ABS Delete Manifold Installed - Forums at Modded Mustangs
post #1 of 86 Old January 8th, 2011, 05:24 PM Thread Starter
What an easy job. Much easier than I did on my old GT, with "T"ing the brake lines. Unhook 6 lines, Unbolt the ABS Pump, Unplug the connector, unbolt the bracket, and then bolt the ABS delete manifold in it's place. More space and more weight savings.
ABS pump and bracket:
ABS pump compared to the delete manifold:
Delete Manifold Installed:
Bolt-On Bullitt... Unmodified longblock, stock intake and throttle body.
266rwhp/306rwtq
12.25@110.4 1.64 60ft
Currently Under Reconstruction
Bullitt5339 is offline
post #2 of 86 Old January 8th, 2011, 05:39 PM
ran260gt's Avatar
Looks good, what does the pump weigh and did you have to bleed the system?
...Mods in garage
ran260gt is offline
post #3 of 86 Old January 8th, 2011, 05:41 PM Thread Starter
The pump and bracket was about 13lbs. I can't get an accurate measurement though.
Yes, when you break open the lines that come from the master cylinder, it will empty it within a few minutes. I had to bleed the master cylinder and all the brakes.
266rwhp/306rwtq
post #4 of 86 Old January 8th, 2011, 05:46 PM
ran260gt's Avatar
13lbs that sounds nice to me, how do the brakes feel like can you tell any difference ?
...Mods in garage
ran260gt is offline
post #5 of 86 Old January 8th, 2011, 05:46 PM
Willy Mo's Avatar
I like it.. much cleaner.
Willy Mo is offline
post #6 of 86 Old January 8th, 2011, 05:57 PM Thread Starter
My ABS has been disabled for quite a while actually. I had a bad sensor, and just unplugged the pump. I just got around to deleting the pump though. If you know how to drive, and don't make a habit of doing panic stops, you'll never notice it's gone.
266rwhp/306rwtq
post #7 of 86 Old January 8th, 2011, 06:18 PM
Willy Mo's Avatar
where did you get the manifold from?
Willy Mo is offline
post #8 of 86 Old January 8th, 2011, 06:31 PM
0949er's Avatar
what happens when you slam on brakes? you loose the ability to steer during brake lock right?
MODS:
Vortech V1 T-Trim @ 7.5 PSI (tuned down)
Comp Cams XE270-AH
+ See Garage
432 rwhp / 396 rwtq 02/27/2011
NEW VIDEOS!
**It takes ~$60 a rwhp (over stock) for a 99-04 Mustang GT.** Do the Math
PLANS ON HOLD
0949er is offline
post #9 of 86 Old January 8th, 2011, 06:38 PM Thread Starter
A guy on Mach 1 Registry makes them for $105. A bit expensive, but it makes it a very simple operation.
Well, I'm a bit older than most people here, so there was no such thing as ABS when I learned to drive, so I actually learned how to drive. Someone who knows how to drive can stop without ABS faster than slamming on the brakes and letting the ABS do it for you. The only difference is that you can lock the brakes up, it doesn't mean it happens all the time. You just have to know your car.
266rwhp/306rwtq
post #10 of 86 Old January 8th, 2011, 06:43 PM
0949er's Avatar
who needs brakes anyway when you can just power through it
MODS:
Comp Cams XE270-AH
+ See Garage
NEW VIDEOS!
PLANS ON HOLD
0949er is offline
post #11 of 86 Old January 8th, 2011, 06:45 PM Thread Starter
The brakes work exactly the same as they did before. I just don't have anti-lock anymore. The only time I remember even kicking the ABS on in the 3 years I've owned this car is because I hit a patch of ice one morning coming up to a stop sign, and it definitely didn't help in that case.
266rwhp/306rwtq
post #12 of 86 Old January 8th, 2011, 07:47 PM
AngryVanilla's Avatar
Looks good... I always wondered how they delete ABS on these cars... I'm lucky enough to not have ABS/Traction control from the factory...
