2000 Mustang V6
mach 1 or gt 4v?
was thinking about getting a gt and if i wanted to make it faster i would make it 4v. Got a couple questions about this besides the fact that the mach one has 3.55 on the rear end and the gts dont would a gt 4v and mach 1 4v be equal in a race? also anyone know how much it would cost including labor so i can see if i should just buy a mach 1 from the start? and last question would the rev limiter go up on the gt if you make it 4v like the mach 1?
99 gt
First of all ^^WTF^^
It all depends on what 4v set up youd go with. cobra heads, cams and intake? or mark VIII, or mach 1 heads, cams, ect. If your goal is a 4v either way, just buy a mach. Then you dont have to do any work swapping top ends, or engines for that matter.
Resident Diabetic...
06' GT
13.829@103.49
![]() ![]() iTrader: 2 reviews
+1 to Willy.
As far as the rev limiter, it can/will be pushed up after you get the gt re tuned for the 4v motor. If you can't afford a Mach you can always get a cheap gt and swap in a Lincoln Mark 8 motor for cheap if you can do the labor. But like Willy said, go for the Mach if you can afford it. Or hell a Cobra if you are in that price range.
2006 GT-3.55's, Pypes Muffler Delete, PIE Aux Port, GT500 Pedals, Hurst STS, GT500 LCA's, 55D rear springs, FRPP A arm brace, Diablo 93 Tune. ![]() motortalkblog.com |
#5 | |
2000 Mustang V6
2003 Mustang GT
Get a Mach 1. Much better car stock for stock. And will hold value a lot more. Bone stock they run low 13's. My dads bone stock was running 13.2 @ 105mph.
Mach 1's look a lot better, seats are 10x better, handling is better, brakes are better etc... The 5 speeds also have a steel crank, and rev to 6800 rpm.
![]() Vortech V1 Intercooled @ 11psi 394rwhp/392rwtq @ 9.5psi 415rwhp/400rwtq @ 11psi on Methanol Tuned By: Pete @ Performance Dyno Affordable Supercharger Build Guide Supercharger Info for Noobs |
2004 Mustang Gt
13.17@106.7 1.8 60ft
yea the mach is better overall but the gt has potential too just depends on what you want...get the mach lol
CRAZY HORSE RACING couple of bolt-ons and bolt-offs |
machs also have an aluminum block which weighs approximately 80 pounds less than the GT's iron block.
2002 Procharged GT 12.503 @ 113.08 351rwhp 353rwtq Car Videos: http://www.youtube.com/user/mell00ut5?feature=mhee
06' GT
13.829@103.49
Yea Mach over Gt if you have the option. No doubt.
And if you get a cobra and don't like the IRS, let me know and Ill trade you lol.
2001 Mustang GT Vert.
If you plan on boosting later on down the road, I believe the mach's came with higher CR...like 11:1. Just something to keep in mind.
Get a Saleen or Cobra
02 Mustang GT M5- MMS SFC'S, Fidanza Clutch, 3.90's, Accel Coils, C&L Plenum, C&L Tube, Accufab 75mm, K&N, Steeda Tri Axe, X Pipe, Magnapacks, Predator, Venom Nitrous, Eibach Springs, Eibach Shocks, Classic Shaker, 315 Kumho XS. |
2003 Mustang Mach 1
No, 10.1:1 is the stock CR on a Mach 1. And they can handle a reasonable amount of boost, like in the 8-9psi range. However, they do take real nicely to giggle gas in the form of a 75-125shot!
2003 gt
5.4 32v on the way
if you just want to buy a decent car, get the mach, if you want a project, get a fox. The mach is a nice car and has plenty of room to grow, the gt will require that you do a lot of work to it after you buy it just to put it even with a stock mach.
2003 Mustang gt - usual mods - slowly working on 5.4 swap 2004 srt4 - Stock DD/winter beater Click here for your tuning needs Before asking a gearing related question click THIS link and enjoy all your saved time. |
BYAHHHH!
2001 Mustang GT
13.874
![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() iTrader: 3 reviews
is it weird that I'd perfer a Mach1 over a 03/04 termi?
![]() Precision Turbo|TurboSmart|TeamZ|Strange|Hellion|BBK|SCT|Edge Converters|Fairbanks|CG Fabrications|Treadstone |
BYAHHHH!
2001 Mustang GT
13.874
yeah but. but get a Mach1. You bave a SRA, Alum block, 4v, good intake to port, nice interoir, exterior, and in the 5 speed a forged crank and the auto is a 4r75w. So easy to mod up nicely. Get the auto and a forged crank, h beams, and better pistons. since the termi pistons and the weak part. Do the same dish for high CR and boost the shit out of it! And no one will think it's fast but it will be faster then a termi with just weight alone.
06' GT
13.829@103.49
I hear ya. I would prefer a a clean Mach over a not quite as clean cobra. Also everyone expects a cobra to be fast. Alot of Machs are about as slow as gt's. (w/o the drive mod that is.)
A mach with a good driver is pretty decent.
I see it like this. I have a GT because I can make it run good and look good for less money than a Mach. Granted if I had the money I would have a Mach 1. I say get the Mach 1 if you can get one for a cheaper amount of money. and if you are worried about the IRS in the Cobra you can always switch that out.
Threads Similar to: mach 1 or gt 4v?
| mach vs mach **video** | RALVAREZ26 | Videos | 12 | November 14th, 2010 05:39 PM |
| need help with the mach | 04MachOne | 4V / SVT | 4 | May 11th, 2010 05:22 PM |
| 04 mach 1 | RC02GT | 99-04 | 5 | March 21st, 2008 06:13 PM |
| Need help on 03 MAch | nHuman | 99-04 | 36 | January 7th, 2008 10:45 PM |
