#21 |
13.4@101 wheel spin
I forgot to mention that ... My 13.4 and previous 13.6 an 13.8 the time before all had 1.8 60 ft times... Im betting your shifting too late like i was ... i shift at 5k i could prolly hold a lil longer but ill play with that next time... I wanna lower my 60ft first
02 GT K&N CAI no cats FRPP drop diablo programmer cherry bomb mufflers MGW short throw shifter TFS UDP's 3.73's... Looking into some shorty headers upper intake got a 75mm tb waiting ... Ironhorsemotorsports.com for all your ford needs! |
#22 |
2001 Mustang GT
34.82 @ 21
![]() ![]() iTrader: 4 reviews
This thread is ruining my hope of running a 13.9X due to my 285 18" Sumitomos that just do not hook up on launches. What you say is very true tbird, I have my shift light set at 5,600 just because it feels so gutless above that, up to 6K.
Haven't had the Mustang to the track yet, just do a lot of practice runs on a stretch of road near me that has a 1/4 mile marked out. (Bunch of guys run their Jap bikes back there in the summer) I just hope that with the 3.73's, BBK CAI, and if I run the 93 octane tune, I'll be able to put down a 13.9X. Launching is just going to be tricky. Gonna have to use the T/C on launch, and keep it low enough at the same time so it doesn't bog down too much. ....Or I can just steal an aluminum 5.4 out of the 2011 Shelby GT500 and run 11's.
'01 GT - T56 6 Speed - Centerforce DFX - SCT LiveWire - Borla Stingers - Magnaflow Catted X - Steeda Tri Ax - Cobra Aluminum Driveshaft - 3.73s - Eibach Pro-Kit - MM Full Length Subframe Connectors - MM Caster Camber Plates Vortech V1 sold |
#23 |
12.88 @ 109.45 N/A
![]() ![]() ![]() ![]() ![]() ![]() iTrader: -1 reviews
Thanks LOL, just trying to help out.
Myslow makes a goo point about the slicks being a bit lighter and they are "in-sprung" weight which makes even more of a difference. My suggestion to the OP is to get a shift light and ignore the tach. Set your shift light to 5400 and just shift according to the light. Make a couple runs, and see how it does. Then bump it up 50-100 rpm and see what your next couple runs look like. Keep raising the rpm til you see no more gains or any loss of performance. The name of the game is consistency. A shift light will help you with that. Only change 1 thing from one run to another. You need to figure out what changes are actually helping or hurting. You make more than 1 adjustment, you won't be able to tell which is hurting or helping. |
#24 |
MM's Taint Shaver!
2003 Mustang GT
Thanks again everyone. Too be honest with you I think my problem was the guy in the other lane as dumb as that sounds. I started racing against a couple cars that were a good match with mine and I was focusing more on beating them then getting a great time. Another problem I had was hot lapping my car. I was having so much fun beating this s197GT that I kept racing back to back until my clutch finally told to settle down. Im not disappointed with the times I ran but when I go back again ill be focused more on my shift points and launches, then beating the guy beside me. The longest cool down of the night was around 15 minutes when I swapped from the slicks too drag radials. Yea I know its dumb but the fun factor was high and it was my first time at a 1/4 mile track. My shift light is set at 5,800rpm's but I wasn't focusing on it as much as I should have.
#25 |
Moderator
2012 300a gt auto
12.10@116
most things are covered pretty well, but the thing that cant be stressed enough is practice (especially at a drag strip with a stick since the odds are stacked against you making repeatable passes from the start).
generally speaking in my experiance, you'll need about 100 passes to sort out a minor mod, 200+ to sort out a major one.
MM BRACKET RACING CREW CO-FOUNDER BAMA Performance Drag Team Founder 2012 300a GT auto
#26 | |
MM's Taint Shaver!
2003 Mustang GT
It will take me a lifetime too make that many passes. I just want a fun street car that may see the track twice a year. Who knows that could possibly change in the future. Thanks Casper!
#27 | |
Moderator
2012 300a gt auto
12.10@116
you're not gonna see the full gains from any mod without dialing in the car is where I'm going, so my advice would be leave the 3.73's in (much easier to control the rpm's & you wouln't need to be so precise) & get a set of 26" slicks or bias ply dot tires & have fun with it. if your curious, a typical year for someone serious about drag racing usually amounts to 500+ passes a year, thats why its easy to say what I did about taking your time to sort out mods.
#28 | |
MM's Taint Shaver!
2003 Mustang GT
#29 |
12.88 @ 109.45 N/A
Yup, I made about 250 passes this year, but my car broke twice this year including a blown rear end and I did an auto swap. I'm sure if it was up and running all season, I would have been around 500 passes easy
#30 |
Moderator
2012 300a gt auto
12.10@116
light year for me as well last year, minor tune/trans issues, work & cracking my stock intake at Columbus, I made 376.
#31 |
I have 3.90s and spraying 100/125/150 depending on who's jets I can borrow. What size tire should I be running. I get to the line at 5900 rpms in 4th gear on street tires. I have the 17 inch stocker on right now
Black and White Crew ![]() Crew Member # 3 centerforce dual friction,.100 shot freeflow exhaust,70mm accufab tb,professional products plenum, tri ax,3.90s amazing how fast you can go when the road never curves .....lighting up the Canadian prairie |
#32 |
Moderator
2012 300a gt auto
12.10@116
by the sound of what you said there, 26's are right about where you need to be.
Threads Similar to: I hate gearing threads
| I hate, hate, hate these type of people. | shroom | The Clubhouse | 71 | May 24th, 2011 05:02 PM |
| Subscribed Threads and New Threads button at Page Bottom | Daniel0318 | Feedback Forum | 0 | October 30th, 2010 07:31 PM |
| threads about ban threads about unban threads about ban threads | nba1341 | The Clubhouse | 1 | March 24th, 2008 12:50 AM |
| Estimated Hp? ( I know I hate these threads too) | blk98gt | 96-98 | 24 | March 20th, 2008 10:09 PM |
| gearing | Mustang RacR94 | V6 Mustangs | 9 | June 29th, 2007 12:13 AM |
