Header Bolts? Help!!
I just bought a set of pypes shorty headers, what is the best header bolts to use? I dont want them to loosen up. What is the best idea? What have you had the best luck with? Thanks guys!!
2003 ford mustang gt
13.9 stock
i would like to know too subscibed
k&n cai, mangaflows exhaust, summit udp's, 24lb injectors, 78mm bbk plenun, tri-ax s/s, a/c delete,3.73's, aluminum drive shaft, upr upper/lower control arms, solid motor mounts, bbk heades, upr xpipe,bbk cc plates, camber bolts.bama tune
I just use factory metal gaskets and the factory studs/nuts, never had a problem out of them. I put just the smallest dab of blue thread lock on there and never look back
13.4@101 wheel spin
I just got some mac LT's and ill be using copper gaskets with stage 8 locking bolts...
02 GT K&N CAI no cats FRPP drop diablo programmer cherry bomb mufflers MGW short throw shifter TFS UDP's 3.73's... Looking into some shorty headers upper intake got a 75mm tb waiting ... Ironhorsemotorsports.com for all your ford needs! |
theres about 4 or 5 bolts when installing long tubes that are a bitch to try and push the lock piece of the stage 8's on. Enjoy that battle lol
1996 Mustang
I take myself way too seriously.
Moderator
2012 300a gt auto
12.10@116
+1^ good luck wih stage 8's.
MM BRACKET RACING CREW CO-FOUNDER BAMA Performance Drag Team Founder 2012 300a GT auto
13.4@101 wheel spin
...thats what the guys doing the install told me to get lol... Theyre battle not mine... Lol and they said coppers the best... I believe its sce copper gaskets...
1996 Mustang
Sucks to be him then. Has he ever installed 4.6 long tubes? Anyone who has that I know either says "never doing it again" or "you will pay me alot of money"
2001 Mustang Bullitt 5566
+1 on stage 8 bolts. I've used then on two installs. The only thing worse than installing long tubes, is installing leaking long tubes.
![]() True Blue Bullitt 517hp 456tq Vortech | Aftercooler | MHS Blower Cams | MAC LT | Lethal Xpipe | SLP PowerFlo | MM RCA TQA PHB FLSC |
long tubes are cake 4 hrs and its done, Ford OEM gaskets and the ford studs/nuts is all I will ever use, never had a leaker yet
I just installed Bassani Mid length headers and used Stage 8 locking bolts. Bassani headers are soooo easy to install because each tube is seperate and bolts on by itself, Man that makes it such a pleasure to install. I also used percy seal 4 good gaskets, which are cheap and re usable.
2002 4.6L 5spd w/bolt ons intercooled/Vortech V3 Si trim |
13.4@101 wheel spin
He has installed several longtubes shorties 4.6 5.4... He owns a shop and does nothing but mustangs and fords... And like he said do it once do it right :-) an the macs are like that individual flanges for each tube
are you buyin the stage 8's and sce gaskets or is he buying them for you? and FUCK letting a shop work on a car, great time to learn/bond with friends make a great story
13.4@101 wheel spin
Na ill prolly help him and no im ordering... But na hes a close friend its not a like regular mechanic shop... Go to teamironhorse.com and check it out...Hes doing my heada cams and headers all at once... Icant do that in a weekend by myself and during week i can drop it off with him an catch a ride to work
13.9 stock
i agree aint nothing like working on ur own car with a friend or to talking shit lol might take longer but alot of fun lol did my shorties with a friend now doing the long tubes soon
1998 Mustang GT
1:34.43@13.86
use ford studs or make sure you buy actual header bolts, then dab some blue locktight on there and ull be straight.
![]() "The only way to learn about a car truly is to break something and fix it yourself..." |
Threads Similar to: Header Bolts? Help!!
| Anybody removed all header bolts with k member, motor, and header still in car?(lts) | The Unknown 7 | 99-04 | 50 | November 6th, 2010 07:10 PM |
| Header bolts! | 03_StangGuy | 99-04 | 18 | June 6th, 2010 05:50 PM |
| header bolts?? | g19n87r | V6 Mustangs | 6 | February 24th, 2010 02:01 AM |
| header bolts | hopper | 5.0 Mustangs | 19 | March 12th, 2009 04:18 PM |
| Help with header bolts - Locking header Bolts? | Rush | 94-95 | 4 | February 4th, 2009 04:37 PM |
