UPR Coil Over's with Strange Struts, maybe have to modify C/O sleeve? - Page 2
LinkBack (2) Thread Tools
Old January 22nd, 2011, 11:46 AM   #21
slow02gt's Avatar
2002 mustang gt
11.38@119
slow02gt is a jewel in the roughslow02gt is a jewel in the roughslow02gt is a jewel in the roughslow02gt is a jewel in the rough
Send a message via AIM to slow02gt
i use the 3 bolts on my cobra you will be just fine with them.... i have used the 3 bolts on 9-10 sec cobras..
built motor,trickflow heads,logan intake,80mm comp turbo on the way..
Old January 22nd, 2011, 04:14 PM   #22
mrbigjeep's Avatar
04 mustang gt
7.21 @ 98
mrbigjeep is a splendid one to beholdmrbigjeep is a splendid one to beholdmrbigjeep is a splendid one to beholdmrbigjeep is a splendid one to beholdmrbigjeep is a splendid one to beholdmrbigjeep is a splendid one to behold
Originally Posted by cbjohnson9 View Post
Why would upr develop a set of 4 bolt plates if the 3 bolt plates were sufficient?
It also probably depends on how much stress your putting on them. I'm running 275/12's up front and autocross so the stronger I could make my strut tower, the better. I'm going up to 325's when I switch to a torque arm.
There is a big difference in fox cc's vs New edge cc's. Picture a triangle made by the 3 bolts on the plate. On a fox, the strut pertrudes up within that triangle, distributing the weight into all three bolts. On a new edge, the strut pertrusion lies outside this triangle, causing uneven weight loads. This is why the new edge mustangs require 4 bolt plates for CC's. The strut is enclosed by the bolts and stabilizes load distribution.
i asked the same question and the answer straight from jeremy himself was that they came out with the 4 bolts because the autocross/road course guys wanted them...guess what? i don't do turns...lol.
if your into that then by all means get the 4 bolts. otherwise i think the 3 bolts are fine for drag and street driving (which is the only turns i do!)
cams + 150 shot
Old January 22nd, 2011, 04:21 PM   #23
BaznastyDave's Avatar
2004 Mustang
BaznastyDave is a name known to allBaznastyDave is a name known to allBaznastyDave is a name known to allBaznastyDave is a name known to allBaznastyDave is a name known to allBaznastyDave is a name known to all
Yeah I believe they are fine for drag racing but I wanted the 4's bc they have more adjustment in them, I would hate to put the 3 bolts on my car and take it to get aligned and they say it does not have enough adjustment to fix it.
305/333 WHP/WTQ with CMS Stage II cams
440/552 WHP/WTQ on Spray
7.86 @ 89.1mph, 1.61 60 foot N/A
7.20 @ 98.8MPH 1.55 60 foot on spray
Stock Longblock with Cams
Old January 22nd, 2011, 04:23 PM   #24
mrbigjeep's Avatar
04 mustang gt
7.21 @ 98
adjustment is the same according to jeremy.
i asked that too...you just gotta change to the other slots if it doesn't have enough.
regardless, nothing wrong with going to the four bolts
cams + 150 shot
Old January 22nd, 2011, 04:31 PM   #25
2001 Bullitt
12.25@110.4
Bullitt5339 is a glorious beacon of lightBullitt5339 is a glorious beacon of lightBullitt5339 is a glorious beacon of lightBullitt5339 is a glorious beacon of lightBullitt5339 is a glorious beacon of lightBullitt5339 is a glorious beacon of light
You can tell Jeremy he's full of shit for me then.....
I had the UPR Shark 3 bolt plates, and they couldn't get my camber correct on either of the settings those POS's have. I went to Holcomb and bought the 4 bolt set from UPR, installed them, and it aligned to the specs I wanted the 1st time.
So, no matter what Jeremy says, the 4 bolt plates with their true sliding adjustment will give you more adjustment on camber than the POS Shark plates and their 2 different slotted settings for camber.
And the Shark plates tear up the paint on the top of the strut towers. I have some touch up painting to do now because of them.
Bolt-On Bullitt... Unmodified longblock, stock intake and throttle body.
266rwhp/306rwtq
12.25@110.4 1.64 60ft
Currently Under Reconstruction
Old January 22nd, 2011, 04:34 PM   #26
mrbigjeep's Avatar
04 mustang gt
7.21 @ 98
oh well..
i got mine close enough. got it back to the same specs it was before coil overs. i had no problems.
cams + 150 shot
Old January 22nd, 2011, 04:41 PM   #27
2001 Bullitt
12.25@110.4
In theory, they should allow plenty of adjustment, but the plates themselves hit the ridge to the outside of the strut towers before I reached the necessary adjustment. With the spacers under the plates, I could slide the plates further out before they made contact. In order to get the Shark plates out far enough to correct my camber, I would have had to cut the outside of them off.
266rwhp/306rwtq
Old January 22nd, 2011, 04:43 PM   #28
mrbigjeep's Avatar
04 mustang gt
7.21 @ 98
well i suppose he will like the four bolts...
either way i still like my shark plates
cams + 150 shot
Old January 22nd, 2011, 08:00 PM   #29
2004 Mustang
Yeah I would hate to get em on and waste time and money not being able to adjust them enough and then you can't send em back b/c they have been used, glad they worked for you though Jeep.
LinkBack to this Thread: http://www.moddedmustangs.com/forums/99-04/200561-upr-coil-overs-strange-struts-maybe-have-modify-c-o-sleeve.html
mustang coil over sleeve id | BoardReader This thread Refback April 19th, 2011 03:50 PM
Thread Who's using upr coilovers with strange struts | SVTPerformance | BoardReader This thread Refback March 12th, 2011 03:40 AM
Threads Similar to: UPR Coil Over's with Strange Struts, maybe have to modify C/O sleeve?
Will Strange struts work? 2VSouth 99-04 23 November 28th, 2010 03:04 PM
Strange Coil Over pacopatron 5.0 Mustangs 5 November 16th, 2010 07:05 PM
Strange Struts and Shocks I8ACMRO 99-04 17 April 9th, 2010 12:09 PM
Those with Strange Shocks and Struts Hawaiianbro 99-04 0 August 19th, 2008 04:52 PM
strange 10 way adjustable struts DILO2001GT General Tech 2 July 16th, 2006 11:31 AM
