Still fuel spiking WTF!
Old December 27th, 2010, 08:43 PM   #1
WhiteVenom's Avatar
99 Cobra :p
12.36@119.35
WhiteVenom is just really niceWhiteVenom is just really niceWhiteVenom is just really niceWhiteVenom is just really niceWhiteVenom is just really nice
Send a message via AIM to WhiteVenom
Well i borrowed my buddies FRPS and i spiked 85psi still just tapping the gas in neutral up to 3,000 rpms or so. Just another point to when i take off my FRPS gas shoots like 5 feet in the air and my buddies never did that. Mine does it every time. I found a random vaccum line not connected to anything behind my EGR but can't find where it might go. Looks like just a breather hose or something. Any suggestions now? WTF!
MM COBRA CLUB #80
SRA SWAP WRITE UP!
Old December 27th, 2010, 08:47 PM   #2
2001 Bullitt
12.25@110.4
Bullitt5339 is a glorious beacon of lightBullitt5339 is a glorious beacon of lightBullitt5339 is a glorious beacon of lightBullitt5339 is a glorious beacon of lightBullitt5339 is a glorious beacon of lightBullitt5339 is a glorious beacon of light
Are you still relying on your fuel pressure gauge, or did you measure it with a mechanical gauge yet?
Old December 27th, 2010, 08:50 PM   #3
WhiteVenom's Avatar
99 Cobra :p
12.36@119.35
still relaying on gauge. Its been in for 2 years and never read over 50 psi once until beating the shit out of the car at the track. The fuel shooting 5 foot in the air seems to relate back to the whole 85 psi idea. That gauge is 40 bucks so i guess i can drop the cash on it but seems like a waste.
MM COBRA CLUB #80
SRA SWAP WRITE UP!
Old December 27th, 2010, 08:55 PM   #4
2001 Bullitt
12.25@110.4
You need to find someone with a mechanical gauge, X3 or a real scantool to monitor what your fuel pressure really is before you waste money replacing parts.
Old December 27th, 2010, 08:56 PM   #5
1999 GT 35th LE
99GT35thLE has a spectacular aura about99GT35thLE has a spectacular aura about
The vacuum lines on the driver side go to the FRPS and the EGR valve. There are some vacuum lines on the EGR module but I forget what it's called.
Drive it like you stole it
Old December 27th, 2010, 08:58 PM   #6
WhiteVenom's Avatar
99 Cobra :p
12.36@119.35
DPFE..
lol i know what goes to the FRPS and EGR.
MM COBRA CLUB #80
SRA SWAP WRITE UP!
Old December 27th, 2010, 09:05 PM   #7
WhiteVenom's Avatar
99 Cobra :p
12.36@119.35
Time to play, NAME THAT VACUUM LINE!! Heres a pic. It looks like it has residue on the back on the line so it must go somewhere
MM COBRA CLUB #80
SRA SWAP WRITE UP!
Old December 27th, 2010, 09:07 PM   #8
Shaun03GT's Avatar
2003 Mustang GT
Shaun03GT has a brilliant futureShaun03GT has a brilliant futureShaun03GT has a brilliant futureShaun03GT has a brilliant futureShaun03GT has a brilliant futureShaun03GT has a brilliant futureShaun03GT has a brilliant futureShaun03GT has a brilliant futureShaun03GT has a brilliant futureShaun03GT has a brilliant futureShaun03GT has a brilliant future
iTrader: 12 reviews
Thats wierd. Although, I would think the fuel shooting in the air would be normal.
You should see if autozone scantools let you view live data and read your Fuel pressure. 85psi jesus lol. What are you going by that says 85psi?
