k member install
Just finished installing an AJE tubular k member in my car, just thought I'd post some pics and info about the install for anyone interested in doing it to their car. It cleared up a LOT of room for headers and for the 5.4 i plan on dropping in after christmas.
Note: Your car will need to be ALIGNED... didn't think about it and my wheels were pointed in interesting directions haha Step one: jack up the car enough to get the k member out, and support the engine with a lift ![]() Since you'll only be supporting the front weight of the engine, you can use the two bolts in the front timing cover, this lets you tilt the engine to align it
02 GT --> long tube headers w/ x pipe and flow masters, throttle body w/ intake plenum, cold air intake, short throw, 255 nitto 555's all around, 373 diff gears, 2 inch lowering kit w/caster camber plates, sony radio working with stock system
I can barely see my passenger side header with the stock k member
![]() I didn't want to seperate the bottom ball joint, so I kept the spindle attached to the a-arm, since I was using the stock a arms. Jack up the a-arm slightly and remove the strut, caliper, steering, and anti-roll bar. Lower the a-arm with the jack to remove the spring.
After both a-arms have been dropped, remove the steering rack from the k-member, and support the k-member with a jack. Loosen the motor mounts (the single nut is a lot easier) and remove the 8 k-member bolts. Then drop the k-member out.
![]() New vs old. With this kit, the motor mounts were a pain. When installing, I had to jack the new k-member up and install the motor mounts on the k-member before bolting them to the engine. You will have to remove the dipstick on the passenger side
To get everything to line up, I had to loosen the transmission mount to allow the motor to slide forward a bit more. I used a punch to align the k-member, but it still took a lot of prying everything around. After you get the k-member bolted in, everything else is pretty easy, just everything in reverse order.
It gave me a ton more space. ![]() I can tighten my headers with a 3/8 socket wrench now ![]() I would recommend this to ANYONE with headers or future engine plans, It cleared up way more space than I expected. Hope this helps some people, I had trouble finding info on it. If anyone has questions, just PM me
2003 GT
Surprising the weight difference you have when you compare the two......
John
SOLD - '03 GT, Max Moto Max Grip Box, Wilwood SL 6 front/DL4 rear Big Brake Kit, Corbeau Seats, MGW Short Shifter, MAC Long Tube Headers/Prochamber mid/ Flowmaster 40, FRPP 4.10, TrickFlow Diff Cover/75mm TB/Plenum, Eaton Posi, Moser 31 spl Axles |
yeah the weight difference was pretty surprising. Driving it around today, I can feel a lot more from the engine, those poly motor mounts made a big difference. Still kinda hot and cold on the rigid mount, but the extra clearance was definitely worth it.
I'm a little nervous about coil overs since the strut tower was never meant to support the weight of the car, but it would be nice to have the adjustability. I gotta do something with my spring rates, it handles good but it rides like it has no suspension and it doesn't transfer any weight to the rear
nice work man... less weight equals more fun hehe
#11 | |
2012 Brembo Mustang GT
![]() iTrader: 1 reviews
What keeps the top of the coil spring secure on a tubalar k? I haven't seen one yet in person.
![]() 2001 GT Supercharged and Intercooled....387RWHP - SOLD 2012 Brembo GT
2001 Saleen Mustang
12.4@108
nice, how much weight you think you shaved off by doing that?
#14 | |
wheni did my tubular k-member, I did a-arms, coil overs, removed sway bar as well as the bumper suport. It was a lil over 100lbs.
![]() Last edited by Willy Mo; December 23rd, 2010 at 08:26 PM. |
2001 Saleen Mustang
12.4@108
niiiice!
2001 Mustang GT Vert.
did you square the k-member with the rear lca torque boxes or just eyeball it?
I've never installed a k-member so I don't really know how much adjustment there is for this...
Mods in garage |
Threads Similar to: k member install
| K member install help | S281 | 99-04 | 18 | October 5th, 2010 11:16 AM |
| BMR K-Member Install Impressions | scramblr | 2005 - 2010 | 19 | October 14th, 2009 04:50 PM |
| pics of install qa1 k-member | tom2000r | 99-04 | 13 | May 6th, 2008 10:06 PM |
| k member install | droppedbass87 | General Tech | 4 | December 25th, 2006 05:49 PM |
| Tubular K Member Install | droppedbass87 | General Tech | 27 | October 15th, 2006 04:31 PM |
