tuning issue???
Old December 21st, 2010, 09:31 PM   #1
K_Boss01GT's Avatar
2012 5.0
N/A
K_Boss01GT is on a distinguished road
tuning issue???
Well i got my car out of the shop yesterday and it was running great until this morning when it wouldnt turn over... When it finally did i couldnt let it drop below 1000 rpms without dying.. i called up my tuner and was informed to reinstall the tune and it should correct the tune. After doing so i started to run fine but we cant help but think if its either a tuning issue or if it has something to do with the ecu itself not retaining the tune.. I need opinions on what this issue may be... thx for any input
2012 Black GT, 3.73, bassani axel backs, MGW shifter ordered!!!
MFE - If Engines can't fix it, your're f#@ked
http://www.wpclipart.com/armed_services/airplanes/airplanes_2/EC-130H_Compass_Call.jpg
Old December 21st, 2010, 09:32 PM   #2
ajm
* waits for everyone to say "clean the iac"*
Old December 21st, 2010, 09:47 PM   #3
K_Boss01GT's Avatar
2012 5.0
N/A
was cleaned by my tuner when he ran into the problem
Old December 22nd, 2010, 09:36 AM   #4
K_Boss01GT's Avatar
2012 5.0
N/A
Well i changed out my iac and it didnt work.. It actually hapens more fequently... Can it be aomething else? Or just nit getting the tune right.... Has anyone run into a problem like this before?
Old December 22nd, 2010, 03:03 PM   #5
Willy Mo's Avatar
Willy Mo is just really niceWilly Mo is just really niceWilly Mo is just really niceWilly Mo is just really niceWilly Mo is just really nice
o2 sensors may be shitting out on ya.
Old December 22nd, 2010, 04:13 PM   #6
tbirdscwd's Avatar
12.88 @ 109.45 N/A
tbirdscwd is a name known to alltbirdscwd is a name known to alltbirdscwd is a name known to alltbirdscwd is a name known to alltbirdscwd is a name known to alltbirdscwd is a name known to all
iTrader: -1 reviews
It won't turn over (as in wonk crank when you turn the key)....or it won't start running. Those are two very different things which would point in different directions.
Fun: 2004 Mustang GT
DD: 1994 Ram 2500 Cummins 4x4
Borla "Stinger" Exhaust Vids
Old December 22nd, 2010, 07:35 PM   #7
K_Boss01GT's Avatar
2012 5.0
N/A
itll do both... at times it wont crank and at times like in my driveway itll idle fine bounce a little then just cut out... i know my mech put some pretty heavy oil in it when he changed the cams but i doubt it could be bogged down from that... is there anyway to clean the o2 sensors or is it just a replacement i need
Old December 22nd, 2010, 09:30 PM   #8
K_Boss01GT's Avatar
2012 5.0
N/A
Ill see if puting in a new tps and cps along with cleaning my maf does the trick.. I put my old iac back on after re cleaning it
Threads Similar to: tuning issue???
mafia issue? maf issue?? help nateCR 99-04 2 September 22nd, 2010 09:00 PM
Tuning your ECM F-15 crew dawg 2005 - 2010 V6 6 April 30th, 2010 10:26 AM
What is everyones opinion on tuning on dyno or street tuning CammedMysticCobra 4V / SVT 33 November 28th, 2009 10:27 PM
Do your own tuning. TROJENHORSE 99-04 11 August 13th, 2008 11:18 PM
help with tuning jrhurst Modular Mustangs 9 April 27th, 2007 04:19 PM
