Return vs. returnless fuel system - Forums at Modded Mustangs
post #1 of 38 Old January 4th, 2011, 07:17 PM Thread Starter
brett22's Avatar
What are the advantages and disadvantages of a return style fuel system compared to a returnless fuel system. Which is better suited for high engine fuel demands? I am under the impression that the returnless system is better because ford switched from return style to returnless. Right now I have the stock returnless system but it is in need of an upgrade so just wondering which route to go
Mechanical Engineer at Kondex Corporation
brett22 is offline
post #2 of 38 Old January 4th, 2011, 07:26 PM
Procrastinator
If you are keeping within a reasonable hp level a returnless setup will work, but a return style is better because it can cope better with a sudden demand for lots of fuel without losing as much fuel pressure.
DickH is offline
post #3 of 38 Old January 4th, 2011, 07:31 PM Thread Starter
brett22's Avatar
I know dual focus pumps will be good into the 500 hp range but if I were to run dual ford gt pumps shouldn't they be able to provide the extra fuel needed for 600hp under hard acceleration. I think I will just upgrade my current fuel system instead of switching over to the return style
brett22 is offline
post #4 of 38 Old January 4th, 2011, 07:33 PM
Procrastinator
how much power do you plan on making?
DickH is offline
post #5 of 38 Old January 4th, 2011, 07:41 PM Thread Starter
brett22's Avatar
I am looking to be in the 600hp range
brett22 is offline
post #6 of 38 Old January 4th, 2011, 07:49 PM Thread Starter
brett22's Avatar
I have no engine to reference the proper returnless fuel system setup, so is it just a matter of running a y block off the fuel line from the tank and then a line to each of my fuel rails and then on the opposite side of the fuel rails just running a line between the two to equalize the pressure? Is there any fuel pressure sensor? Sorry for the questions just don't know much about the set up and I am not going to buy a kit because I can put a fuel system together for a lot cheaper.
brett22 is offline
post #7 of 38 Old January 4th, 2011, 07:55 PM
BakerFX4's Avatar
iTrader: 15 reviews
return style is better for high demands. I wish i would have done it in the first place. I have redone my returnless system about 5 times now! Not only that.... but with a returnless system, its pretty common to have the "famous" hesitation between shifts that SUCKS ASS!!! Return style is the better way to go HANDS DOWN.
4.75 MMR 900se
Livernois ported heads
HP 292s blower cams
Procharger D1sc at 20+ psi
IW 15% OD pulley
(and more bolt ons)
E85
Tune/numbers coming shortly!!
BakerFX4 is offline
post #8 of 38 Old January 4th, 2011, 09:10 PM
BYAHHHH!
Scott2001GT's Avatar
iTrader: 5 reviews
I was a big returnless guy and was going to keep that. But after researching it I am going return. It's esp better for higher hp E85 cars.
Check out Glenns Performance and everything you need wil be there.
Powered by Ford
Boosted by Precision Turbo and Engine
Thanks to: Wagon Wheel Performance & STL Mustangs
Scott2001GT is offline
post #9 of 38 Old January 4th, 2011, 09:43 PM
stal94gt's Avatar
go with a return style, the only thing i would say is important on a return style fuel system is to have your return line moved away from the pick up line. this will help keep fuel temps down. but returnless is a pain and ends up costing more in the end. the only people who should stay with a returnless system is 400 hp less boosted people and n/a cars.
stal94gt is offline
post #10 of 38 Old January 4th, 2011, 09:59 PM
y2k02's Avatar
Cheaper to stay returnless for only 600rw.
2002 GT~Forged Teksid~ Trick Flow
Big Cams~RR Intake ~160lbers ~E85
Twin 61mm Turbos TH400 & UCC converter
Home built Holley Dominator tuned by me
2016 Mustang GT keeping it stock
y2k02 is offline
post #11 of 38 Old January 4th, 2011, 11:27 PM
stal94gt's Avatar
it is not much cheaper to stay returnless unless you skimp out on parts. a cobra gas tank cost just as much as a return style gas tank, cobra hat/pumps maybe cheap if you can find it any where used, but they are over 400 new if you can even find them new now. then a bap cost 240, your not saving much staying returnless, not to mention returnless systems are not nearly as boost friendly because of the stupid frps senser. not saying it is bad to be returnless its just hard finding the parts at the price to make it worth staying with. oh yeah and a fore hat is rediculus in price.
stal94gt is offline
post #12 of 38 Old January 4th, 2011, 11:49 PM
Shaun13GT/CS's Avatar
iTrader: 27 reviews
What else do you need to go Return style? Cobra tank with hat. Different fuel rails? Or something on the fuel rails? Ive been thinking about switching to return style too, but If its more expensive then keeping it returnless, and returnless can handle the same power as return style then why bother.
14 Mustang GT M6 - TVS, Kooks Full Exhaust, AED Tune
11.04 @ 130.1
621/557 @ 8.6psi
Previous Cars
09 Corvette Z06 - 11.7 @ 123.5 (stock)
13 Mustang GT Bolt Ons - 11.58 @ 122.13
03 Mustang GT Vortech - 11.98 @ 118.68
Shaun13GT/CS is online now
post #13 of 38 Old January 4th, 2011, 11:53 PM
stal94gt's Avatar
simply put a full return system is 1300 dollars. maybe alittle more than a built up cobra returnless system.
stal94gt is offline
post #14 of 38 Old January 4th, 2011, 11:57 PM
iTrader: 27 reviews
Damn, fuel is so god damn expensive. Fuck it Ill stay return style until my tuner tells me I should switch
11.04 @ 130.1
621/557 @ 8.6psi
Previous Cars
post #15 of 38 Old January 4th, 2011, 11:57 PM
mystang0673's Avatar
Does anyone know where the thread is that gives you all the parts needed to put together a return style fuel system? I am about to start building mine... f staying with non return... My dual cobra pumps, bap and 80lb injectors are maxed at around 500hp.... gonna go ahead and get my car ready for a real head unit. ha
mystang0673 is offline
post #16 of 38 Old January 5th, 2011, 12:00 AM
iTrader: 27 reviews
Are you going with the ysi trim? Ill search for the thread cause Im curious too.
11.04 @ 130.1
621/557 @ 8.6psi
Previous Cars
post #17 of 38 Old January 5th, 2011, 12:05 AM
iTrader: 27 reviews
All I could really find was bakers thread
lets talk return style.....
11.04 @ 130.1
621/557 @ 8.6psi
Previous Cars
post #18 of 38 Old January 5th, 2011, 12:06 AM
Im talking with vortech about some different ideas..... But im not gonna slack now.... i figure with a good head unit "3k", a good fuel system "2k" and another 1k in suspension my car could see in the 140mph range in the 1/4.... So, after buying a truck in a month or so, im gonna tell the wife "look, its either me spend 6k on this car at 1 time for parts, or i trade it for a fast fox body"... and she will say that she doesnt want me having a fox. So i win either way... lol
post #19 of 38 Old January 5th, 2011, 12:08 AM
stal94gt's Avatar
Originally Posted by Shaun03GT View Post
Damn, fuel is so god damn expensive. Fuck it Ill stay returnless style until my tuner tells me I should switch
fixed
stal94gt is offline
post #20 of 38 Old January 5th, 2011, 12:10 AM
stal94gt's Avatar
man that is the way i want you to go so bad! i know you would not be happy with a T trim or SI trim. your like me and there is no such thing as too much power.
stal94gt is offline
Human Verification
