Need Your Opinion
Old January 18th, 2011, 11:06 AM   #1
2001 Mustang GT
ONEOFAKIND01 is on a distinguished road
Need Your Opinion
I have an 01 gt with a stock auto transmission with 2200 stall and jmod. For one reason or another i lost over drive and i have no idea why so i was hoping someone on here may know the problem. The people i have talked to work on transmissions and say it sounds like i'm starting to lose the transmission....IDK i have no clue. I hate an automatic because i had a 5 speed before this car and loved being able to put in whatever gear i want and its more fun IMO so how hard would it really be to swap out an auto for a manual is the real question?
Old January 18th, 2011, 12:06 PM   #2
Cruzzer08's Avatar
04 GT vert
Cruzzer08 is on a distinguished road
Hey man welcome to MM, remember to do some searching before starting a new thread.. Check out the Stickys on the top of the thread list, I don't know anything about manual swaps but this was in the How to Center...
manual swap how to
There are a whole bunch of auto guys on here "Casper gt" always has allot of good info search for some threads with his comments.. He doesn't like J-mods though
Bullitt5339 seems like hes been working on autos for years and swears by J-mods so he might be a little more help for you particular set up...
Good luck
Old January 18th, 2011, 02:02 PM   #3
rodeheavers's Avatar
1981 4 EYED FREAK
9.48@147
rodeheavers is on a distinguished road
does your speedo still work? If the speedo quit at the same time , that ususally means your speed sensor in the tranny took a dump.
www.rodeheavershotrod.com
9.48@147 on pump gas through the
mufflers, still has pw,tilt,t-tops,all
lights, wipers!!!, check out the vid
http://www.youtube.com/watch?v=SloE3Zdetac
Old January 18th, 2011, 05:26 PM   #4
Moderator
casper gt's Avatar
2012 300a gt auto
12.10@116
casper gt has a brilliant futurecasper gt has a brilliant futurecasper gt has a brilliant futurecasper gt has a brilliant futurecasper gt has a brilliant futurecasper gt has a brilliant futurecasper gt has a brilliant futurecasper gt has a brilliant futurecasper gt has a brilliant futurecasper gt has a brilliant futurecasper gt has a brilliant future
first I'd find out exactly is done to the car & what it's doing now to make you think you have a trans problem.
the reason I say that is because these cars come stock with a 2400 stall converter so someone was in there that didn't know what they were doing if it has a 2200 stall converter in there now.
as to hating on the auto, try driving a car with a properly built one before you give up on them.
MM BRACKET RACING CREW CO-FOUNDER
BAMA Performance Drag Team Founder
2012 300a GT auto
Old January 18th, 2011, 06:41 PM   #5
blownstang's Avatar
blownstang has a spectacular aura aboutblownstang has a spectacular aura aboutblownstang has a spectacular aura about
Overdrive band probably took a poop. How many miles on the car?
2003 DSG Mustang GT 5spd
Full Bolt On's, Suspension, Built Rear, V1 S
N/A: 266/300, 3,550lbs, 13.44 @ 100.5 1.77 60'
Non-intercooled: 356/371, 3,575lbs, 12.81 @ 110.47 1.86 60'
Intercooled: 362/370
Old January 18th, 2011, 08:48 PM   #6
ytngt has a spectacular aura aboutytngt has a spectacular aura about
I agree. Low probability it's the OD servo.
The auto to 5/6 speed swap is fairly easy. I just went through this and a $45 5 speed harness (tousley ford) is the easy way to go for wiring. As long as you don't have longtubes (especially bbk) changing a transmission is easy.
Old January 19th, 2011, 12:36 PM   #7
2001 Mustang GT
yeah about the 2200 stall converter is what i was told was put in it before i bought the car. The speed odometer still works. And there is 73k on the car, motor, etc
Old January 19th, 2011, 12:39 PM   #8
2001 Mustang GT
And there is 73k on the car, motor, etc. Is it more likely that 410rwhp is a little to much for my tranny being that it may need to be built up a bit?
Old January 19th, 2011, 09:58 PM   #9
Moderator
casper gt's Avatar
2012 300a gt auto
12.10@116
410 is nothing for a 4r70w, but it could just be getting old/worn.
2012 300a GT auto
Old January 19th, 2011, 10:07 PM   #10
86er's Avatar
is o/d totally gone, slipping, what exactly is it doing. Are you s/c or nitrous fed with the stang?
Just a truck
Old January 20th, 2011, 08:51 AM   #11
2001 Mustang GT
Thanks casper i've just never looked into what the 4r70w can hold. And 86er at lower rpms it very very slightly wants to grip but anymore pressure on the gas and its just like nothing is there at all. And i'm s/c fed idk how to put performance parts under my post lol
Old January 20th, 2011, 06:49 PM   #12
Moderator
casper gt's Avatar
2012 300a gt auto
12.10@116
did you check the fluid level?
as far as your mods, go to the user cp near the top of the page & click on edit garage, then put in your info.
2012 300a GT auto
Old January 22nd, 2011, 04:25 PM   #13
2001 Mustang GT
Yes the fluid level was normal and didnt smell burnt or anything abnormal.
Threads Similar to: Need Your Opinion
Second opinion trent2590 99-04 8 March 29th, 2010 12:12 PM
Need an opinion. 97S281 96-98 2 January 11th, 2009 08:02 PM
i want your opinion 00redgt The Clubhouse 11 January 8th, 2009 12:36 AM
My opinion. 07stanggt 2005 - 2010 20 January 1st, 2009 09:29 PM
2nd Opinion FTW oldernewbie The Clubhouse 8 December 19th, 2007 06:32 PM
