The height adjustment ones are also kind of taboo in my book. You want to set the ride height once, set the pinion angle and be done with it, so I wouldn't go with those.
IMHO, get something with sphericals or heim joints at both ends, not just one. They're a lot easier on torque boxes on hard launches. You don't want anything with a solid bushings. J&M's poly ball setup looks really good as well, kind of a good mix of both worlds. You can get the ones without the adjustable perches for $207.
Old December 21st, 2010, 10:23 PM   #3
Too Soon, Junior!
03 GT Vert
I was thinking the exact same thing on the height adjustable LCAs. I feel like it'd be annoying to have to set the pinion angle multiple times.
Though I was told to avoid LCAs with poly bushings on both ends as they don't articulate much and thus wouldn't decrease suspension bind as much as a poly/spherical LCA. I would go with a spherical bearing on both ends but peeps have said that it transmits a lot of noise into the car, so that's the reason every link up there is to some form of poly/spherical LCA.
Old December 21st, 2010, 10:29 PM   #4
jonnyspeed is on a distinguished road
jazzer where are you? i think hell rec. the maximum motorsports HD
Old December 21st, 2010, 10:46 PM   #5
Abyssinian of AX
Jazzer The Cat's Avatar
'02 Saleen
19.34@42.259
Jazzer The Cat has a brilliant futureJazzer The Cat has a brilliant futureJazzer The Cat has a brilliant futureJazzer The Cat has a brilliant futureJazzer The Cat has a brilliant futureJazzer The Cat has a brilliant futureJazzer The Cat has a brilliant futureJazzer The Cat has a brilliant futureJazzer The Cat has a brilliant futureJazzer The Cat has a brilliant futureJazzer The Cat has a brilliant future
You pepes don't need me to chime in here, you guys KNOW what I'm gonna say
Un-Official Suspension Guide | Choosing a new tire | Brakes upgrade ~ Speeding up slowing down | T-3650 ~ T-56 swap | Tire and Wheel Fitment Guide | The Kitty makes front page news
Originally Posted by Novanutcase View Post
"... although Jazzer's view is a little skewed since he pushes his car HARD so his opinion as to what works is more rooted in extreme circumstances!
Threads Similar to: Choosing a lower control arm
UPR lower control arms. freefallin2000 99-04 9 May 17th, 2010 02:36 PM
Best rear lower control arms? need control.. Speeddemon 94-95 6 April 19th, 2010 02:55 AM
BMR Lower Control Arm Brackets 06GTMustang89 2005 - 2010 29 September 9th, 2009 10:04 AM
lower control arm help energiesource 99-04 23 July 23rd, 2009 11:16 AM
lower control arms reeds98gt General Tech 6 November 19th, 2006 11:27 AM
