!FACEPLATED!
Heater Plenum Removal(weight reduction)
Alright guys, just a quick question so I can tell what Im getting into. Does the dash have to be removed in order to get the heater plenum out??. thanks in advance
![]() MM Bracket Racing Crew Co-Founder ~Its a Drag Car, Not a Show Car~ LINK-->Custom Race Transmission Build<--LINK
I have always done it, friend says you can finagle it out with part of the driver side loosened, but I just dont see it, maybe its my hulk hands or something, but I just cant finagle it right.
Resident Diabetic...
06' GT
13.829@103.49
![]() ![]() iTrader: 2 reviews
Hey F8L if you want to take any pics of this when you pull it out that would be awesome. I have a sneaking suspicion that I will be doing this soon. I feel a cold draft of out side air coming in the passenger foot well area. Also when I put it on Max ac it flows louder but weaker out of the vents, and I dont feel it blowing any better anywhere else lol.
2006 GT-3.55's, Pypes Muffler Delete, PIE Aux Port, GT500 Pedals, Hurst STS, GT500 LCA's, 55D rear springs, FRPP A arm brace, Diablo 93 Tune. ![]() motortalkblog.com |
mm's nitrous mod
2000 mustang gt
11.79@115.83 (old set up)
2003 mustang v6 ;)
slow
![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() iTrader: 2 reviews
i had to pull my dash out when i swaped heater cores, i know its not the same but that unit is large and i see it being much easier to pull with the dash out.
not sure if this helps but here is a pic of it when i swaped my heater core.
Yea, you'll have to pull the dash to get it out.
![]() 2000 CSVT 03 Escape 3L block, 02 Mercury Cougar 2.5 heads, SVT cams untuned. Stock manifolds, short ram intake, MSDS Y pipe, stock exhaust. 195whp/182wtq 1985 Honda 450 Nighthawk 70+MPG average 8200 miles and counting
!FACEPLATED!
looks like I will be pulling the dash. Stal, you have any advice on things to look out for?
Bringing Yellow Back
that looks like zero fun
![]() SOON TO BE 5.4 3V POWERD WITH A ROUSH CHARGER HELPING IT ![]() BAMA Performance Drag Team Member #4 |
2003 mustang v6 ;)
slow
surprising there really isnt a whole lot to it. all the wire harnesses end at the kick pannels so you just unclip them there. REMOVE THE SEATS way easier. start with the steering wheel then go to the center councal/radio area. then driver passenger side, i belive it is held up by 4 bolts per side and pull that bitch out.
!FACEPLATED!
Thanks man, I'll probably give it a go this weekend
2003 mustang v6 ;)
slow
its really not as bad as you would think, my problem is i unhooked more than i needed, ford made the dash so everything was hooked up then droped in. there are 4 bolts down by the shfter area, 4 bolts per side, and if my memory is correct there is 3-4 wire harnesses per side to unclip, then pull the dash out.
2003 mustang v6 ;)
slow
if you look in this pic i pulled way to much out, you dont need to unhook the gauge pod, radio, i belive you may have to pull the ac stuff out cause your getting rid of it
!FACEPLATED!
I dont think pulling the dash would be hard at all. Just making sure thats what has to be done in order to remove the plenum
I'm going On A Manhunt!
2002 true blue GT
speed of time @ 88mph
how long would you say it would take to remove the dash?
mac lt's, mac O/R H pipe, spintech super prostreets, JLT RAI, 14"antenna, mach 1 chin spoiler, two 12" kickers.
06' GT
13.829@103.49
Thanks for the pics.
2003 mustang v6 ;)
slow
i had my dash out in a couple of hours, it takes 2 people to do cause there is a heavy ass metal bar that runs behind it, making it awkward to move around. i took the pics to show people you can pull the heater core out with out draining the ac.
2003 mustang v6 ;)
slow
btw if you want to save a lot of weight pull the metal bar out from behind the dash.
2003 ford mustang gt
13.9 stock
is a heater plenum the same as a heater core?
k&n cai, mangaflows exhaust, summit udp's, 24lb injectors, 78mm bbk plenun, tri-ax s/s, a/c delete,3.73's, aluminum drive shaft, upr upper/lower control arms, solid motor mounts, bbk heades, upr xpipe,bbk cc plates, camber bolts.bama tune
2003 mustang v6 ;)
slow
#20 | |
06' GT
13.829@103.49
Threads Similar to: Heater Plenum Removal(weight reduction)
| Weight Reduction | ironsteed5.0 | 5.0 Mustangs | 2 | November 7th, 2009 01:49 PM |
| what possible weight reduction? | mystang0673 | 99-04 | 37 | January 13th, 2009 07:12 PM |
| weight reduction ftw | DickH | 99-04 | 12 | September 8th, 2008 04:29 PM |
| Weight Reduction? | thlsislt | 2005 - 2010 | 20 | December 27th, 2007 12:56 AM |
| Weight Reduction | GTSilver | 99-04 | 6 | September 24th, 2006 11:59 PM |
