Idle problems after Plenum/TB/o/r X pipe installation
Old April 17th, 2007, 03:27 PM   #1
throwedoff's Avatar
throwedoff is on a distinguished road
I installed these 3 things at the same time on my 1999 GT, and also used some DIY mil eliminators to hook to my rear O2 sensors to make sure I didn't get a check engine light.
Well, after installing all of this, I have severe idle issues. It's very random, sometimes at a stop the car will repeatedly drop to ~200rpm and then rev up to 1500, sometimes it will die completely while doing this. Sometimes it will sputter while driving at 1300rpm. Sometimes I will literally have to floor the pedal to get it to move from a stop, sometimes it is completely fine.
After resetting my computer and driving about 20 miles, my check engine light comes on. I got the codes read at autozone today and this is what came from that:
Code: P1151 -- Please note that the TPS I am using DID come with the plenum I purchased, it is not my old TPS.
Definition:
Accelerator Position Sensor (APS) property malfunction
Probable causes
1.-Open or short circuit condition
2.-Poor electrical connection
3.-Failed APS
Code: P0136
Definition:H02S 12 circuit condition (Heated oxygen sensor bank 1 sensor 2) Can anyone tell me what O2 sensor in particular this is? I know that it is post-cat, but not what side it is on.
Explanation:
The powertrain control module uses the oxygen sensor to calculate the air/fuel ratio in the exhaust.
Probable Causes
1.-Oxygen sensor defective
2.-Fuel system running very rich or lean-check other codes first
3.-Engine misfire condition-repair
4.-Fuel pressure very high or low-fuel pump or pressure regulator
Code: P1131
Definition:
H02S 11 - Indicates Lean- Correcting for over rich condition
Probable Causes
1.-Leaking injector, regulator or excessive fuel pressure
2.-Engine vacuum leak or open EGR valve at idle
3.-Engine mechanical condition
4.-Failed H02S or MAF sensor
Where should I start looking? Could all of these problems be caused by the TPS problem? As I stated, I do have MIL eliminators hooked up, which should work, so I don't know why the O2 sensors would be throwing codes.
Old April 17th, 2007, 03:37 PM   #2
bigbadwollfff04's Avatar
bigbadwollfff04 is on a distinguished road
Well two of the problems are coming from the throttle body and plenum, but the other one is boggling me!! I really think you need get yourself some sort of tuner, either a SCT Flash or Diablo, they really help you control the amount of fuel, and your idle speed, but as far as the O2 sensor you can shut this off, i shut it off on mine, seems okay so far, but haven't pushed it yet!! Good luck!! STUMPED
Aww, did I step on your poor little bitty ego?
Old April 17th, 2007, 03:51 PM   #3
barksdaleammo is on a distinguished road
+1
Old April 17th, 2007, 03:56 PM   #4
throwedoff's Avatar
Thanks for the response. I'm definitely getting a SCT xcal2 sometime in the near future, but do you have any suggestions as to what I could do to fix these problems until then?
Edit: Also, what 2 of the problems are coming from the TB/plenum specifically?
Old April 17th, 2007, 03:58 PM   #5
RLY SRS
ChrisJ's Avatar
iTrader: 10 reviews
Do you use a chip with a tune on it?
P1151 HO2S21 lack of 'switch', sensor Indicates Lean, (This is seen by the long periods of flatlining on the trace on the low reading. A lack of switch on the high side would generate the error P1152)
P0136 Downstream Heated Oxygen Sensor (H02S 12) circuit malfunction (Bank # 1)
P1131 Lack of upstream Heated Oxygen Sensor (H02S 11) switch, sensor indicates lean (Bank #1)
What kind of mils did you use? becuase it sounds like they are not working...
You did put them on the rear 02's right?
And you did not just remove the 02 sensor right? They have to be in there...Even if you do have them turned off in a tune...
Facebook
Google+
Old April 17th, 2007, 03:59 PM   #6
RLY SRS
ChrisJ's Avatar
iTrader: 10 reviews
Also the problem with the TPS could be that you dont have the voltage just right which can make the car throw codes and run like crapola...
Facebook
Google+
Old April 17th, 2007, 04:43 PM   #7
throwedoff's Avatar
I don't have a chip/cutsom tune. The MILs that I am using are made from the schematic linked to at the bottom of this page: http://www.fordmuscle.com/archives/2...ale/index.php#
And yes, I put them on the rear O2s and did not remove the O2s.
Old April 17th, 2007, 04:49 PM   #8
throwedoff's Avatar
I haven't checked the TPS voltage, but from what I hear it's pretty simple to check/adjust, am I correct?
