LinkBack (1) | Thread Tools |
#1
2003 mustang v6 ;)
slow
![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() iTrader: 2 reviews
kenne bell bap wire upgrade
i just got my zone 5 modified fpdm so while im in there i figure i will go ahead and do a wire up grade. since im an old man now my memory is kind of shot so i wanted to make sure i have the wires correct. im going to hook up a 30 amp relay to the inertia switch pink blak/brown wires. from there i will run a hard line wire from my power box/battery. i will hook that end into the relay then the other end goes to the fused bap wire and the other to pin 9 on my fpdm. now one thing im not sure of is the pink and black/brown wire goes to pin 9 on the fpdm so should i ground the the other end of the relay?
this is the write up i am gonna go by.
BAP/Wiring Upgrade Installation Directions - SVTPerformance
2003 mustang v6 ;)
slow
thanks man. i know the gt fpdm had diff color wires for the power.
2003 mustang v6 ;)
slow
the gt fpdm wiring is slightly diff than the cobras. our inerta switch is the power wire for our fpdm. now how i want to do it is use the power off the inerta switch to power my relay so i would run the power from the inerta switch into the relay and ground the other end. then the power wire from the battery would go into the relay and out into the bap and connect it directly to the fpdm pin 9.
LinkBack to this Thread: http://www.moddedmustangs.com/forums/99-04/197024-kenne-bell-bap-wire-upgrade.html
| Thread kenne bell bap wire upgrade | Forums at Modded Mustangs | BoardReader | This thread | Refback | April 12th, 2011 11:21 PM | |
Threads Similar to: kenne bell bap wire upgrade
| Kenne bell bap | Jucostud | 2005 - 2010 | 3 | August 4th, 2010 08:18 AM |
| 2.8 kenne bell or? | 2000roush | 2005 - 2010 | 19 | August 6th, 2008 05:54 PM |
| kenne bell s/c | 969800gt | 99-04 | 5 | January 27th, 2008 11:57 AM |
