2000 Mustang Gt
13.56 @ 106
tranny and rear end fluid questions
ok im at 50k, i bought my stang used, dont know if either fluids have ever been changed. i want it done for the spring, summer.
ive heard any synthetic for the tranny but what about the rear? and also is friction modifier necessary. ive heard so many different things.from yes,no and no if i use synthetic. whats the truth? thanks matt
JLT - Accufab - MPH Heads - VT Stage 2 N/A cams Manley Valves/Springs - Centerforce Dual Friction BBK LT's - BBK o/r H - Bassani catback FRPP 4.10s - XCAL2 - BBK UDP's 306rwhp/333rwtq |
48.47@ 12.58
use royal purple and the friction modifier.
try a tight turn without friction modifier in your car and you can bet your ass end will jump about 3 feet when those gears start to pop
MM's nicest mod, :)
i would not put synthetic in the rear.
06 Dodge MegaCab Diesel 455rwhp/815rwtq REAL TRUCKS DON'T USE SPARK PLUGS |
MM's Mad Scientist
Slow Fella
![]() ![]() ![]() ![]() ![]() ![]() iTrader: 2 reviews
I use Lucas synthetic only in the rear. It is the only thing I have found that doesn't eventually cause binding.
Lucas is a great oil for rearends.. I have some redline race oil in mine. And i have seen good results with royal purple in the tranny.
Work Hard....Play Harder.
2000 Mustang Gt
13.56 @ 106
the friction modifier is only needed in the read end right? not in the tranny fluid correct?
MM's Mad Scientist
Slow Fella
I don't use any friction modifier
Proud American
Yeah the the friction modifier is only needed in the rearend! And for the money it costs it is not a waste!!
the mobil 1 75-140 has a modifier in it. and states that no other friction modifier is needed. thats what it said on their website.
Alot of the better brand rear end oils have the modifier already in it. So dont add more.. this can actually cause problems.. haha and dont put any in the tranny...
i use amsoil full synthetic in all my cars fluid areas...no probs!
04 mach 1 |
Threads Similar to: tranny and rear end fluid questions
| tranny fluid | fsttang96 | 96-98 | 7 | October 27th, 2007 10:31 PM |
| tranny fluid | 96gtponyred | 96-98 | 4 | August 8th, 2007 04:49 PM |
| What Fluid do you use in your T5 Tranny? | noyz25 | 5.0 Mustangs | 6 | August 6th, 2007 04:25 AM |
| tranny fluid | Mustang RacR94 | V6 Mustangs | 1 | April 29th, 2007 10:18 PM |
| tranny fluid | terribleonexx88 | 5.0 Mustangs | 20 | November 24th, 2006 05:41 PM |
