2003 mustang v6 ;)
slow
![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() iTrader: 2 reviews
another gear thread, on the fence 3.73's vs 3.55's
thought this would be funny but wondered what kind of top speed people are getting out of 3.55 gears. im sure there is a calculator some where but i have no clue where. i dont go to the track much and i could give a crap about gas mileage, i just feel i would enjoy longer gear time. i have 3.73's in my car now and im not to happy with how short each gear is at wot. i have just ordered my detroit locker, 31 spline axles, and full rear end re build kit. i need to order my gears and the choice between the 3.55's vs 3.73's is slowing me down
Supersized Salami Swallower
00 GT
14.043@99.03
I would go with the 3.55s if your not looking to f*** s*** up at the track. Personally, I like hitting high mph in low gears.
2003 mustang v6 ;)
slow
im pretty sure 3.73's will make it to the end of the 1/4 in my car. its cutting it close but i run a 26 inch tall tire. and im going to run 275/60/r15 mt et drags. not sure how well they perform since i have yet to use them.
with my 3.90s I am hitting rev limit in 4th right at the 1/4 gate... i think it just depends on what your power level is and tire hight...
2004 2v GT--3.90's, t3650, H&R SS, 78mm TB, K&N CAI, steeda bump stop kit, HP Blues shocks and struts, soon to have a rear seat delete, light weight driveshaft. |
2003 mustang v6 ;)
slow
making it to the end of the track is important to me but being maxed out is not the top of my list considering i drive it alot on the street. like i said im really wanting more time in gear than shifting every half second. i know i have enough power to make 3.55's fun and it will kick out decent times at the track. im curious how much more top speed i get with 3.55's compaired to my 3.73's. i get 128 mph with 3.73's and a 26 inch tall tire
Moderator
2012 300a gt auto
12.10@116
MM BRACKET RACING CREW CO-FOUNDER BAMA Performance Drag Team Founder 2012 300a GT auto
2003 GT
If you're gonna drive it on the street then there really is only one option....
4.10's!!!! LOL!!! John
SOLD - '03 GT, Max Moto Max Grip Box, Wilwood SL 6 front/DL4 rear Big Brake Kit, Corbeau Seats, MGW Short Shifter, MAC Long Tube Headers/Prochamber mid/ Flowmaster 40, FRPP 4.10, TrickFlow Diff Cover/75mm TB/Plenum, Eaton Posi, Moser 31 spl Axles |
2003 mustang v6 ;)
slow
i cant be mad at you cause you probably have a mental problem, but you have not read any of this thread, unless your joking of course. 4.10 are out of the question. i dont feel like coasting at the end of the track, or running 5th gear. you would know this if your car put down any kind of power other wise i would have just looked up an old post on 4.10's vs 3.73's
2003 gt
5.4 32v on the way
check the link in my sig, id do a copy/paste for the link but i cant see my sig right now.
2003 Mustang gt - usual mods - slowly working on 5.4 swap 2004 srt4 - Stock DD/winter beater Click here for your tuning needs Before asking a gearing related question click THIS link and enjoy all your saved time. |
Not much of a difference. It's the same debate as 3.90 vs. 4.10. I have 4.10 and do all city driving without an issue so you cant be shifting that much with 3.73's.
![]() 2003 DSG Mustang GT 5spd Full Bolt On's, Suspension, Built Rear, V1 S N/A: 266/300, 3,550lbs, 13.44 @ 100.5 1.77 60' Non-intercooled: 356/371, 3,575lbs, 12.81 @ 110.47 1.86 60' Intercooled: 362/370 |
You shoulnt even be close to redline with the mods you have listed.
12.73@111.36
There is only a 5% difference between them. But, if that's what keeps you from running out of gear, then that's what you need.
ProCharger P-1SC, 9 psi, STD 396/383; Uncorrected 388/375; SAE 383/370 Mods list in Garage. |
#13 | |
Bringing Yellow Back
![]() edit. but in you case i would do with 373s, once my car makes more power i will change to 373s
![]() SOON TO BE 5.4 3V POWERD WITH A ROUSH CHARGER HELPING IT ![]() BAMA Performance Drag Team Member #4 |
You should still have plenty of room unless you didn't use a handheld tuner to calibrate your gears or tire height. Those tires should be 25.9" tall which by redline will give you ~ 111mph with 4.10's.
yea, i have to work on my 60 foot, also i do have a hand held
2003 mustang v6 ;)
slow
its not the low speed shifting im talking about its the wot 1st and 2nd gear, i smack the red pretty quick. plus im positive im going with the 3.55's.
I am also running a different tire than stock, and at "my" redline is 115mph (as "my" speedo reads) I could be off a little but I dont push the car past 5.5k as there really isnt any point, I dont make much power up there.
I understnd what you are talking about 1st and second. Honestly I would just run different tires. I wanted 3.55's but everyone talked me into 3.73s and I love them. If you do go 3.55's please let us know how you like them.
2003 mustang v6 ;)
slow
here is what i do know on the dyno my car pulls 126-128 4th gear with my tires and 3.73's now im almost sure my car will make it to the end of the quarter mile with 3.73's i think i would be happier with 3.55's.
none the less i have to hurry and make up my mine cause parts are showing up and this came in today
#20 | |
Good luck, i know what it is like when parts start coming, I spent a good month debating in my head between 3.73 and 4.10 so I compromised with the 3.90.
Threads Similar to: another gear thread, on the fence 3.73's vs 3.55's
| 3.55's or 3.73's with my aodewon't work? help | riggsracin | 5.0 Mustangs | 3 | January 3rd, 2010 08:01 PM |
| 3.55's or 3.73's | White 89 | 5.0 Mustangs | 31 | September 7th, 2008 09:46 AM |
| 3.73's/4.10's - gear whine? | Timber | 99-04 | 15 | December 11th, 2007 07:59 AM |
| 3.55's vs 3.73's vs 4.10's for 03-04 Mach 1 | TheBusher | 99-04 | 11 | September 3rd, 2007 09:07 PM |
| need help with gear swap to 3.73's | roscoe | 5.0 Mustangs | 7 | April 22nd, 2007 08:20 PM |
