Weird problem, need some help. - Page 4
Old December 24th, 2010, 01:35 PM   #61
Hooo Ha Ha
sharkbait's Avatar
1997 Mustang GT
11.65 @ 115
sharkbait has much to be proud ofsharkbait has much to be proud ofsharkbait has much to be proud ofsharkbait has much to be proud ofsharkbait has much to be proud ofsharkbait has much to be proud ofsharkbait has much to be proud ofsharkbait has much to be proud of
iTrader: 10 reviews
Check the 02 sensor voltages for the front at idle
What are they in relation to the short term fuel trims when heated up properly
410rwhp 520rwtq @ 12.9 psi
Old December 24th, 2010, 05:48 PM   #62
2000 GT
RyanGT is a jewel in the roughRyanGT is a jewel in the roughRyanGT is a jewel in the rough
Even with open loop tune it did this (bypasses o2 sensors). So i figured o2 was probably ok.
But when it happened o2 was funky, and was a stable reading instead of the normal signal that would look like a wave if you graph it. I was kinda leaning towards o2, since my car runs only on passenger bank (because of kb bypass). So one failing would really make things wacko. But like i mentioned same thing happened exactly with open loop tune
2000 Black convertible GT: KB 15psi, and other goodies...
1971 Datsun 240 z: Header and rebuilt motor. (The DD)
Old December 24th, 2010, 05:49 PM   #63
2000 GT
And it was fine all day today after it was good last night. Hit 7 stores for work. So quite a few full cycles. So F'in weird!
Threads Similar to: Weird problem, need some help.
weird problem 01brknGT 99-04 3 September 18th, 2009 02:08 AM
Weird problem to have gotn20 5.0 Mustangs 8 February 5th, 2009 11:28 AM
Weird LED problem? SUHLeen 2005 - 2010 0 June 4th, 2008 10:19 AM
umm have a weird problem? idle problem? blue03mach1 99-04 16 March 4th, 2008 12:03 PM
weird problem Reggedon 99-04 6 January 9th, 2008 09:40 PM