Vortech V1 Intercooled @ 11psi
394rwhp/392rwtq @ 9.5psi
415rwhp/400rwtq @ 11psi on Methanol
Tuned By: Pete @ Performance Dyno
Affordable Supercharger Build Guide
Supercharger Info for Noobs
Old December 27th, 2010, 09:09 PM   #9
stal94gt's Avatar
2003 mustang v6 ;)
slow
stal94gt has much to be proud ofstal94gt has much to be proud ofstal94gt has much to be proud ofstal94gt has much to be proud ofstal94gt has much to be proud ofstal94gt has much to be proud ofstal94gt has much to be proud ofstal94gt has much to be proud ofstal94gt has much to be proud of
the only hoses that i know that are made that size that are around that area are the 2 lines that go from the egr pipe to the dpfe, or the evap hose going into the manifold. look down your egr pipe there are 2 fittings where the dpfe sensor goes
Old December 27th, 2010, 09:11 PM   #10
WhiteVenom's Avatar
99 Cobra :p
12.36@119.35
I can get 110psi if i actually rev it up. 85 is just when i tap the gas. My autometer gauge is telling me 85 psi. It runs and drives perfect with no issue. To be 100% honest i would not even know i had a problem if it were not for the gauge readings.
MM COBRA CLUB #80
SRA SWAP WRITE UP!
Old December 27th, 2010, 09:13 PM   #11
stal94gt's Avatar
2003 mustang v6 ;)
slow
try swaping the fpdm out of your buddys car, yours may have over heated and fryed its self
Old December 27th, 2010, 09:18 PM   #12
Shaun03GT's Avatar
2003 Mustang GT
iTrader: 12 reviews
I was acually going to say maybe its fpdm related? Or maybe your gauge is just way the fuck off. Id try to view live data with SCT or a scantool man. But, if you dont have access, do what stal said
Old December 27th, 2010, 09:18 PM   #13
WhiteVenom's Avatar
99 Cobra :p
12.36@119.35
I found where the line went. It went on that DPFE. Theres like two hoses and a plug on the bracket. Still didnt fix my fuel spiking though vaccum line is in though!
MM COBRA CLUB #80
SRA SWAP WRITE UP!
Old December 27th, 2010, 09:21 PM   #14
WhiteVenom's Avatar
99 Cobra :p
12.36@119.35
Maybe i dont have it connected in the trunk or something i guess?
MM COBRA CLUB #80
SRA SWAP WRITE UP!
Old December 27th, 2010, 09:24 PM   #15
stal94gt's Avatar
2003 mustang v6 ;)
slow
do you have a bap on the car?
Old December 27th, 2010, 09:27 PM   #16
WhiteVenom's Avatar
99 Cobra :p
12.36@119.35
no idea..
I looked in my trunk everything is connected. How come that red button is like stuck down? i cant even push it. It wont move when i do its like jammed in or something?
MM COBRA CLUB #80
SRA SWAP WRITE UP!
Old December 27th, 2010, 09:32 PM   #17
Shaun03GT's Avatar
2003 Mustang GT
iTrader: 12 reviews
You dont know if you have a boost a pump? Check your trunk for one.
Also, the red button is the inertia switch. If its pushed down, it means it shut the fuel pump off. So Idk something doesnt seem right?
Old December 27th, 2010, 09:34 PM   #18
WhiteVenom's Avatar
99 Cobra :p
12.36@119.35
yeah it wont move. Its like someone jammed it down or something. Give me about 10 mins guys and i will take a picture of the area. I dont even know what it has for fuel pumps. Kid told me "i think it might have termi pumps but i would'nt know".
MM COBRA CLUB #80
SRA SWAP WRITE UP!
Old December 27th, 2010, 09:36 PM   #19
stal94gt's Avatar
2003 mustang v6 ;)
slow
the button is supposed to be down. when it is poped up it means it needs to be reset.
Old December 27th, 2010, 09:38 PM   #20
WhiteVenom's Avatar
99 Cobra :p
12.36@119.35
Looks so nice back there...
MM COBRA CLUB #80
SRA SWAP WRITE UP!
Threads Similar to: Still fuel spiking WTF!
Datalogging Fuel Pump Volts with a BAP and Fuel Flow Rates Trick Tuners 99-04 21 November 18th, 2010 08:44 PM
Four cylinder fuel economy compared to v6 and v8 fuel injected models Rivguy 2.3 Mustangs 5 September 22nd, 2010 12:30 PM
Four cylinder fuel economy compared to v6 and v9 fuel injected models Rivguy 2.3 Mustangs 0 July 21st, 2010 08:04 PM
Spiking a WaterMelon G.T. Rags The Clubhouse 25 July 4th, 2009 01:26 PM
