Engine noise on cold morning start up - Forums at Modded Mustangs
post #1 of 5 Old January 12th, 2011, 08:20 AM Thread Starter
cedsks's Avatar
I have a remote start on my stang, I went out to start it and noticed a very slight tick noice that went away after about 5 mins of idle.
I just changed the oil with 5 qts of 5-20 royal purple and lucas synth to top it off. Is this just normal in the snow covered car and cold weather or do I have the beginings of engine failure?
This is the first time I have noticed this sound on start up, its about 14ºF out side.
49k on my clock right now
2004 2v GT--3.90's, t3650, H&R SS, 78mm TB, K&N CAI, steeda bump stop kit, HP Blues shocks and struts, soon to have a rear seat delete, light weight driveshaft.
cedsks is offline
post #2 of 5 Old January 12th, 2011, 08:41 AM
Normal. It's freezing outside and these engines take for ever to warm up especially in the winter.
Why do you use lucas additive, I would think Royal purple alone would be good enough.
If I were you though I would start using 5w30 instead of 5w20 if you prefer a longer living engine over a non-noticeable increase in gas mileage.
Stang187 is offline
post #3 of 5 Old January 12th, 2011, 09:51 AM
sl04gt's Avatar
+1 stang187
CRAZY HORSE RACING
couple of bolt-ons and bolt-offs
sl04gt is offline
post #4 of 5 Old January 12th, 2011, 10:02 AM
a.k.a. Racecougar
Tang Stang's Avatar
I agree that the Lucas additive is a waste at the least. If you do a search on it over at BITOG you'll see quite a few negative things posted about it, the worst of which is that it reduces the anti-foaming agents in the oil and allows the oil to "froth" or "foam" up.
Rod @ AzzKicker Cars
2004 Ford Mustang GT-The Driver-BBK CAI, PP TB & Inlet, Steeda UD's, SLP LM1, & 3.73's.
1990 Mercury Cougar XR7-The Meth Addict-5.0L DOHC Stroker w/2.1L KB SC.
1995 Ford F150-Mud Toy-5.0L, 4x4, 33's, & Warn 8274 Winch
Tang Stang is offline
post #5 of 5 Old January 13th, 2011, 03:03 PM
JM0523's Avatar
The lucas is like glue and all its doing is thickening the hell out of your oil until it warms up, i would attribute the thicker oil on startup to the noise your hearing, i would try just plain royal purple next time and see if it still makes the noise upon startup.
02 Mustang GT M5- MMS SFC'S, Fidanza Clutch, 3.90's, Accel Coils, C&L Plenum, C&L Tube, Accufab 75mm, K&N, Steeda Tri Axe, X Pipe, Magnapacks, Predator, Venom Nitrous, Eibach Springs, Eibach Shocks, Classic Shaker, 315 Kumho XS.
JM0523 is offline
Human Verification
