Heated PCV valve
Old December 23rd, 2010, 10:01 PM   #1
Bullitt5566's Avatar
2001 Mustang Bullitt 5566
Bullitt5566 is on a distinguished road
Heated PCV valve
I finished removing the EGR valve, solenoid, DPFE sensor, and bracket today on the Bullitt. While I'm there I start looking at this crazy PCV setup that runs coolant from the heater hose, around the PCV valve and around the vacuum connection on the manifold. I'm pretty sure the smart ford engineers went through all that trouble to heat the PCV for some reason, but I seriously can't think of one. Does anyone know?
True Blue Bullitt 517hp 456tq
Vortech
| Aftercooler | MHS Blower Cams | MAC LT | Lethal Xpipe | SLP PowerFlo | MM RCA TQA PHB FLSC
Old December 23rd, 2010, 10:28 PM   #2
stal94gt's Avatar
2003 mustang v6 ;)
slow
stal94gt has much to be proud ofstal94gt has much to be proud ofstal94gt has much to be proud ofstal94gt has much to be proud ofstal94gt has much to be proud ofstal94gt has much to be proud ofstal94gt has much to be proud ofstal94gt has much to be proud ofstal94gt has much to be proud of
that sounds a little crazy, im not sure about bullits but i have never seen that style of valve. i know my car has the older push in stlye but on the newer ones the diff i have seen is a larger hose and a twist off valve
Old December 23rd, 2010, 10:59 PM   #3
The PCV still press fits into the valve cover, but it has a coolant line around it. I just don't understand why they would go through that trouble.
Vortech
Old December 24th, 2010, 08:20 AM   #4
1999 GT 35th LE
99GT35thLE has a spectacular aura about99GT35thLE has a spectacular aura about
It must only be a Bullitt thing, I've never seen that before on the GTs.
I would remove all that coolant hose if were me.
Drive it like you stole it
Old December 24th, 2010, 08:29 AM   #5
2000 GT
RyanGT is a jewel in the roughRyanGT is a jewel in the roughRyanGT is a jewel in the rough
That seems like a headache if coolant lines cracked. Sounds more like the work of the environmental side than ford engineers.
2000 Black convertible GT: KB 15psi, and other goodies...
1971 Datsun 240 z: Header and rebuilt motor. (The DD)
Old December 24th, 2010, 11:31 AM   #6
S281 is on a distinguished road
its a bullitt only thing. seems like some of the bullitt mustangs intended for colder climates had those. I have a bullitt intake swap and just plugged the lines and got a non heated PCV valve, so much cheaper.
2002 4.6L 5spd w/bolt ons
intercooled/Vortech V3 Si trim
Old December 24th, 2010, 01:23 PM   #7
cliffyk's Avatar
cliffyk is a glorious beacon of lightcliffyk is a glorious beacon of lightcliffyk is a glorious beacon of lightcliffyk is a glorious beacon of lightcliffyk is a glorious beacon of lightcliffyk is a glorious beacon of light
There's a lot of water vapour in the crankcase fumes, and as other's have said this is likely a colder climate thing to keep the PCV valve from icing.
Odd that they would do it that way however--there are electrically heated PCV valves on some Fords?
-cliff knight-
My Mustang
2003 GT, UPR X, 24lb/h injectors, Magnaflow, 180° stat,
PP 70mm TB & plenum, DF Commando, Steeda UDPs,
Ralco RZ_flywheel, RAM HDX clutch, WX EFX COPs
3.73s, 262 rwHP/305 lb-ft.
Flex-fuel: burns gas and rubber...
Old December 24th, 2010, 02:17 PM   #8
MeanChad is on a distinguished road
Not true,I have seen these on GT's that were produced in colder climates.
2003 Mustang GT:Blown and fully built
Old December 24th, 2010, 06:00 PM   #9
Willy Mo's Avatar
Willy Mo is just really niceWilly Mo is just really niceWilly Mo is just really niceWilly Mo is just really niceWilly Mo is just really nice
first time ive heard of this. If it were me i woudl delete the coolant lines and get a non heated PCV valve.
Old December 24th, 2010, 08:47 PM   #10
wierd, then its just a colder climate thing i guess.
Threads Similar to: Heated PCV valve
Heated seats??? Cruzzer08 99-04 11 November 23rd, 2010 03:58 PM
Still over heated Sapper Daddy Classic Mustangs 1 September 15th, 2010 08:57 AM
Over heated Sapper Daddy Classic Mustangs 1 August 2nd, 2010 10:50 PM
heated seats memphismustang87 96-98 36 September 30th, 2007 03:26 AM
heated pcv valve question kellie_27 2005 - 2010 0 January 6th, 2007 05:45 PM