The TPS came pre-attached to the throttle body when I bought it, and I haven't messed with it at all.
Old April 17th, 2007, 05:01 PM   #9
RLY SRS
ChrisJ's Avatar
iTrader: 10 reviews
Yes its pretty easy to do with a voltage tester...
Sounds like your mils are not working...
Facebook
Google+
Old April 17th, 2007, 05:03 PM   #10
throwedoff's Avatar
Would that cause bad idle problems and also cause me to get horrible gas mileage (I'm talking 12mpg here).
Or, would that be related to the P1151 code (which says it's 'failed accelerator position sensor')
Old April 17th, 2007, 05:40 PM   #11
throwedoff's Avatar
Also, I just looked, and the TPS is a Ford TPS, not aftermarket.
1999 GT - CAI, Flowmaster 40s, MAC O/R X-Pipe, 70mm p&p MAC TB, p&p plenum,
SCT Xcal2 running 93 octane tune, and heavy ass 20 inch rims.
Old April 17th, 2007, 06:04 PM   #12
RLY SRS
ChrisJ's Avatar
iTrader: 10 reviews
It does not matter what type TPS it is...Its about the voltage...
There is a write up on here on how to do a test on them...
ANd yes bad 02's and faulty mils will cause horrid gas mileage...
The bank 1 upstream 02 (thats before the cat) is what could be screwing the gas up...And your car has to be running like $hit right now...
Facebook
Google+
Old April 17th, 2007, 06:22 PM   #13
throwedoff's Avatar
Oh yeah, definitely running horribly. Would bad mils cause the car to run worse than it would with no mils? I think I'm going to pull them off and try checking the TPS voltage like you guys suggested... Thanks!
Edit: Also, does it look like the upstream O2 could be bad or could it straighten out once I get the TPS and downstream O2 problems worked out?
Old April 18th, 2007, 01:41 AM   #14
neckbonekat's Avatar
2005 Cadillac STS V8
You may want to invet in a tuner soon than planned. When I put my O/R X pipe on I just turned my sensors off and haven't had any issues yet. I had a similar issue with the rough idle and the cr trying to shut off but that was because I put on a 85mm MAF and my car didn't like it one bit.
ITEMS FOR SALE!
4.10 GEARS + BEARING KIT
Old April 18th, 2007, 10:07 AM   #15
check the voltage, and just buy a tuner, should be all good then, shut off the O2 sensors ASAP!!
Old April 18th, 2007, 10:47 AM   #16
zkid01 is on a distinguished road
+1, Listen to this guy he is right on target. One of your MILS is not working correctly.. As far as the TPS..make sure you plugged it back in for one.. then do a voltage check.. its simple. That should solve your problems. And i would deff think about getting a tuner if i was you. Good luck.
Work Hard....Play Harder.
Old April 18th, 2007, 07:42 PM   #17
throwedoff's Avatar
Ok, I just tested the middle wire of my TPS (with key turned to acc) and it gave 1.03v closed, and 4.67v WOT. Does this need to be adjusted to be exactly .99v or is 1.03 close enough?
Old April 18th, 2007, 09:26 PM   #18
throwedoff's Avatar
I got it to right at .98 and it didn't help any. With the motor running, it fluctuated from .6-1.08
Old April 18th, 2007, 09:54 PM   #19
DrHolliday is on a distinguished road
Did you check all your vacuume hoses? Sounds like the idling problem could be a leak somewhere or a problem with your IAC sensor on the plenum.... Some one correct me if I'm wrong.
Mustangless atm
2006 2500 HD Diesel. Built allison trans and other goodies
Old April 18th, 2007, 10:39 PM   #20
throwedoff's Avatar
Sure did, I've looked over all hoses and gaskets multiple times.
Edit: Just bought an impact driver and got the TPS off of my old TB (surprisingly, even with the impact driver it was a pain in the ass to get off). I'll be swapping the TPS out with the other one soon to see if it makes a difference.
Threads Similar to: Idle problems after Plenum/TB/o/r X pipe installation
X Pipe Installation..help! Seabee General Tech 5 September 1st, 2007 10:15 PM
h pipe installation SilverGT04 99-04 9 August 30th, 2007 11:12 PM
Idle problems El_Cangri V6 Mustangs 28 April 15th, 2007 06:35 PM
Idle Problems Code 1506, Idle Overspeed Error jagstang96 96-98 3 August 29th, 2006 04:11 AM
Idle problems 5sppony V6 Mustangs 0 June 30th, 2006 02:05 PM
