MM's Taint Shaver!
2003 Mustang GT
I hate gearing threads
I see threads all the time saying 3.73 or 4.10 gears and ever since I went too the track with Baker a couple months ago it's been confusing the hell out of me. When I went my car was just a mild bolt on 2 valve with 3.73 gears. I ran a total of eleven times that night. About five of those runs were on Bakers 28" slicks and the rest on my 26" 555r drag radials. My best time with the slicks was a 13.75@97mph with a 1.88 60ft and the best with my drag radials was a 13.80@97mph with a 1.90 60ft. Now here is my dilema. With the slicks I was able to go thru the traps at the top of third gear and the drag radials forced me into forth so thats a decent gain in gearing but why didn't the taller gearing affect me negatively if its so important? Now I know the difference in gearing between 3.27 and 4.10s is pretty important but some of these threads I see on here make 4.10s sound so superior over 3.73s but the difference in gearing I used at the track that night had to of been pretty close to say comparing my 3.73s to 3.55s right? Im not an expert so thats why im asking everyone here. Logically if the difference between 3.73s and 4.10s is so beneficial then why didn't the taller tires hurt my time or trap speed any? Btw my best trap speed for that night was 98mph. I know I could have had a better time than the 13.75 but my car was bogging pretty bad off the line with both set of tires. Thanks!
12.85 @ 114
are you an auto?
![]() MODS: Vortech V1 T-Trim @ 7.5 PSI (tuned down) Comp Cam Stage 2's + more 432 rwhp / 396 rwtq 02/27/2011 NEW VIDEOS! **It takes ~$60 a rwhp (over stock) for a 99-04 Mustang GT.** Do the Math ![]() C2H5OH on the horizon |
MM's Taint Shaver!
2003 Mustang GT
Sorry its a stick.
![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() iTrader: 14 reviews
dale... your first launch on the slicks was the best i think. That was the 13.75 wasnt it. Car took off pretty nice like. But yeah i think all the others bogged pretty much.
![]() 4.75 MMR 900se Livernois ported heads HP 292s blower cams Procharger D1sc at 20+ psi IW 15% OD pulley (and more bolt ons) E85 ![]() Tune/numbers coming shortly!! |
Should i get 3.73s 0r 4.10 on my car, please help!!!!
12.85 @ 114
The end goal is to be going through the traps at the top of your gear.
Now, you said you are going through the traps in the top of 3rd. Tire diameter of the tire is a way to "fine tune" your car so that you can enter the traps at the correct speed. What you found out is that with your setup and 3.73s, it will take you a 28" tire to go through the traps at your maximum speed. Now, for comparison I have 4.10s and with my regular street tire, I go though the traps at the top of 4th gear (115 mph). Now, if I wanted to increase my speed without running out of gear, I would increase my rear tire diameter. That would then enable me to continue using my 4.10s and to be able to go through the traps at higher speeds
#7 | |
2003 Mustang GT
slow
![]() iTrader: 1 reviews
MM's Taint Shaver!
2003 Mustang GT
Yes your right on everything. First run was damn near perfect.
#9 | |
MM's Taint Shaver!
2003 Mustang GT
2003 Mustang GT
slow
2003 Mustang GT
slow
dale... I'm not sure what your asking. I thought you were asking why a taller tire didn't hurt your trap speed.
12.88 @ 109.45 N/A
![]() ![]() ![]() ![]() ![]() ![]() iTrader: -1 reviews
There are a lot of factors which affect choice of gearing and tire diameter on the drag strip. The fact that you make shit for power off the bottle means you want to get through each gear as fast as possible and maintain as high of an RPM as possible while doing so. That is why most drag guys go with 4.10s at least.
Provided traction off the line is the same and you have a decent driver behind the wheel, an N/A 2v 4.6 with 4.10s will be faster in the quarter that the same car with 3.73s, 3.55s, 3.27s, etc..... With stock heads and cams, a manual 4.6 car needs to shift right at 5500rpm to yield best results.....but doing so brings you back pretty low in the rpm range (3,000-3,500 depending on which gear 2nd 3rd etc) where you don't make much power. The taller (or lower numerical number) rear end gear, the more time you will spend at these lower rpms until you get back into your peak power range. |
very well put tbird!
MM's Taint Shaver!
2003 Mustang GT
Thats kinda the point I was trying make. With those taller tires shouldn't it have negatively affected my times since it was bringing my rpm's back too a lower point after each shift and make my launch worse since first gear was taller. Idk this crap confuses the hell out of me.
Instead I was trapping identical speeds and almost the same times with both tires although their was a 2" difference in tire height. Tire weight and traction was making the biggest difference I guess. Although I was hooking pretty good with both tires.
#15 | |
2003 Mustang GT
slow
12.88 @ 109.45 N/A
Thanks baker.
Dale, you can't just compare best run with the 26s to best run On the 28s with just one trip to the track. Try comparing your average trap speed with the two. This is one of the reasons why figuring out what a manual car sucks. It's so easy to be a tenth of a second off of a few shifts especially when they are coming at you faster with 3.73s or 4.10s on a stick car. If you had a solid grasp of what your car should run and runs repeatedly, you would have something to go off of. But just to take a trip to the track, run a dozen times and compare best to best is not going to really show what your car wants/needs. I say at your power level, a 26" slick is going to be your best bet. Keep up with the shifts and you will be happy enough. A 28" tire is leaving a lot on the table especially with 3.73s. It those had been 26" slicks, you might have scraped a few more 1.8s maybe even a 1.7 and would have been mid to low 13s |
MM's Taint Shaver!
2003 Mustang GT
Thanks tbird! That made alot of sense. My trap speeds were all in the 97 mph range except for one 98 and a couple low ones from screwing up on a run. Another question I have is why are my trap speeds so low? I see cars on here with similar mods breaking into the 100mph range but their times were slower.
13.4@101 wheel spin
My first time out i ran a best of 13.6@98 in 100+ degree weather i went back out in 50-60 degree weather and shifted sooner and cut it down to a 13.4@101 im confused on why your bogging with nitto's i have wheel spin launching with my hoosier dr's and we same gearing and prolly the same mods.. If i hook off the line id prolly be doing low 13s
02 GT K&N CAI no cats FRPP drop diablo programmer cherry bomb mufflers MGW short throw shifter TFS UDP's 3.73's... Looking into some shorty headers upper intake got a 75mm tb waiting ... Ironhorsemotorsports.com for all your ford needs! |
12.88 @ 109.45 N/A
Like anything else, trap speed can fluctuate because of many things. Seeing as how your best run was a 13.75 @ 97 mph with a 1.8 60' tells me that either your shiftpoints are a bit off or that you need some work on shifting faster. A 1.8 60' is worth low 13s on these cars.
2004 Mustang Gt
13.17@106.7 1.8 60ft
tbird is the man
CRAZY HORSE RACING couple of bolt-ons and bolt-offs |
Threads Similar to: I hate gearing threads
| I hate, hate, hate these type of people. | shroom | The Clubhouse | 71 | May 24th, 2011 05:02 PM |
| Subscribed Threads and New Threads button at Page Bottom | Daniel0318 | Feedback Forum | 0 | October 30th, 2010 07:31 PM |
| threads about ban threads about unban threads about ban threads | nba1341 | The Clubhouse | 1 | March 24th, 2008 12:50 AM |
| Estimated Hp? ( I know I hate these threads too) | blk98gt | 96-98 | 24 | March 20th, 2008 10:09 PM |
| gearing | Mustang RacR94 | V6 Mustangs | 9 | June 29th, 2007 12:13 AM |
