trouble code
Old April 17th, 2007, 10:39 AM   #1
Resident Bubblehead
00vabchgt's Avatar
00vabchgt is a jewel in the rough00vabchgt is a jewel in the rough00vabchgt is a jewel in the rough
trouble code
so last night i'm at sonics getting some burgers and i notice that my car's idling funny so i say to myself, "Self, you need to clean your IAC when you get home." for the hell of it, i plugged in my predator to see if it was throwing any codes. sure enough, P0306 shows up- misfire on cylinder 6. anybody have this happen? how bad am i screwed?
Submariners Do It Deeper
Military Crew
MM1 (SS)
Order of the Bluenose
US Navy Veteran
Originally Posted by MamaStang View Post
"Boy Danny....nice cock ya got there. "
Old April 17th, 2007, 10:49 AM   #2
CBSTANG's Avatar
2002 GT
CBSTANG is on a distinguished road
hey 00,
i had a similar code just a different cylinder. I had to replace the cam position sensor and it went away. about 15 dollar fix, also with mine the longer i went w/o changing it the worse it ran. Just food for thought bud. Good luck!
MUSTANG!!!
An American legend. The original pony car and muscle car, born on April 17th 1964. The car all other manufacturers tried tried and are still trying to emulate!
Old April 17th, 2007, 10:57 AM   #3
Resident Bubblehead
00vabchgt's Avatar
thanks, man. i just did some research on it, and it looks like worst case scenario, it's caused by a burnt exhaust valve, best case, something minor, like a bad sensor or injector. thanks again. if anybody else has any input, please share.
Military Crew
MM1 (SS)
US Navy Veteran
Old April 17th, 2007, 11:02 AM   #4
Cigar Assassin
GTsetGO's Avatar
12.88 @ 112
GTsetGO has much to be proud ofGTsetGO has much to be proud ofGTsetGO has much to be proud ofGTsetGO has much to be proud ofGTsetGO has much to be proud ofGTsetGO has much to be proud ofGTsetGO has much to be proud ofGTsetGO has much to be proud ofGTsetGO has much to be proud of
iTrader: 10 reviews
i had a couple of misfire trouble codes and come to find out there was a bracket on the back of the driver side valve cover that had stripped one of the wires. If I got on it hard enough it would short the wire and cause a misfire for me. We removed the bracket, put some electrical tape around the wire and went on our. haven't had a problem since.
Old April 17th, 2007, 12:53 PM   #5
Casper98GT's Avatar
you have a cylinder 6 misfire. normally caused by a bad coil pack. Its not a cam sensor and usually if you have chaffed wires it more than one code. Swap the numbert 6 coil pack with the number 5 or 4 and then if it follows then replace the coil pack. If not you have a bad plug or injector. Then do the same with the plug and injector. Easy trouble code you havce there.
91 LX, 5spd.
Ex:Toyota/Ford tech
Old April 17th, 2007, 04:57 PM   #6
Resident Bubblehead
00vabchgt's Avatar
so the stealership's had my car since about 9 this morning and i just talked to the guy (i had to call him). he said the shop foreman "thinks it might be the timing". now maybe i'm all fucked up, but wouldn't that cause a misfire on the whole left bank? i got a bad feeling like the stealership's trying to fuck me.
Military Crew
MM1 (SS)
US Navy Veteran
Threads Similar to: trouble code
Trouble Code P1413 Mrs_Mustang V6 Mustangs 36 December 1st, 2010 06:46 PM
trouble code p1495 DragonFreak 96-98 5 August 18th, 2007 11:02 PM
Trouble code dezzrat1 94-95 0 April 17th, 2007 09:36 AM
Trouble Code pdg36 V6 Mustangs 1 March 29th, 2007 07:35 PM
Trouble code help supu80 V6 Mustangs 8 December 30th, 2006 10:10 PM