2004 Mustang GT <---- For Sale
2003 Mustang Mach 1 <---- New Black Slut
AngryVanilla is offline
post #13 of 86 Old January 8th, 2011, 07:51 PM
The Mean Green
MATT02GT's Avatar
Looks clean man.
Bolt on list in Garage...... MM Insomniac Crew
MATT02GT is offline
post #14 of 86 Old January 8th, 2011, 08:46 PM
yes, looks super nice ! Something i'd like to do myself on my car being an "older driver"
Warriorofice is offline
post #15 of 86 Old January 8th, 2011, 10:29 PM
BYAHHHH!
Scott2001GT's Avatar
iTrader: 5 reviews
dude i was just talking about this today!! Doing this for sure. I mounted my turbo today and the room is tight and the ABS is in the way. Might delete me A/C too.
What his his name on the website?
Powered by Ford
Boosted by Precision Turbo and Engine
Thanks to: Wagon Wheel Performance & STL Mustangs
Scott2001GT is offline
post #16 of 86 Old January 8th, 2011, 10:36 PM
!FACEPLATED!
F8L GT's Avatar
iTrader: 13 reviews
Here you go boys
http://www.mach1registry.org/forums/...ete+manifoldur
Teksid short block, Ported 2v heads, Custom ground cams, Edelbrock Vic Jr intake, Brandon Alsept tuned
F8L GT is offline
post #17 of 86 Old January 8th, 2011, 10:36 PM
!FACEPLATED!
F8L GT's Avatar
iTrader: 13 reviews
Here you go boys
F8L GT is offline
post #18 of 86 Old January 8th, 2011, 10:39 PM
ajm
nice and clean
ajm is offline
post #19 of 86 Old January 8th, 2011, 10:43 PM Thread Starter
I ditched the AC a few months ago, it makes the car much easier to work on, that's for sure.
266rwhp/306rwtq
post #20 of 86 Old January 8th, 2011, 10:44 PM
BYAHHHH!
iTrader: 5 reviews
I put my turbo in the car today it's way the way and Im sick of messing with it! Looks like shit and if I need A/C i'll drive my DD...one line grows right across the turbine inlet.
Powered by Ford
Human Verification
LinkBack to this Thread: http://www.moddedmustangs.com/forums/99-04/199045-abs-delete-manifold-installed.html
ABS Pump Delete Brake Manifold - Page 5 - 2003-04 Mach 1 Registry Owners Club This thread Refback August 23rd, 2015 03:07 PM
ABS Pump Delete Brake Manifold - 2003-04 Mach 1 Registry Owners Club This thread Refback August 5th, 2015 04:20 PM
ABS Pump Delete Brake Manifold - 2003-04 Mach 1 Registry Owners Club This thread Refback July 20th, 2015 11:37 AM
ABS Pump Delete Brake Manifold - 2003-04 Mach 1 Registry Owners Club This thread Refback December 23rd, 2013 03:17 PM
ABS Pump Delete Brake Manifold - 2003-04 Mach 1 Registry Owners Club This thread Refback September 21st, 2013 07:54 PM
ABS Pump Delete Brake Manifold - 2003-04 Mach 1 Registry Owners Club This thread Refback May 24th, 2012 02:11 PM
ABS Pump Delete Brake Manifold - Page 5 - 2003-04 Mach 1 Registry Owners Club This thread Refback February 23rd, 2012 09:12 PM
2003-04 Mach 1 Registry Owners Club - View Single Post - ABS Pump Delete Brake Manifold This thread Refback September 30th, 2011 04:32 AM
ABS Pump Delete Brake Manifold - 2003-04 Mach 1 Registry Owners Club This thread Refback September 5th, 2011 10:48 AM
ABS Delete Manifold - New York Mustangs - Forums Post #1 Pingback February 17th, 2011 09:10 AM
