need help with lower control arm bolt stuck
LinkBack (1) Thread Tools
Old December 23rd, 2010, 01:35 PM   1 links from elsewhere to this Post. Click to view. #1
2002 mustang gt
quickndslick2 is infamous around these partsquickndslick2 is infamous around these parts
Send a message via AIM to quickndslick2
Unhappy
ok so i go the the last bolt of the lower control arm thats in the torque box, i unscrewd the but and it came out easy, but the bolt dosent seem to want to come out. its loose in there it spins but nothing, used rachet, used impact gun used a pry bar use a can of pb blaster i even hit the shit out of it with a hammer and a bar and nothing, both sides are the same the bolt is loose and dosent want to come out any ideas?
[SIGPIC][/SIGPIC] SLAMMED 02 F/I Mustang GT:eek:
Procharged d1 @ 9psi -- 395rwhp and 400tq
waiting for new shortblock install then back to the dyno
Old December 23rd, 2010, 02:09 PM   #2
2002 mustang gt
Anyone out there please have any suggestions or anything?? I need to finish this tonight so i can get the car out the shop anything is helpful right now
Old December 23rd, 2010, 02:14 PM   #3
MikeJones's Avatar
13.7@103
MikeJones is just really niceMikeJones is just really niceMikeJones is just really niceMikeJones is just really niceMikeJones is just really nice
burn out the bushing. Good luck.
Wear a nice protective breathing mask too.
Mod6
Bigbore
Kooks
(parting out 2v motor)
Old December 23rd, 2010, 02:21 PM   #4
tbirdscwd's Avatar
12.88 @ 109.45 N/A
tbirdscwd is a name known to alltbirdscwd is a name known to alltbirdscwd is a name known to alltbirdscwd is a name known to alltbirdscwd is a name known to alltbirdscwd is a name known to all
iTrader: -1 reviews
There is pressure on the control arm somehow keeping the bolt from sliding out. Disconnect it from the axle side and then wiggle it while trying to slide the bolt out.
Fun: 2004 Mustang GT
DD: 1994 Ram 2500 Cummins 4x4
Borla "Stinger" Exhaust Vids
Old December 23rd, 2010, 02:21 PM   #5
2002 mustang gt
^^^^ i didnt want to resort to that or gridning either but i dont think theres a bushing there just the bolt goes str8 threw the control arm and thats it
Old December 23rd, 2010, 02:23 PM   #6
2002 mustang gt
tried wiggleing it that didnt work either but i think ur probably right about the pressure because i had the diff just hanging down i will try again tonight with it in place and see if the bolt comes out
Old December 23rd, 2010, 02:36 PM   #7
tbirdscwd's Avatar
12.88 @ 109.45 N/A
iTrader: -1 reviews
Yeah, you need to relieve the pressure on the control arm or the bolt will not come out. Easiest way is to support the diff somehow. If it still gives you trouble, you might want to try disconnecting it from the axle end first.
Old December 23rd, 2010, 02:40 PM   #8
2002 mustang gt
yea i will try with the diff held up in place and hopefully it will come out with ez, wen u say disconnect from axle end first what do u mean?the axle end was already disconnected and the control arm was dangling hittin the floor that side was easy it the bolt thats in the torque box that is a bitch but maybe with the pressure relieve it will help out
Old December 24th, 2010, 11:29 AM   #9
2002 mustang gt
tried the whole pressure thing and still nothing bolt spins in place but does not budge at all
Old December 24th, 2010, 12:24 PM   #10
ndfrspd's Avatar
1998 Mustang GT
1:34.43@13.86
ndfrspd is infamous around these parts
torch that bitch
"The only way to learn about a car truly is to break something and fix it yourself..."
LinkBack to this Thread: http://www.moddedmustangs.com/forums/99-04/196982-need-help-lower-control-arm-bolt-stuck.html
Thread lower control arm bolt stuck...need some advice | Mustang Forums | AllFordMustangs.com | BoardReader This thread Refback September 5th, 2011 07:44 AM
Threads Similar to: need help with lower control arm bolt stuck
Best rear lower control arms? need control.. Speeddemon 94-95 6 April 19th, 2010 02:55 AM
Lower Control Arm Bolt Specs and Measurements moneygreenstang 99-04 0 December 2nd, 2009 11:35 PM
lower control arm help energiesource 99-04 23 July 23rd, 2009 11:16 AM
Lower control arm bolt diameter? Someone refresh my memory... C MY 4D Modular Mustangs 0 March 15th, 2009 02:50 PM
Lower Control Arm Bushings cali 5.0 5.0 Mustangs 3 November 13th, 2006 06:04 AM
