Procharger Cold Startup
Old December 23rd, 2010, 10:33 PM   #1
jonnyspeed is on a distinguished road
When i start my car when its cold the procharger pulley chirps... then stops when it warms up what should i do? i spray wd40 in it when its cold and it stops if for like 10 seconds
Old December 23rd, 2010, 10:42 PM   #2
stal94gt's Avatar
2003 mustang v6 ;)
slow
stal94gt has much to be proud ofstal94gt has much to be proud ofstal94gt has much to be proud ofstal94gt has much to be proud ofstal94gt has much to be proud ofstal94gt has much to be proud ofstal94gt has much to be proud ofstal94gt has much to be proud ofstal94gt has much to be proud of
dont spray wd40 on it for one, unless you like getting belt slip and loosing boost. if its making sound i would look into one of the idler pulleys next to it but if it is your head unit then it is most likely a bearing in it.
Old December 23rd, 2010, 10:45 PM   #3
Eagle2000GT's Avatar
12.73@111.36
Eagle2000GT is a splendid one to beholdEagle2000GT is a splendid one to beholdEagle2000GT is a splendid one to beholdEagle2000GT is a splendid one to beholdEagle2000GT is a splendid one to beholdEagle2000GT is a splendid one to beholdEagle2000GT is a splendid one to behold
I've had worn belts do that. When was the last time you changed the belt?
ProCharger P-1SC, 9 psi, STD 396/383; Uncorrected 388/375; SAE 383/370
Mods list in Garage.
Old December 23rd, 2010, 10:49 PM   #4
belt looks good no cracks, and i cant see what boost i make cas idk how to hook up my boost gauge fml
Old December 23rd, 2010, 10:53 PM   #5
my tuner said i need a 1 inch smaller belt could that be it?
Old December 23rd, 2010, 11:04 PM   #6
2001 Mustang GT Vert.
cbjohnson9 will become famous soon enoughcbjohnson9 will become famous soon enough
I spliced a T fitting into one of the vacuum tubes off my plenum.
Mods in garage
Old December 23rd, 2010, 11:05 PM   #7
stal94gt's Avatar
2003 mustang v6 ;)
slow
take a look at your tensoner, if it is not in the middle or higher you may need a shorter belt.
Old December 23rd, 2010, 11:53 PM   #8
tbirdscwd's Avatar
12.88 @ 109.45 N/A
tbirdscwd is a name known to alltbirdscwd is a name known to alltbirdscwd is a name known to alltbirdscwd is a name known to alltbirdscwd is a name known to alltbirdscwd is a name known to all
iTrader: -1 reviews
Prochargers are much much louder when they are cold. Mine almost always sounded like it was chirping til it warmed up and then just made the distinct Procharger whistle
Fun: 2004 Mustang GT
DD: 1994 Ram 2500 Cummins 4x4
Borla "Stinger" Exhaust Vids
Old December 23rd, 2010, 11:56 PM   #9
this mount seem like a stupid question, but the unit does have the correct amount of oil in it right?
Mods in garage
Old December 24th, 2010, 12:08 AM   #10
yea right oil amount
Old December 24th, 2010, 11:47 AM   #11
my friend had a procharer and he said he never checked the oil, then it broke and he looked inside to find the oil turned to powder.
Old December 24th, 2010, 12:30 PM   #12
blownstang's Avatar
blownstang has a spectacular aura aboutblownstang has a spectacular aura aboutblownstang has a spectacular aura about
lol... aren't you supposed to change it like every 5,000 miles? My Vortech doesn't make any weird noises when starting it in 20 degree weather. A couple times I heard it whislte a little louder for like the first 3 seconds.
2003 DSG Mustang GT 5spd
Full Bolt On's, Suspension, Built Rear, V1 S
N/A: 266/300, 3,550lbs, 13.44 @ 100.5 1.77 60'
Non-intercooled: 356/371, 3,575lbs, 12.81 @ 110.47 1.86 60'
Intercooled: 362/370
Old December 24th, 2010, 12:31 PM   #13
its the pulley
Old December 24th, 2010, 03:35 PM   #14
Could someone put up a pic of the splice you made? and ones of how you got it to your gauge
Threads Similar to: Procharger Cold Startup
New Engine Sounds dry at startup when cold Mustang46 99-04 12 September 10th, 2010 07:04 PM
Procharger Cold Air ? Weidmansheil 2005 - 2010 5 May 16th, 2010 03:03 PM
My 358 Startup teal89 5.0 Mustangs 0 June 8th, 2008 01:08 PM
odd startup mscribellito V6 Mustangs 6 April 1st, 2008 11:51 AM
First Startup of 306 viper3508 5.0 Mustangs 18 February 8th, 2008 07:45 PM
