Still fuel spiking WTF! - Page 3
Old December 28th, 2010, 01:13 AM   #41
WhiteVenom's Avatar
99 Cobra :p
12.36@119.35
WhiteVenom is just really niceWhiteVenom is just really niceWhiteVenom is just really niceWhiteVenom is just really niceWhiteVenom is just really nice
Send a message via AIM to WhiteVenom
Its just odd that the car has absolutely no symptoms. Even if it is my FPDM is there any issue from this?
MM COBRA CLUB #80
SRA SWAP WRITE UP!
Old December 28th, 2010, 07:08 AM   #42
'00 gt, '95 gt, '83 lx
11.85@116
bottled2v is a jewel in the roughbottled2v is a jewel in the roughbottled2v is a jewel in the rough
Send a message via AIM to bottled2v
do you have any type of way to monitor your fuel trims? like a handheld tuner or even one of those little code readers? that would be a good way to see if it's really that high of psi, because at twice what it should be it'll deff be running rich.
'00 GT, hp 292's, full bolt ons, built/stalled auto, 4.10's, 150 shot-new times to come.
'95 GT, 347, tko, etc-11.8@116-sold.
WTT-my mildly built 4r70 for t56/tko.
Old December 28th, 2010, 02:22 PM   #43
WhiteVenom's Avatar
99 Cobra :p
12.36@119.35
Nope. I did have a scanner tool but a friend borrowed and never returned it...
MM COBRA CLUB #80
SRA SWAP WRITE UP!
Old December 29th, 2010, 11:47 AM   #44
Trick Tuners's Avatar
KB'd GT
Don't sweat it, if the car runs fine then its fine. It can be tuned out a bit, but there will always be a spike on returnless cars. Read this thread for more info.
Returnless hesitation issue - Trick Tuners Forums
Old December 29th, 2010, 02:47 PM   #45
WhiteVenom's Avatar
99 Cobra :p
12.36@119.35
Idk i was told if the pressure is too high it can get in vaccum lines and into the plenum but idk?
MM COBRA CLUB #80
SRA SWAP WRITE UP!
Old December 29th, 2010, 02:48 PM   #46
WhiteVenom's Avatar
99 Cobra :p
12.36@119.35
You would think if the 100 psi was bad i would notice on how it runs. Runs perfect with no issues. I would not even know if it were not for the gauge. I still think i should work on fixing it. I think im going to buy a mechianical gauge soon. Its not really important right now. I got bigger stuff to deal with like my SRA swap and my IRS sitting on the ground lol.
MM COBRA CLUB #80
SRA SWAP WRITE UP!
Old December 29th, 2010, 08:03 PM   #47
KB'd GT
Only if you burst the FRPS. That can happen with high transient spikes.
Then don't worry about it
Old December 29th, 2010, 08:21 PM   #48
Shaun03GT's Avatar
2003 Mustang GT
Shaun03GT has a brilliant futureShaun03GT has a brilliant futureShaun03GT has a brilliant futureShaun03GT has a brilliant futureShaun03GT has a brilliant futureShaun03GT has a brilliant futureShaun03GT has a brilliant futureShaun03GT has a brilliant futureShaun03GT has a brilliant futureShaun03GT has a brilliant futureShaun03GT has a brilliant future
iTrader: 12 reviews
Did you try your buddy's FMDM?
I will say atleast the fuel isnt cutting out.
Vortech V1 Intercooled @ 11psi
394rwhp/392rwtq @ 9.5psi
415rwhp/400rwtq @ 11psi on Methanol
Tuned By: Pete @ Performance Dyno
Affordable Supercharger Build Guide
Supercharger Info for Noobs
Old December 29th, 2010, 10:31 PM   #49
WhiteVenom's Avatar
99 Cobra :p
12.36@119.35
no i havent.. I wanna test the mechanical fuel pressure. if its really 80 psi etc then i will fix whatever it takes. If it shows normal then ill just forget about it till i have some extra cash to investigate.
MM COBRA CLUB #80
SRA SWAP WRITE UP!
Old December 30th, 2010, 12:32 PM   #50
KB'd GT
If you don't want any spike then your fix is going to be a return fuel system. You can tune it down, but you will always see a blip in the datalogs on the returnless fuel system. Throwing parts at it will do nothing. You can remove the pprv and that may help a little (and is free!)
Old December 30th, 2010, 02:36 PM   #51
WhiteVenom's Avatar
99 Cobra :p
12.36@119.35
It shouldnt spike on every single rev. Regardless of my fuel system 100 psi every time i hit the gas is not normal.
MM COBRA CLUB #80
SRA SWAP WRITE UP!
Old December 31st, 2010, 12:37 PM   #52
KB'd GT
Its far more normal than you seem to think, but 100psi is pretty high. It could also be that your gauge is out of calibration, or if its electric it can be over reacting. IMO aftermarket electronic FP gauges are all crap. The frps in a datalog is FAR more accurate, but I know you are not using that because the sensor pegs at 90psi.
Threads Similar to: Still fuel spiking WTF!
Datalogging Fuel Pump Volts with a BAP and Fuel Flow Rates Trick Tuners 99-04 21 November 18th, 2010 08:44 PM
Four cylinder fuel economy compared to v6 and v8 fuel injected models Rivguy 2.3 Mustangs 5 September 22nd, 2010 12:30 PM
Four cylinder fuel economy compared to v6 and v9 fuel injected models Rivguy 2.3 Mustangs 0 July 21st, 2010 08:04 PM
Spiking a WaterMelon G.T. Rags The Clubhouse 25 July 4th, 2009 01:26 PM
